Will not train or spin
My washer isn't spinning and f 02 error appeared
  • 460 Answers
I need the brand n modul # to better assist you
Thank you for trust Fixya.com
Posted on May 09, 2009
Wont pump out comes up with E3 on display
CLOGGED WATER PUMP HINDERING DRAIN AND SPIN CYCLE
Jun 11, 2015 | Washing Machines
Code F-02 on hotpoint WT960
Check and clean the filter and drain hose. Make sure the hose isn't kinked.
Apr 22, 2012 | Hotpoint Ultima WF860 Front Load Washer
Whirlpool duet washergets a code 2 when it gets to spin cycle.wont rinse and spin
If the drain time exceeds eight minutes, the water valves are turned off and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the display. NOTE: After four minutes the “Sud” error will be displayed, then four minutes later the “F/02” error code will be displayed.
1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
Apr 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code OF 2 When this error code appears it happens during the spin cycle. I manually switch to the Drain/Spin cycle and change the spin speed to medium and press start. This fixes the problem each...
It sounds like you may have a motor control board issue. It acts like the motors brain and tells it what to do and when. part number 8182706. Also the closet error code i could find is a f/02 which means long drain, which could indicate a bad pump or draining cycle, alos knows as the spin cycle This should definetly be diagnosed by a technician. hope this helps
Thanks
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My hotpoint wt 960 washer doesnt spin towards end
Error code F02 is indicating a motor tacho problem, it could be jammed or have become detached.
Check all connections on motor, plug motor lead , and the control module.
Hope this helps,
Dec 17, 2009 | Washing Machines
Off-Balance Duet Washer
spin basket surport is defective..put unit in spin without clothes do it bang and clang,,sound like train ,or airplane,,if so contact whirlpool your under warrranty for spin basket..onthejob
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Duet washer doesn't run through the entire spin cycle on heavy duty setting. Clothes come out of washer, naturally,WET!!!!!!!!!!!!!! Seems to spin out better on the normal cycle. spin cycle dosent...
displayed.
Possible Causes / Procedure
or kinked.
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
No Spin
Hey, I know it's probably late, but I'm having a similar problem in that it's not spinning and I'm getting an error message of F 02. Did you have this problem? How did you fix yours? Please let me know, I need to wash clothes for my son's prom tonight. Thanks.
Oct 20, 2006 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
110 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
