Question about Garden
Need to know the head bolt torque for Craftsmam Pressure Washer
Need to know the head bolt torque for Craftsman High Pressure Washer model# 580.752410
7.0 horsepower
2900 PSI
2.3 GPM
Model Number 580.752410
  • 7 Answers
SOURCE: oil leak under the engine
If it is a vertical shaft engine then it is most likely the crankshaft seal. That requires removing the engine from the frame and removing the pump from the motor to replace the seal. If it is a horizontal shaft engine then it could be either the shaft seal or the side cover gasket. Both require removal of the pump.
Posted on May 02, 2009
blueextc3221
  • 15935 Answers
SOURCE: Craftsman 2000 psi, 1.9 gpm pressure washer Manual
The model number is required to get the correct manual.
The Model Number is on the motor tag.
It is in the format XXX . XXXXXX
Where X = a number.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 31, 2009
  • 61 Answers
SOURCE: troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Posted on Sep 20, 2009
  • 760 Answers
SOURCE: what typ of gas do i use
Regular gas 87-89 octane works fine.
Posted on Jul 14, 2010
  • 1388 Answers
SOURCE: I have a Craftsman (B & S) pressure washer 7
I worked at a tool rental store while attending college and discovered how to extend the life of tools. Really a simple trick that you practice every day. Although your car can travel at a very high rate of speed, you only use about 30 to 40 percent of its power, if however you traveled at 100 mph everywhere that you needed to go, you would greatly shorten its life. Althouth I do believe that you have received good service from your unit, you may have increased the life by using only 60 to 80 percent of its pressure potential for most general work and increase only for stubborn debris.
Posted on Apr 26, 2011
Testimonial: "Many thanks for the suggestions. Dave B"
Need to know what is the pattern to snug bolts on head gasket
criss cross, corner to corner. More important is the torque settings.
Oct 02, 2015 | Craftsman 675 Torque 190cc 21" Briggs ...
What are the tightening torques of all clutch plate pressure plate flywheel bolts of 2279cc slant engine vauxhalls
I have some original manuals for the model somewhere and the Kent-Moore service tool for adjusting the valve clearances. There isn't much information in my general data book but the flywheel bolts are 66 Nm.
The clutch cover bolts do have a torque value but I don't have it to hand and have never used it or heard of anyone using it. Good sense will suffice.
The important thing is to tighten the cover bolts a little at a time evenly until tension is felt and then it is sufficient to "knip" them a little further. There should be a spring washer under each cover bolt head and it is important they and the bolts are all identical
Mar 04, 2015 | Cars & Trucks
Headbolt tension
Hi Belinda, I am not sure what you are asking for when you say headbolt. If you mean cylinder bolt, jug bolt or head bolt then
approximately 125 inch pounds.. not foot pounds!!!
This image I found for a Poulan chainsaw site, Poulan makes most of Craftsman saws. If you match the size you should find your torque setting.
jeromekj
Apr 20, 2014 | Craftsman sears 18" Chain Saw Chain (...
Im replacing the cylinder heads on my 2000 mitsubishi montereo with a 3.0 v6 I need cylinder head torque specs and torque pattern and I need to know if I need to seal the threadx on the cylinder head bolts...
98_mt00sport_11a-030c.png&width=384&height=480&displaytype=display&imgrotation=&links=
Tighten head bolts with the bevel side of the washer facing up in 3 steps to 80 ft lbs. (first pass 40 foot pounds of torque, 2nd pass 60, 3rd and final pass 80) Clean and lubricate the threads and washers of the bolts with motor oil, no sealer needed.
Dec 12, 2013 | Vehicle Parts & Accessories
Bolt torque sequence on 1991 jaguar xj6 4.0 intake manifold?
intake manifold or head gasket? i know head gasket need a sequential order followed by how many degrees and Lbs of pressure. if its on the intake i doubt it needs an specific torque. just try not to crack the intake manifold since its made of plastic.
Oct 29, 2012 | 1991 Jaguar XJ6
Husky model VT631502AJ head torque specs
I am certain there are torque specifications but I don't know what they are. You might be able to get them from the manufacturer. Lacking that, determine what the bolt strength (usually indicated by marks on the bolt head) and with the bolt strength and size you can determine what the appropriate torque would be for that size bolt. Too little torque and the head will leak. Too much and you will strip out the threads or twist off the bolt head. A 13mm head is nominally a 1/2", which is not a very large bolt head thus the bolt shank is not going to be particularly large, probably somewhere in the 7 to 9 mm range. Check online for torque specs. If you can't identify the specific bolt strength I would assume it is the lowest normal value for that size bolt. There shouldn't be any particular reason for using high-strength bolts in this type of application.
Aug 03, 2012 | Air Tools & Compressors
How do I determine how much torque my impact wrench makes?
I test my impact wrench on a good vice and with a high grade steel nut/ washers and bolt that can take high torque. Select bolt with thread almost to the head. Hold head of bolt on solid vice and place two washers(more if needed to reach into threaded area) and nut on bolt. Set air pressure to max (I have 125psi). Run nut against bolt head with impact. Remove nut with torque wrench for reading. This low tech method will give you a rough idea. Higher pressure may give you better result. If you have used your air wrench for a while. Clean by adding diesel fuel into air fitting. Little at at time until diesel comes out rather clean. Then add a few drops of oil. Then test again. Good luck.
Aug 17, 2011 | Craftsman Tools 1/2" Air Impact Wrench...
Cylinder head torque specs
Cyl. Head Bolts torque
200in.lbs
16.5ft.lbs
22.5Nm
Mar 26, 2009 | Craftsman Garden
Air leaks between head and cylinder
either the head gasket is gone or the rings are shot
Mar 04, 2009 | Air Tools & Compressors
Garden Logo
69 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
