Question about Danby DPAC8020 Air Conditioner
I can't figure out where to drain the water from on the Everstar Portable A/C unit, and don't know what tubes everyone else is talking about. Can someone walk me through this process from scratch? Thanks.
  • paularobledo May 10, 2009
    Before I read your reply I finally figured out where the drain tube is located, and it certainly didn't look like that would have been a drain tube (so now I know I'm not an idiot, LOL). So I took the cap off of it and got a lot of water to come out just by taking it off, and I let it drain into a bucket. However, because I was tilting the unit, a lot of water also came from the bottom of the unit and onto my carpeting. But I still couldn't figure out where the drain pan was or how to empty it, and figured this has to be why it's "leaking" from underneath when I tilt the unit. So now I'll try taking off the front door as you've suggested and see if the drain pan is behind it and hopefully get this thing to start blowing the really cold air it used to. I also cleaned off the dusty areas behind the grates all the way around the unit, figuring this would help aid in the air flow, and it seemed to help a little bit (I have several dogs here, so that stuff piles on there pretty quickly). I just wanted to let you know what I've tried so far and say "thank you" for getting back to me at all, let alone so quickly, and for offering me free advice for what my problem is with this A/C unit. It seems nobody wants to give anything away for free anymore, even advice, so this has been a refreshing change of pace. If I can offer you any free assistance with any dog issues, please let me know (I did rescue for 8 years, and by osmosis have gathered a LOT of knowledge about them and their behaviors and such). Thanks again, and I'll let you know if your solution fixes my issue.
  • 22 Answers
The water bucket is usually located behind the front door. The door is usually held on by snaps or magnets and is hinged on the bottom or side. A hose from the condensate drain pan to the bucket carries the water. Try pulling on the top of the bottom door or each side. It may be a bit tough,but don't pull so hard that it may break. If it is not there, consult the owner's manual. When the bucket fills a switch will turn the cooling off. Ron
Posted on May 10, 2009
  • Ronald Walden
    Ronald Walden May 10, 2009
    I rented and sold commercial grade portable a/c's for about 2 years and they either had a bucket or a pump for the water to drain into. I'm not familiar with your model but if it doesn't have a bucket I guess they assume you're supposed to provide the bucket (odd). As for the dog hair - simple solution: clean the coil very well, measure the size of the coil and tape a CHEAP BLUE fiberglass filter over the coil. DON'T use use a high performance pleated filter as it will overly restrict the air flow to the coil. When the filter is starting to get filled, either put on anther one or simply take the filter outside and shake it as necessary to get it reasonably clean and put it back on. I wish you had experience with cats as I have a 4 year old that since I moved back to Orlando he has started losing his beautiful fur. I've tried the Advantage, BioSpot Dip, cleaned the ears - still losing fur. :( One way you can help me it to rate my answer by clicking on the little books at the top right. Good luck! Ron
Is there a tube in this unit that forces the water to the side bucket
They have a hose inside that could off undo the back and have a look.
Aug 13, 2014 | Everstar Portable Air Conditioner Everstar
Why there is no cold air?
The compressor is not coming on and cooling the evaporator coils. It could be due to loss of refrigerant or something else.
Jun 05, 2014 | Everstar Portable Air Conditioner Everstar
My Everstar portable air conditioner model# MPK-10CR-1 will not drain into the bucket that comes with it. It is draining into the tray at the bottom of the unit then the unit turns off when the tray is...
Simple I believe...just run a weed eater line up the whole in the back where you have the clear tube. You can take the little back door off the power cord area to see inside where the water drips into the little tray before it goes down the hose tube. Water debris sometimes blocks the water from draining properely. The weedeateer line will clear the blockage and it will begin flowing again.
Jun 27, 2010 | Heating & Cooling
Does the unit suppose to retain the water?
No. The unit is not supposed to retain water. By product of a/c or
refridgeration is water due to air being cooled below dew point of air.
(Check your uninsulated cold water pipes on a hot, humid day. They
are usually sweating.) The tubing should be routed to drain or outdoors.
Jul 24, 2009 | GE APH10AA Air Conditioner
Need owners manual for Everstar Portable AC MPM1-10CR-BB6
Needed the manual to clarify a P1 error message. Figured how to fix the error P1 on my own. there are two drains on the unit, one is always open as an overflow drip, the other at bottom of unit has a plug. I opened the plug at the bottom of the unit, drained the water, and the P1 error code cleared.
Jun 25, 2009 | Danby DPAC8020 Air Conditioner
Don't know how much water to use
Do not put any water in the unit, the water that is in the unit drawer or bucket that is attached to the hose is a byproduct of the air conditioning process.
It transfers heat to cold and in the process produces condensation = Water.
May 30, 2009 | Everstar Portable Heater/Fan
What is the P1 error code on an Everstar portable A/C unit?
U need to empty the internal bucket, its full of water.
I have this air conditioner. What I did was get a long plastic tube from home depot and connect it to the middle back drain. I then put the plastic tube outside my window, or if u have a drain somewhere put it in there or put the end into a big bucket. Let gravity do its job. I did not connect the tube to the internal bucket b/c I would have to empty it too often. The air conditioner is on top of a table so that water will flow down the tube and out the window.
May 09, 2009 | Danby DPAC8020 Air Conditioner
Everstar portable ac unit displaying error message P1. The unit turned itself off and will not come back on. It had no symptoms of not working well before turning off.
According to my Everstar manual, P-1 is a drainage problem.
EverStar owners manual pg. 16 -
1. Release the drain hose from the ruber clip and pull out the rubber plug, let the drain hose slant down to a water container.
2. Press the TURBO button on the unit control panel for more than 3 seconds and the WATER INDICATOR light begins flashing. It indicates the forced water drainage feature is activated.
3. Waiting until the WATER INDICATOR light stops flashing and there is no water flow.
4. After the water has drained, remember to secure the drain hose and plug in the upright position and clip it to the unit.
The unit will return to normal operation.
....I had to do this and it worked - Good luck!
Mar 25, 2009 | Heating & Cooling
Danby DPAC8020 Air Conditioner Logo
475 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
