Question about Samsung SyncMaster 214T (Silver) Monitor
Red stripes on my monitor
Hey. SyncMaster 214 t 3 years old. running whit gforce 8800 gtx. screen text flickers a bit in startup window before windows turns on. it also has small dots of green all over the scren. Windows will not load unless i runn savemode. and when windows is loaded in safemode the screnn has red stripes all over from topp to bottom. What i did was deactivate the gforce, then reboot. all the errors are the same here, except now windows loads in normal startup. now runing on standard vga and still there are red stripes on the screen. tested all fans and they work. main question is does this look like a monitor or gfx card issue? or somthing else!? your sincerly André Strømsten Norway
    Guru:
  • 830 Answers
This looks like a driver issue. Could be incompatible with a software you have installed or bad install.
Use a generic VGA to unintsall and reinstall driver for new card. Turn off computer and then install the new VGA. This should work.
Posted on May 09, 2009
Screen flickering on windows 7 boot
This is more than likely an issue with the monitors themselves. Does this happen on the main monitor is you move the secondary cable over to it? What kind of monitors are you using, how old are they, and do you know the refresh rates on them?
Nov 21, 2013 | Nvidia Computers & Internet
Blue stripe across the monitor syncmaster b2230
Your monitor has a 3 year warranty through Samsung. The issues you are having indicate that your video control board in the monitor is beginning to have issues. You need to get an RMA to have it serviced before the warranty runs out.
Jul 20, 2012 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung LCD monitor (SyncMaster 710v) displaying white stripe.
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Jan 21, 2010 | Samsung SyncMaster 172N 17" LCD Monitor
SyncMaster 213T Screen quality
did you try change the VGA cable? if not, try it.
Dec 19, 2009 | Samsung SyncMaster 213 T 21.3" LCD Monitor
Red stripes on the screen when choosing a 1280 x 1024 resolution and 32-bit color depth.
640 x 480 resolution means that the screen is 640 pixels wide by 480 tall, ... With the exception of one resolution combination (1280 x 1024 uses a ratio of 5:4), ... A black and white monitor uses 1-bit color depth (2 to the power of 1): ... 5 bits for red, and 6 bits for green, giving 32 different intensities for ...
www.thescreamonline.com/technology/.../monitor_res.html
Dec 06, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Palit 8800 GT 1GB screen problem
This certainly sounds like the card is over heating, 120 celcius is way to high for the card to be working as mine is the 8800 GTX and runs at 60 celcius at the most. The blue screen just confirms this further as windows will do that to stop it from getting too hot. I would make sure that the fan is working properly on the card and if it has dust in it or anything like that then remove it and try again.
May 16, 2009 | Palit Microsystems GeForce 8800 GT,, PCI...
Samsung 214t syncmaster flickering
It sounds like you have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of the monitor. If you aregood at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should workfine.We just posted a repair guide showing how to remove the case ansreplace the parts. The capacitors do need to be installed with thecorrect + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Apr 22, 2009 | Samsung SyncMaster 214T 21.3" LCD Monitor
Vx2235wm lcd flickers a bit then turns white
White screen is an indication of a faulty video board.
A blown fuse in the actual screen will cause the same effect but usually these do not reset on a fresh startup.
You can check the ribbon going from the video board to the back of the screen to see if it is somehow working loose, but I think based on your description that this isn't the problem.
ebaysbammbammfran
Oct 07, 2008 | ViewSonic VX2235wm LCD Monitor
Black Out
Hi Detrix, Check with www.lcdrepair.net if you want a repair. Something is wrong with your LCD controller and or GUI interface circuit or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. These circuits take the Signal from the computer and controls the 2.5 million pixels on the LCD screen. Dsut can cause major problems with handling all that data. Give it a shot, what do you have to loose, its not dangerous if the monitor is unplugged.
Oct 09, 2007 | Samsung SyncMaster 193P 19" LCD Monitor
Samsung SyncMaster 214T (Silver) Monitor Logo
508 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
