Samsung 22'' lcd screen turns on see something for half a second then turns off tried to hook up different computer same problem had two hooked up tot the same computer and same problem on both screens two weeks apart
    Problem Solver:
  • 16 Answers
I have had 3 Samsung monitors do the same thing. Before you call Samsung, completely disconnect the monitor from all computers, then power it on. If the monitor is okay you will get a screen that will say something along the lines of "video source not found" in what I believe will be a blue box on the screen.
If you get nothing the internal boards are bad and it is time to send it back to Samsung. Go to Samsung's website, if you have not registered the warranty then do so, you will need the cash register receipt or the invoice from where you purchased the monitor -- you have to send an electronic copy to Samsung to register the warranty. Once registered begin the RMA process. If the monitor is within the warranty period Samsung will actually UPS a replacement montor to you. The process is simple, you go to the UPS Store unpack the replacement, put the sick monitor in the box from Samsung, UPS puts on the prepaid preprinted label, you go home with good monitor and the sick one goes back to Samsung.
Posted on May 10, 2009
Sharp aquos won't turn on
if it was a new tv you can ask the supplier for check up it was covered with warranty.
Sep 22, 2012 | Sharp AQUOS LC-22SB28UT 22" LCD TV
When i come back to my sync master 2233rz monitor after leaving it alone for atleast an hour, half of the screen goes bezerk and the only way i can fix it is by restarting my system , please tell me what i...
Hook a spare monitor to your computer, if okay! the problem is in the SynMaster, but if both show the same it indicates a video graphics card problem in the computer, Hook your SyncMaster to the computer and change the video cord from the computer to the monitor just to be sure. If no change! it is time to replace the monitor "the LCD panel is defective" not cost effective to repair.
Mar 23, 2012 | Samsung SyncMaster 2233RZ 22 inch 3D LCD...
Monitor turns off by itself during normal usage.
There are a few things you can try in order to narrow the the cause. First there's the easy outside-the-PC stuff such as:
- hook up a different power cable
- hook up a different video (VGA/DVI) cable
- You can always try switching to the other type of cable (try VGA if you're on DVI and vice-versa) to see if that makes a difference, assuming your monitor as both connectors.
- try connecting same monitor (and power/video cable) to a different PC for a day and see if it turns off there as well.
- For that matter connecting a "known good" monitor to your PC to see if that monitor also acts that way on your PC.
On the software side you can disable the power management features related to the display to see if that makes any difference.
If you were to connect this to a different PC with a different VGA/DVI cable and power cable and it still did it that I would say it's probably the monitor itself (unless the PCs were identical or something and under control of the same domain policies or some craziness like that).
At some point you probably want to call the manufacturer and see if an RMA is an option. I would recommend trying some things before that though. I hope this helped!
Jun 02, 2010 | Samsung SyncMaster 2220WM 22" LCD Monitor
Samsung hdtv scrfeen half black half res
Sounds like the color wheel is not turning properly. I would recommend calling 1-800-samsung to set up repair with an authorized service center. I would not try to replace it yourself. The part costs $120.00- $180.00.
May 26, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Lower half portion of the horizontal screen black
hi rafi,
check if problem occurs with another computer, hook up another monitor to your computer to check if your graphic card is making trouble.
if it the monitor, and it still is under warranty and you did not damage it, just return to place of purchase and let the paid pros work their magic1
Good luck
Sep 07, 2009 | ViewSonic VA2226w 22" Widescreen LCD...
Monitor stops showing desktop
probably needs new voltage regulator for backlight. it would probably be cheaper to just buy a new monitor
Aug 14, 2009 | Acer 22" X223w LCD Monitor
Not optimum mode recommended mode 1024 x 768 60hz
Hook up a different monitor and set resolution to no higher than 1024 x 768. Samsung monitor will then work fine. It appears that something fails in the monitor and it will no longer support anything higher than this.
Mar 03, 2008 | Samsung 710V 17" LCD Monitor
Computers & Internet Logo
204 people viewed this question
David Payne
David Payne
