Question about Ricoh Aficio 1035 Copier
Hello sir i have problem in ricoh aficio 1022 image repeat problem. u told me to change hotroller pressure roller baring also i change its same plz tell me where is the problem before fusing copy is ok after fusing its give problem after ten copies thanks
    President:
  • Ricoh Master
  • 990 Answers
Hi sir; No matter who told you to replace, the hot roller is the most possibility, the next item also last item you need to check is drum unit (drum cleaning blade,[replace it ], image transfer roller [clean up by alcohal] and drum [ depend condition ]).
Posted on May 09, 2009
Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Jan 15, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
RICOH AFICIO 401 COPIER- COPIES FADED ON ONE SIDE
Hello sir; You have to replace drum and developer meanwhile you have to clean up image roller, then it will take care the problem.
Nov 06, 2009 | Ricoh Aficio 450 Copier
Aficio 1515MF knocking when printing
Hello sir;Pull out drum unit re-assembly image cleaning roller I believe thatis the problem coming from.
Aug 10, 2009 | Ricoh Aficio SP-C210SF Printer
Light Copy / Prints
Hello sir; Try to clean image roller with alcohol and both end where the ground contact, see what happen.
Jun 02, 2009 | Ricoh Aficio 2018 Copier
I have problem in ricoh 1022 image repeat problem i cheek fusing drum and replace its still same befor fusing copy ok when enter in fusin then its give the problem what i should do tell me
The problem is that the Upper fixing roller needs to be replaced... Most likely the coating on the roller has worn off and the bear metal is exposed and the toner stick to the metal and reprint it futher dow the page.... It could also be uneven pressure with the upper and lower fixing rollers... It may be a broken bushing or ball bearing... Good Luck
May 03, 2009 | Ricoh Aficio 450 Copier
Ricoh aficio 1022 sc 546
problema ricoh aficio 1022 copia en blanco aparece codigo
sc 193
Oct 20, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
On lcd massage
some times the nipple (cover) of the toner stays in the toner holder this wont allow the new one to be opened
Sep 22, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
Infotec IS 2220D Copier (same as aficio 1022 i think) SC551 Error
Start by pressing clear modes, 1, 0, 7, and press and hold clear/stop. enter copy sp, select 7 fot data log, scroll to 7807, and execute. exit all the way out, and recycle the power. See if that does not fix your problem.
Mar 25, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
Ricoh Aficio 1035 Copier Logo
163 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
