Question about Car Audio & Video
No identification of wiring color code
I received this radio from friend with no idea what the wire color code is. Trying to install in my boat and no idea what to connect for what.
  • bullridersro May 18, 2009
    To jsinsorrow: Thank you for the wire color info. Connected as per your info and everything works fine. Much appreciated. Bullrider
  • jsinsorrow May 11, 2010
    most radios have a black wire for ground, a single yellow wire for power, a single red wire for switched power (only has power when vehicle is on) and dual grey wires, dual white wires, dual etc. for speakers. the single blue wire is for remote accessories like an amp or eq.
    Scholar:
  • 80 Answers
Usually it's....
black = ground
red = switched battery power
yellow = constant batery power (for clock...etc)
orange = illumination
blue = amplifier turn on or accessory (electric antenna, amps etc)
green/white/purple/grey are speaker wires.
Posted on Jun 12, 2009
My hg-m84mic has white green red yellow wires how can i figure out the functions of them to a stryker 655
first you must get the color code of your radio,second you must figure out the audio color,receive color, transmit,switch color. it should be easy the internet is your friend use it!
Feb 13, 2015 | Cobra HG-M84W CB Microphone
I'm installing the Pyle plcd33mr in my 1996 rinker 180 boat and the wireing harness on the stereo does not match up with the boats. How should I go about fixing this
The trick is find the adapter which plugs into the original radio's harness. In the automotive world, these adapters are vehicle specific and readily available. The adapter plugs into the original radio's harness and the wires on the adapter are the same colors as the wire colors on the new after market radio's plug. So it's a matter of connecting yellow to yellow ,etc.
I was unable to locate adapters for boat radios, or radio pin outs . I would think they are available as the automotive adapters are.
I suggest you go to a local marine supply store and ask if they carry radio adapters for after market radios. You can also try doing a web search. It may work if you can come up with the name and model number of the original radio in the boat, and try a search using that info....
Jun 01, 2014 | Car Audio & Video
Radio won't play
There may be differences between the color coding of the adapter wires and the color coding of the vehicle. Check to determine whether the wires were functionally matched, not just matched by color. Check for missing or poor connections
May 07, 2013 | Dual Electronics XD1222 Car USB Player
I got a 1998 ford expedition eddie bower and im trying to install a radio i just bought and i need to know the colour coding from the car eglike power wires and speaker wires
just get the harness kit from a sound shop/bestbuy/walmart. it plugs into your car harness and has wire colors that match all the wires on the radio. it makes it fool proof and a breeze.
Oct 07, 2010 | Car Audio & Video
Car radio stolen, harness cut, have replacement radio, need pin Identification for installation.
email me at iambanshee74@yahoo.com. I have diagrams I just can't send them through here. Which radio did you have?
Feb 27, 2010 | 2002 Dodge Intrepid
Installing newer radio in older truck
Hello zachary_reed,
What you need is an aftermarket wiring harness. These are made by Metra, Scosche, and others and are made to plug directly into the OEM radio harness. It appears that the one you want is the Scosche FB02B available from SonicElectronix. You simply connect the wires from your new receiver to the harness wires and then plug it into the factory radio plug. Another online retailer that sells aftermarket harnesses is www.crutchfield.com. Your local car audio shop or perhaps Best Buy may also have the wiring harness.
Be sure to match up the wires from your new radio harness to the aftermarket harness by FUNCTION, not by color. For example, most newer receivers will use Yellow as the 12V constant (hot) wire. The wiring color code for your F150 is shown here. Make sure that the pin on the aftermarket harness is connecting the yellow from your new receiver to the green/yellow of the OEM plug and so on.
Hope this helps.
Jun 09, 2009 | Pioneer DEH-1100 CD Player
Identification of original wiring to car radio/stereo
no wiring diagram needed go cut a plug from a junk yard and wire it into the cut wires then buy the adapter kit for you car and wire that to the car plug and the radio plug.
Mar 19, 2009 | 1986 Honda Civic
What color is what on the clip coming out of the bak of the deck.(power,ground, left/right front spkrs, etc?
Good Day,
Good Day,
Red is ignition
Yellow is constant hot (you can wire red and yellow together if you don't have a constant however the radio will loose settings each time the boat is turned off)
Black is ground
Gray wires are front right
White wires are front left
Green wires are rear right
Purple wires are rear left
Blue is power Ant
Orange is ilumm
Hope this helps
Jul 07, 2008 | Sony CDX-CA850X CD Player
Wiring Diagram
If you could post a clear picture of the back of the radio where the plug goes in I might be able to help you. I need to see the number of pins, their configuration and the shape of the socket. It wouldn't hurt to see the colors of the wires in the plug too.
Jun 07, 2008 | Car Audio & Video
I am having trouble trying to install a stereo to my 1994 lincoln town car because i dont now the color code to the radio harnes so i can install it
Best thing to do is purchase a Radio Wiring Harness. These can be purchased at a Store like Circuit City, Best Buy, WalMart (not sure of your location) or a 12 Volt Specialty shop.
This harness will connect to your new radio harness and plug directly into the vehicle harness without having to cut wires. The Radio Wiring Harness will come with color identification to match to your radio harness.
FYI http://www.installdr.com/QuickWiring.html
Jan 12, 2008 | Car Audio & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
