Question about SVA-USA HD4208TIII-VR 42 in. Plasma Television
Tv won't turn on
My tv clicks like it is about to turn on, but within a few seconds it clicks a second time and never turns on.  Please help.
  • mark mark Jan 19, 2008
    Having the same problem. Where is this faulty relay and how much does it cost to repair. Where did you find the part?
    Thanks
  • Dave7612 Mar 03, 2008
    I have the same problem, I even took the back panel of the display off and as I powered up the relay has led indicator lights that lit up then it clicked off. does anyone know where to purchase these? or what the specs are for the relays? also are they socket or soldered in place
Just Repaired a HD4208-III with the same problem, found faulty
Relay RLY8002 (Faulty Contacts) Replace both RLY8001 &
RLY8002.
Regards
Patrick
P-Tronics
Adelaide
Posted on Dec 10, 2007
  • supergags Jan 29, 2008
    Hi Thegolfguymb,
    The relays were purchased from FARNELL Part No: 109-4011
    they are located towards the bottom left corner of the PCB
    next to the green LEDS. cost = $45.80AUD
    You will need to cut off one of the unused pin on the relays but they are a perfect fit.
    Relay spec's = 5Volts DC / 12A 250VAC
    Hope this is of some help.
    Regards
SOURCE:
My sharp LCD tv won't turn on,it goes off after a few seconds.
Time for a new TV. or you might unplug it let it set for a while and then plug it back in see if it reset itself.
Mar 13, 2013 | Televison & Video
No power to gray wire at fuel tank
Keep in mind that this wire will only have voltage to it for two seconds after you turn the key on. It will take two people to check since you won't have time to run back and forth from the ignition switch to the connector to the fuel pump. Find the Fuel pump relay in the under hood fuse box and have someone turn the key on and listen for an audible click. The check for voltage again at the power wire of your connector within that ininitial two seconds. Let me know if you need further diagnosis. I've replaced quite few fuel pumps on these already. Just remember that when you turn the key on, you'll only have voltage for 2 seconds.
Aug 15, 2012 | 2005 Pontiac G6
1999 Mercury Sable Keyless entry wont work
I only have the instructions. If it won't program you may have a problem in the module. In that case see the dealer for testing and diagnosis
. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in RUN.
Door locks will cycle to confirm programming mode. 2. Within 20 seconds press any button on first keyless remote. Door locks will cycle to
confirm programming.
3. Within 20 seconds, press any button on second keyless remote. Door locks will cycle
again to confirm programming.
4. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Jul 03, 2012 | 1999 Mercury Sable
Sony Trinitron KV-27FV310 won't stay on, standby button flashes around 10 times, help please?
Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board
Jun 18, 2012 | Sony FD Trinitron WEGA KV-27FV310 27" TV
My sOny tv KF-42WE610.. Won't turn on.. I just
Please let me know how many times it will blink to determine where the exact fault came from.
Jdvillanueva
Jun 17, 2011 | Sony Televison & Video
TV won't stay on! The TV will randomly make a "click/pop" sound and turn off. I will unplug the tv for a bit and then reinsert power cord. The tv will "click" (just like when it is turning on) then a...
Power supply board have problems.It dying.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 14, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
LCD Tv turns off automatically within few seconds
It is a software problem sony was fixing for free untill 03/01/08
You can unplug your set from the outlet for 30 seconds and it will work fine untill several hours of use acrue again. Found this out on the sony website. hope it helps.
Jan 13, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
GE 31GT740 clicks off and on
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Reverts to standby from switch on via TV or Video
No 5v rail because FET MTP3055 o/c. (BUZ71 will do nicely)
Goes straight to standby, after a quick burst of power
Replaced R952 (39K), had gone slightly high
Nov 23, 2007 | GE 31GT740 31" TV
Open Questions:
SVA-USA HD4208TIII-VR 42 in. Plasma Television Logo
550 people viewed this question
Top SVA-USA Televison & Video Experts
Steve Allison
Steve Allison
Marvin
Marvin
Vitally Alcher
Are you a SVA-USA Televison and Video Expert? Answer questions, earn points and help others
