Question about Aluratek AUS0202 - 2-Port USB 2.0 Printer/Peripheral Auto Sharing Switch
CAn't print on one PC
I can't print on one PC with this swithc but can with the other.  Not cables or the color laser I'm using. I get the message about an unkown USB device in the system tray.  Do you know of a way to get the PC to recognize the switch?
First you have to install the drivers for the switch and then you need to install your printer driver using the switch as your port ... I'm assuming you have the driver CD for the switch
Posted on Mar 09, 2008
Are you sure it is not recognizing the switch?  Just a thought, but maybe the other computer has not loaded the usb drivers for the printer.  Have you connected the printer directly to the computer to see if you can isolate the problem?
Posted on Oct 12, 2007
Laser printers / Ink Jet printers the difference
Depending upon what you are printing and how you want it to look. Also cost is a factor. We sell new and used printers at our storefront. If you are printing items you do not want to smear if they get wet - Go laser. If you are printing photos on photo paper - Go ink. Some people fail to tell you when selling a color laser jet printer that when you are are printing just black, you are also using each of the colors a little. Toner is the lubricant that keeps the drums from squeaking on the blade as the drum inside the cartridge turns. The buildup of excess toner in the waste container may cause the cartridge to fail though you have only used a little in the cartridge. Laser and Led printing black only is the most efficient way to print. We don't usually recommend color laser printers unless that is all you are going to print are full color documents. Color can be expensive. Inkjet is more expensive to only print black with. While if printing color, it is less expensive than laser. If you need more information please ask!
Jun 03, 2014 | Computers & Internet
Hp deskjet D2600 series cant print but new ink
If printer power swithc blinking after the instalattion cartridges it should be cartridge circuit error.
One solution is
just clean the cartridge circuit use a tissue paper. dont use water.
swithced offf and then on. make it print.
check ur data cable. may be thts complaint. try to use another data cable.
restart ur computer.
Jun 15, 2011 | HP Office Equipment & Supplies
HP Color Laser Jet CP2025. Replace Supplies message on screen and can't get it off. Put in a new print cartridge. Message still won't go away. Please advise how I can get a User Manual for this...
HP Color LaserJet CP2025 - "Replace Supplies" message.
black cartridge is blinking. Printer won't print and message will not go away. Any suggestions?
Nov 09, 2010 | HP Office Equipment & Supplies
My SCX-4521F Scanner is not working. "System Cannot Found" - Message pop-up on my PC whenever I tried to do scanning. An unknown characters appeared on my Samsung All-in-One Laser Printer every time I do...
1. Reconnect the PC and printer, replace any faulty
cables. If using a parallel cable, check that the parallel
port is properly configured in the BIOS.
2. If printing is OK check that the Scan driver is also
Oct 03, 2010 | Samsung SCX-4216F All-In-One Laser Printer
HP 1600 color laser printer--colors are out of sync
Check the following information please.
General print quality issues
Solving issues with color documents This section describes issues that can occur when you print in color. Color document issues Problem Cause Solution Only black is printing when the document should be printing in color.
c00659983.gif Color mode is not selected in your program or printer driver. Select color mode instead of grayscale mode. The correct printer driver might not be selected in the program. Select the correct printer driver. The device might not be correctly configured. Print a Configuration page.
One or more colors are not printing, or are inaccurate.
c00659984.gif Sealing tape might be on the print cartridges. Verify that the sealing tape has been completely removed from the print cartridges. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The device might be operating in excessively humid conditions. Verify that the device environment is within humidity specifications. One or more print cartridges might be low. If you are using non-HP print cartridges, no messages appear on the device control panel or in the HP Toolbox. Replace any low print cartridges. The control panel is set for override. Replace low or empty print cartridges. A color is printing inconsistently after you load a new print cartridge.
c00659985.gif Another print cartridge might be low. If you are using a non-HP print cartridge, it might be low or empty but you will receive no indication. Remove the print cartridge for the color that is printing inconsistently and reinstall it. The control panel is set for override. Replace low or empty print cartridges. The colors on the printed page do not match the colors as they appear on the screen.
c00659986.gif The colors on your computer monitor might differ from the device output. Select Screen Match in the Color tab of the printer driver. If extremely light colors or extremely dark colors on screen are not printing, your software program might interpret extremely light colors as white or extremely dark colors as black. If possible, avoid using extremely light or extremely dark colors. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The finish on the printed color page is inconsistent.
c00659987.gif The media might be too rough. Use a smooth paper or print media, such as a high-quality paper that is made for color laser printers. Generally, smoother media produces better results. Repetitive image defect ruler Use a repetitive image defect ruler to measure occurrences of repetitive image defects to help solve image quality problems. Place the ruler next to the first occurrence of the defect on the page. Find the distance between identical defects and see the Repetitive image defects table to identify the component that is causing the defect. Repetitive image defects Measurement Component 24.7 mm0.97 inch Developer sleeve 26.7 mm1.05 inches Charge roller 32.9 mm1.3 inches RS roller 37.7 mm1.48 inches Transfer roller 54.5 mm2.15 inches ETB rollers 56.6 mm2.22 inches Fuser sleeve 62.8 mm2.47 inches Pressure roller 75.4 mm2.97 inches OPC
Have a good evening
Jun 18, 2009 | HP LaserJet 1600 Printer
Printing error message: cartridge problem.tri-color.I wasn't even
its becoz even if ur print contains only black text in it, while printer printing in black it needs a cyan or yellow ink to give very clear print out. work around for this issue, go to the printer icon and right click and go printing preferances and change the option to print only in blak or print only in gray scale. it should resolve ur issue............
Regards,  raj_p5983
Jan 21, 2009 | HP OfficeJet J4580 All-In-One Laser...
"Please change PC Drum" message appear on printers LCD
If your print job prints ok, ignore it. Just bear in mind you'll need a new drum soon. The drum is a light sensative roller that ink from the toner cartridge adheres to where the laser hits it. When it is no longer magnatized enough to hold the toner you'll see your print jobs start to lose that toner color. Just pull the drum out, buy a new one and put it in. Just don't expose the drum to light very long.
Oct 24, 2008 | Minolta Di2510 All-In-One Laser Printer
Messege: Yellow Cartige is low
You can specify that a print job prints in black and white in the properties screen when you print something. You may even be able to save it as a default in the printer driver default printing settings. Unfortunately I've never seen a colour laser be able to ignore it's color cartridges before, you may be forced to replace that empty cartridge.
Oct 25, 2007 | Lexmark C510 Laser Printer
Brother mcf7220 will not print..says "cancel printing" "job cancel"
firest you swithc off all the printers and wait for some minute then clear all printers queue by going in to printer folder then restart your system.
Sep 01, 2007 | Brother MFC-7220 All-In-One Laser Printer
Aluratek AUS0202 - 2-Port USB 2.0 Printer/Peripheral Auto Sharing Switch Logo
201 people viewed this question
Top Aluratek Computers & Internet Experts
Don Hart
Are you an Aluratek Computer and Internet Expert? Answer questions, earn points and help others
