Question about Mitsubishi VS-50705 50" Rear Projection Television
Mitsubishi vs 5075
Tv was working fine yesterday. Today green light comes on , but screen is black - no sound. cant turn tv off either with remote or manually. when i unplug set i hear clicking sound. same sound i hear when i plug it in . i checked all fuses- they are ok. does anybody have any ideas what the problem is- thank you
  • mundy Nov 12, 2007
    tv was working fine yesterday. Today green light comes on , but screen is black - no sound. cant turn tv off either with remote or manually. when i unplug set i hear clicking sound. same sound i hear when i plug it in . i checked all fuses- they are ok. does anybody have any ideas what the problem is- thank you
    Genius:
  • 1,153 Answers
THIS MODEL IS EQUIPPED WITH A KEYBOARD LOCK FEATURE; THIS CAN BE MISTAKEN AS A NO POWER CONDITION. TO UNLOCK THE KEYBOARD PRESS AND HOLD THE "MENU" BUTTON ON THE FRONT PANEL FOR 10 SECONDS
Posted on Mar 10, 2008
Mitsubishi
YOU NEED TO CALL THE MITSUBISHI TECH SUPPORT, THEY SHOULD BE ABLE TO TELL YOU FOR FREE THE POSSIBLE TROUBLE...JUST EXPLAIN THE ERROR CODE..GOOD LUCK
Nov 10, 2013 | Mitsubishi VS-70707 70" Rear Projection...
Mitsubishi VS-50609 won't turn on
What a great tv this is Mitsubishi did a fine job making this one, but......only an authorized mitsubishi servicer should repair it. This set records diagnostic led codes that the technician receives to help determine where the problem might be, not the problem, but in which circuit it might be. The one thing to try is, unplug the tv , let it set for a minute, plug it back in , turn it on and hope it reset the micro. Next , call for mits. service.
Jun 11, 2009 | Mitsubishi VS-50609 50" Rear Projection...
I have a Mitsubishi vs-4543 tv that when powered
check the power supply section.. probably the electronic component got problem.
Jun 04, 2009 | Mitsubishi VS-4544 45" TV
I HAVE SOUND BUT NO PICTURE
Is it a rear projection tv? plasma? or LCD?
Feb 15, 2009 | Mitsubishi VS-5075 50" Rear Projection...
Mitsubishi VS-5075
Your standby power supplies are most likely at fault you should check the low voltage regulators and see if they are functioning they may be defective.
Jun 16, 2008 | Mitsubishi VS-5075 50" Rear Projection...
Mitsubishi VS-50501 - Black Screen
Is the power light staying on? If so press imput and menu together for 5 seconds to see if the set will blink a 2 digit repeating code. If that doesnt work. Check for CRT coolant leaks on the boards. This seems to happen alot as do faulty capacitors. Coolant leaks will be located on the chassis directly under the tubes they can cause corrosion and prevent your set from starting especially in the VS models.
Dec 30, 2007 | Mitsubishi VS-50501 50" Rear Projection...
No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
Sep 09, 2007 | Hitachi Director's Series 65XWX20B 65"...
Please help
If its a rear projection TV. It sounds like the Lamp is shot on the projector, or is going. Look in the back and see if it is lit if it is flickering I would definitely suggest replacing it. If that doesnt repair it then I would ultimately suggest the optical engine which is the projector of the TV
Jan 30, 2007 | Mitsubishi VS-5075 50" Rear Projection...
Mitsubishi VS-50705 50" Rear Projection Television Logo
214 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
