Question about RCA 32V420T 32" TV
RCA 32V432T My tv has an excellent picture, good sound. The problem is trying to turn it on. When you turn it on is shows a sunburst of colors and then cuts right back off by itself. It takes anywhere from 10 minutes to a couple of hours to get it on. When it finally comes on it has an excellent picture. Do you know what could be causing this.? Thanks.
techman
  • 3130 Answers
SOURCE: TV turns off by itself, juggling power cord causes TV to come back on
It could seem to be a power cord problem But when you move around the cord you are realisticly flexing the printed circuit board assy. If you know all the safety issues around the servicing a solid state tv, then Of course I will assit you, in any way I can, But you must be aware of the high voltage that these sets store , even if they Are unplugged. Its a total safety issue. If you have no experience using a multi- meter as well as the safety issue awarness, then PLEASE seek a pro to assist you with this reapir, as it will get worse in the long run and cost ya more to fix, as everytime you move around the cord and the set shuts off, then goes on , your surging the componets!. Good Luck
Posted on Jun 19, 2006
  • 1694 Answers
SOURCE: RCA 32" TV - Model #32F531T - Faded to black
Isolate filament voltage from CRT,i.e. unplug Crt socket from pix tube.Measure filament voltage on CRT PCB.If present,suspect bad pix tube.If missing,solder any/all connects in filament circuit,meaning CRT board first then main PCB.
Posted on Oct 02, 2007
  • 317 Answers
SOURCE: RCA 32V434T Flashing Red Light
Flashing led..in protect mode..internal shorted component.
Posted on Aug 14, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: rca tv model 32v432t
This set is not digital tuning and you would need a converter for off-the-air reception. You can get full specs and manual downloads from RCA's site:
http://tv.rca.com/en-us/productdownloads.html?MN=32V432T
Posted on Dec 18, 2008
muttandjeff
  • 359 Answers
SOURCE: TV power light comes on but no picture/no sound
chip on ic board repair shop might replace it and reprogram if the tv is worth the fix
Posted on Feb 06, 2009
Rca 32" 32v432t
What is the problem with your RCA TV? Provide some more details, please.
Jun 23, 2012 | RCA TruFlat 27F520T 27" TV
I have two RCA 32v432t tv one want power up and the fuse is good I see no burns on the board and no burn smell and every shop i call say it's cheaper to by another one is it' ?
This sets just dont hold up. CK hori output transistor and Bad FBT flyback Transfomer.
Also try with TV off Press and hold CH- VOL- at same time and see if TV will try to come on.
Dec 27, 2010 | RCA 32V420T 32" TV
I have a 32" RCA 32V432T TV that only shows snow now. I've checked everything externally but still no picture. Any solutions?
There could be several things that can cause this: 1. There are no analog channels in your area. 2. Check the menu setup and verify that you select the proper input (antenna, cable, etc). 3. The TV tuner is defective Try using the composite input on the TV (there are normally 3 jacks per input). Yellow for video and red and black for audio. If you dont have the proper cable, pick one up in you local 99 cent store or an electronic store.
Connect the "output" of your device (VCR, cable box, Tivo, dvd player, etc) to the "input" on the TV. Then use your TV remote to select the proper input.
Hopefully this helps. Good luck.
Sep 27, 2010 | RCA 32V420T 32" TV
I have a RCA 61" d61w20b, i can turn on the tv and the sound is good but the picture is not right it bows and distorts the picture, it shows the picture in three colors green, red, and blue could it be the...
What you most likely have is a convergence problem. The convergence circuitry is used to align your colors. What you describe sounds like that circuit has failed. Here’s a link to a decent video that will give you an idea of what is needed to fix it: http://www.youtube.com/watch?v=S6Wa8FvSz-s
Aug 30, 2010 | RCA D61W20 61" Rear Projection Television
Lightning Surge, RCA 32V432T, will not power up
Throw TV AWAY,these tvs had alot of problems without lighting hitting them,It probably played out FBT flyback transfomer CK hori out put Transistor if shorted replace FBT also.
Aug 06, 2009 | RCA D52W19 52" Rear Projection Television
Rca tv model 32v432t
Nov 18, 2008 | RCA 32V420T 32" TV
32" rca picture stretched
Before you fool around with this, it may be under warranty. Check that first. Second, does the picture stretch in both directions or just vertically? If just vertically is it more pronounced at the top?
Thanks,
Dan
Apr 03, 2008 | RCA 32V420T 32" TV
RCA 27F634T
Have you tried to access the menu features and tried to retune the stations on digital, or are you hooked up for analog.
If you don't know about what i speak, give me a yell. jr@excel.net I believe my remote sensor card is bad. While this might explain why you can't turn yours off, it would not explain the blank picture. If the menu does show, i would think the picture tube is O.K. if the menu does not show, there are some other things to look at.
Dec 29, 2007 | RCA 27F634T TV
RCA 32V432T picture problem
Sounds like the Filter Cap is shorting.
Sep 08, 2007 | Televison & Video
RCA 32V420T 32" TV Logo
204 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
