Question about Mitutoyo Dial Indicator-Graduations:0. 001", Total Range:0. 075", Range per Rev: Model 1581-10
Adjusting the angle of the contact point on a Mitutoyo 513-402
I have recently bought a Mitutoyo 513-402 (lever not plunger) dial indicator. How do I change the angle of the contact point?
Peter
By simply pushing it (the contact point), it may be stiff to start but should ease up over time. Remember if your doing precision work (0.001mm or seconds of a degree) changing this original position will affect your reading so refer to booklet within original packaging or visit mitutoyo website's (Japan, USA, UK) between them they have most instructions available it's just a question of finding it, Good Luck.
Posted on May 26, 2009
Mitutoyo 543-256 linear error of 0.028mm over full 12mm stroke. Repeatability is perfect, mechanically is perfect. Is there a re-calibration procedure?
Ensure your testing procedure is perfect. If your testing procedure is proven, then you will need to send it for repair. At that point, either your scale or grid assembly is damaged or requires adjusting.
Canada's Gauge Repair Specialists
Precision Tool Works - www.precisiontoolworks.com
Jan 08, 2015 | Mitutoyo Measuring Tools & Sensors
Mitutoyo digimatic false readings.
Try first no cable and also change battery as general solution. Second is to test does button for zero works well or give contact unpressed.
Mar 27, 2017 | Mitutoyo 293 831 Electronic Digital...
How do you rezero a 505-637 mitutoyo dial caliper
Fully close the caliper. The pointer should be pointing about straight up or close to it. Losen the knurled screw which is located on the circumference near the bottom. Now grab the dial and turn until the zero lines up with the needle. Re-tighten the knurled screw.
Dec 03, 2010 | Mitutoyo 0 150mm X .02mm Dial Caliper
This is my first Leupold scope, I don't understand the friction adjustments 1/2 MOA dials, I need to adjust 3 inches up and 1and 1/2 to the right, I have moved the dials in the direction indicated to no...
minute of angle is not the same as 1/4" per click at 100 yards. if it doesn't click something is wrong. i would call leupold and probably try to get a replacement from where you bought it. moa is an angle value not an inch value.
Oct 23, 2010 | Leupold ® Rifleman® 3-9x50 mm Scope
The locking nut on my micrometer does not lock anymore, can i fix this?
yes. Just remove the screw in the lock, lift the lock arm off its shaft, and reposition at different angle. (put to lock, take off without turning, and set back on at unlocked position...may ned adjusting)
good luck
Mar 28, 2010 | Mitutoyo 0 1".001 Fric/Thimble Mti Outside...
Im looking for the instructions manual for Mitutoyo 543-271B
For any manual contact Mitutoyo nearest office , they are professional and will help you.
Feb 13, 2010 | Measuring Tools & Sensors
How to reset zero position reading on a mitutoyo 505 629 dial caliper?
unless they have changed them there is asrew like a watch winder on the dial it self ,undo it slightly and turn the dial to the desired position then retighten the screw
Nov 08, 2009 | Mitutoyo 505 677: Test & Measurement...
How do I change the battery in my Mitutoyo digital?
The battery compartment is on the front of the instrument. The cover is round and has some symbols that resemble arrows pointing down. Slide the round cover down to access the battery.
Nov 05, 2009 | Mitutoyo 500 506 10 Electronic Digital...
Mitutoyo Dial Indicator-Graduations:0. 001", Total Range:0. 075", Range per Rev: Model 1581-10 Logo
297 people viewed this question
Top Mitutoyo Measuring Tools & Sensors Experts
Glenn
Glenn
Dragan Manojlovic
Dragan Manojlovic
Level 1 Expert
Are you a Mitutoyo Measuring Tool and Sensor Expert? Answer questions, earn points and help others
