Question about Panasonic KX-FPG391 Plain Paper Thermal transfer Fax
Won`t print out fax.
How do i get the fax when the machine well not print it out?
    Problem Solver:
  • 8 Answers
Can you not forward it to your mobile or E-mail address?
Posted on May 09, 2009
Fax won't transmit or receive
you need to flush the memory of the fax in the settings, some faxes machines depending on the grade or type can hold between a few MB up to 64 MB or more with expansions. Corporate photocopiers or bigger machines have an internal hard drive to store the data.
Just go through the settings and look for something that will let you empty the logs of the faxes that were received and send.
Also most of the all-in-one machines have a web interface if they support Ethernet (network) connection where you can perform those task in a more easier manner.
Feb 26, 2013 | Canon imageCLASS MF5730 All-In-One Laser...
Brother fax machine MFC 495 CW won't print a received fax
Hello sir; would you try on another phone jack if still have same problem then replace phone wire.
Nov 01, 2012 | Brother MFC-495cw Color Inkjet All-in-One...
The black ink won't work even though its new
check if the noozles are on the catridges or on the independent print head. if the print head is seperate from catridges, them try print head cleaning. if you it cant work. then dip the print head in hot water for 5 to 10 seconds. dont dry it just put it back into the printer and try again immedeately. let me know if your problem is fixed
Jun 24, 2012 | Brother MFC J6510DW - Multifunction fax /...
Printer says cant print until cyan ink is replaced. Have replaced it with 2 different cartridges, but still wont print
You won't be able to print if one of the cartridges is out of ink. The printer will prime every once in a while thus the need for all cartridges to have sufficient ink levels to prevent damaging the printhead.
May 29, 2012 | Lexmark Interpret S405 - multifunction ...
Won't print
take the toner out and swich m/c off and on put it back and test unit
Mar 04, 2012 | Brother IntelliFAX 4100 Laser Fax
Brother mfc-7840w won't receive fax
The first thing that I would try multiple people to ask them to fax you.Sometimes the 2 machines don't "sync".This is a toll free fax test number that I always use to check my machines..1-888-473-2963.Just write the words "FAX TEST" in large letters on a blank sheet of paper..fax it to that number...leave the line open...you should get a fax back in about a minute.If you get a fax back...your machine is fine...let me know if this was helpful....thanks.
Dec 14, 2011 | Brother MFC 7840W Printer
Have a Samsung SCX 4521F printer scanner machine. Toner is full but won't print when trying to photocopy....will print if something is faxed. The bulb doesn't seem to come on when it starts to...
push menu and # 1943
the fax will go in service mode
push menu again and scrolle until you get new cartrige
push ok
then swich the machine of and on
and it will work
Jul 13, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Hi my canon fax-jx200 keeps coming up recorded in memory..How do I retrieve it?? Many thanks, Lorraine
Hi Lorraine,normaly with this fax it have a auto print off setting that keep the faxes in memory.You can turn auto print to on by pressing the on/off button once less than a second,then it will switch to auto print on.
Let me know if you dont succeed.
Dec 03, 2009 | Canon FAX JX200 Fax / copier Plain Paper...
BLANK PAPER
If you receive a fax with blank pages , nine times out of 10 the answer is that the sender fed one or more of the sheets into the fax machine upside down or backward. You can confirm that this is what happened by noting whether the header (lines of sender information) is present.
You could also be experiencing a technical or mechanical problem, such as a need to fix or change parts. You can test whether your machine can print at all by using its “copy” function, or print an activity report. If all is well on your end, the problem must be with the sender’s machine.
If, by any chance, you’re using an old thermal fax machine, check to see if the roll of paper has been put in backward, because if that’s the case the heads won’t print on the side that isn’t heat-sensitive.
Thanks for using Fixya.
Apr 16, 2009 | Office Equipment & Supplies
Panasonic KX-FPG391 Plain Paper Thermal transfer Fax Logo
109 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
