Body Control Module (BCM)
Below the left side of the I/P to the left of the steering column.
Has three connectors.connector #1 52-Way F AMP Hybrid (BK) Body Control Module (BCM) C1 Pin
Wire Color
Circuit No.
Function
TN
860
Front Windshield Wiper Switch High Signal
WH
1459
Security System Sensor Supply Voltage
PK
1439
Ignition 1 Voltage
TN
28
Horn Relay Control
5
OG
300
Run Relay Control
6
TN
707
RAP Relay Coil Control
7
TN/WH
1969
Headlamp High Beam Relay Control
8
Not Used
9
PK/WH
1970
Headlamp Low Beam Relay Control
10
WH
1080
Park Lamp Relay Control
11
YE
749
Security Indicator Control
12
GY
91
Windshield Wiper Switch Signal 2
13
YE
196
Windshield Wiper Motor Park Switch Signal
14
TN
1835
Low Reference
15
L-GN/BK
1137
DRL Ambient Light Sensor Signal
16
YE
5066
Brake Pedal Position Sensor Signal
17
BK/WH
1651
Ground
18
Not Used
19
BK/WH
151
Ground
20
BK/WH
1651
Ground
21
YE
5
Crank Voltage
22
PK
1239
Ignition 1 Voltage
23
BN
1141
Accessory Voltage
24
Not Used
25
WH/BK
644
12-Volt Reference
26
PK/BK
109
Hood Ajar Switch Signal
27
OG
5688
10-Volt Reference
28
GY/BK
5689
Low Reference
29
BN/WH
230
Low Reference
30
PK
1444
I/P Dimming Control
31
OG/WH
812
I/P Dimming Voltage
32
Not Used
33
BN
5077
Low Reference
34
BN/WH
1571
Traction Control Switch Signal
35
GY/BK
1598
Courtesy Lamps Switch Off Signal
36
PK/BK
1597
Courtesy Lamps Switch On Signal
37
TN/WH
1455
Keyless Entry Signal
38
L-GN
1037
Class 2 Serial Data
39
L-GN
526
Stop Lamp Supply Voltage
40
L-GN
80
Key In Ignition Switch Signal
41
L-BU/WH
1314
Left Front Turn Signal Lamp Supply Voltage
42
D-BU/WH
1315
Right Front Turn Signal Lamp Supply Voltage
43
GY/BK
690
Courtesy Lamp High Control
44
OG
1732
Inadvertent Power Courtesy Lamp
45
Not Used
46
RD/WH
340
Battery Positive Voltage
47
OG
228
Windshield Washer Pump Control
48
GY
8
Instrument Panel Lamp Supply Voltage
49
D-GN/WH
1135
A/T Shift Lock Control Solenoid Control (w/o AQW)
GN/WH
1135
A/T Shift Lock Control Solenoid Control (AQW)
50
RD/WH
240
51
RD/WH
2440
52
RD/WH
1240
Connector #2 52-Way F Receptacle 0.64, 2.8 (BK) Release Tool/Test Probe: 12094429/J-35616-4A
Body Control Module (BCM) C2 Pin
Wire Color
Circuit No.
Function
Not Used
OG/BK
780
Driver Door Lock Switch Lock Signal
D-GN
5512
Liftgate Open Switch Signal
D-BU
245
Passenger Door Lock Switch Unlock Signal
5
L-GN/BK
748
Right Rear Door Ajar Switch Signal
6
YE/BK
1181
Right Rear Door Open Switch Signal
7
L-BU/BK
747
Left Rear Door Ajar Switch Signal
8
L-GN
1177
Right Front Door Open Switch Signal
9
L-BU
1134
Park Brake Switch Signal
10
L-BU
2380
Rear Parking Assist Chime Signal (UD7)
11
OG/BK
781
Driver Door Lock Switch Unlock Signal
12-15
Not Used
16
WH
193
Rear Defog Relay Control
17
TN/WH
746
Right Front Door Ajar Switch Signal
18
D-BU/WH
1179
Left Rear Door Open Switch Signal
19-21
Not Used
22
L-GN
1123
Door Lock Key Switch Lock Signal
23
WH
5075
Current Sensor Signal
24
PU
1124
Door Lock Key Switch Unlock Signal
25
TN
126
Left Front Door Open Switch Signal
26
GY/BK
745
Left Front Door Ajar Switch Signal
27-29
Not Used
30
WH
17
31
L-BU
244
Passenger Door Lock Switch Lock Signal
32-33
Not Used
34
PK/BK
1303
Liftgate Ajar Switch Signal (Early Production)
35
YE
2080
Low Reference
36
PK
2435
Low Reference
37
YE/BK
2079
Driver Heated Seat Cushion Temperature Sensor Signal
38
GY
2434
Passenger Heated Seat Cushion Temperature Sensor Signal
39
TN/WH
2430
Passenger Heated Seat Relay Control
40
PU
2477
Driver Heated Seat Relay Control
41
Not Used
42
L-GN
24
Backup Lamp Supply Voltage
43
YE
18
Left Rear Stop/Turn Lamp Supply Voltage
YE
18
44
GY
8
45
L-GN
275
Park/Neutral Position Park Signal (E58 w/o AQW)
L-GN
275
Park/Neutral Position Park Signal (E59 w/o AQW)
L-GN
275
Park/Neutral Position Park Signal (AQW)
46
TN
694
Driver Door Lock Actuator Unlock Control
47
Not Used
48
D-GN
19
Right Rear Stop/Turn Lamp Supply Voltage
D-GN
19
49
RD/WH
440
50
BK
550
Ground
51
TN
294
52
GY
295
Door Lock Actuator Lock Control
There should be a button on the control panel that says "open door" you need to push that button and wait for the washer to shut off before you open the door. Try pushing that button to see if that resets. My guess is that you broke the safety latch when you opened the door and it will need repair.
On a vista system, enter your 4 digit code and press the 9 button. The keypad should read: Disarmed Chime. The keypad should ding ding ding when a door is opened. To turn the chime off, enter you code and press the 9 button again.
you probably have two switches in your door. one for the door ajar and the other for the door handle. It sounds like the door handle switch is stuck; sending a constant signal to the module showing the door handle being actuated when in fact it is not.
Yes, you can switch the cycle completion signal off (or raise/lower the volume)
1. Switch the dishwasher off using the ON/OFF button
2. Open the door
3. Switch the dishwasher on again. (One of the wash cycle LEDs will flash.)
4. Hold the > button in. Continue holding it and press and release the Start/Reset button once, then release the > button.
"Clean" and one other LED should now be flashing. This indicates that the dishwasher is in the options/settings mode. If they are not flashing, start over at step 1.
5. Press > repeatedly, until the LEDs for "Clean", "Sanitized" and "Rinse Agent" are all flashing.
6. Press repeatedly until none of the LEDs are flashing.
The number of flashing LEDs indicate the volume setting . . .
there is a problem with the soap dispenser not getting signal to open 9 out of ten times it is the dispenser its self and needs to be replaced the other problem is the main control board
HI. this F-9 code is signaling a major door mechanism malfunction. the best action is to replace the entire door latch assembly. this will heel the F-9 alert and, fix the problem you are experiencing at this time.
