The monitor vibrates every now and then
The monitor vibrates after playing at non stable time
  • 304 Answers
Dear Sir this happens due to voltage fluctuations. Check the voltage of your outlet or else check with ups. If it continues even after replacing the UPS. You need to consult a technician.
Thanks & Regards
Nanda Kishore.
Posted on May 09, 2009
In spin cycle violent vibration
First, check to make sure you aren't loading the washer excessively. Many times it is an unbalanced load. Second, check to see if the washer is level. The feet are adjustable and allow you to level the washing machine. While checking the level, make sure the floor underneath is stable as well. Lastly, if these do not help, you may need to have the dampners checked (these are like shock absorbers and minimize the vibration of the drum).
Apr 15, 2014 | LG WM-2277HW Front Load Washer
PS3 has lines and buzzing sound when played in an upstairs bedroom. When played in a lower room, it is fine.
this can be due to heating of the unit sir.
please try cooling the unit using external fans
Jul 01, 2008 | Video Game Consoles & Games
Lg monitor m2262d
SIgnal is not stable. try new cable. or HDMI
Oct 24, 2013 | Computers & Internet
Lt20hvk drivers
have you tried the manufactures web site help and support. as far as i know that is the only settings that windows will give.most monitors have software in built to say what they can do. but a tv/monitors are non plug and play
Sep 20, 2013 | Televison & Video
Whatdo i do if my skullcandy headphones dont charge?
Are these amplifing headphones or ? Most headphones use the devices power source to make the headphones work, they use very low voltage and various ohlms to make the earpieces vibrate and make sound. If they are not working try pushing the connection in all the way, or try another set of headphones to see if the problem is with the device. Sometimes we get defective headphones right out of the box, Skull Candy is usually very reliable and quality checked before shipping, but it can happen with all manufactures. Gool Luck.
Mar 15, 2011 | Audio Players & Recorders
Alpine MRP-T220 car amp. When I turn on the JVC stereo, the amp plays for a split second then dies. The power light stays on, and the fuses from the battery and the amp are fine. It always worked...
Yes your amplifier is stable @ 2OHM but only in stereo mode. If you are running the amplifier in BRIDGE mode then the amplifier is stable only @ 4OHM. So if you are running a sub woofer and it requires a 2 Ohm mono load then the amplifier has either been damaged or is trying to protect itself from the wrong OHM load. You could also make sure that your GND is secured properly, as some times it could come lose from vibration and not offer a decent ground for the system. dreamsystems.
Feb 21, 2011 | Alpine MRP-T220 Car Audio Amplifier
I noticed that every time I buy new PS2 Dual Shock 2 it only last for 3 months because I play to much almost everyday then when I try to open the black wire of the dual shock the colored wires some...
Hi, This is happen because : 1. You may bought a non original controller. 2. You may always engage the vibration function. Sony dual stick controller ( analog stick) has fine cables inside controller. The imitation ones even smaller. While you use the vibration function for long time, it make some cables apart.
Suggestion :- Use only original dual stick controller ( analog stick). Don't engage vibration function for long time - I believe you can reconnect the wires inside controller ( so just fix it yourself) and play..
Dec 01, 2010 | Sony PS2 Dual Shock 2 Controller...
Why want my subwoofer play like it's supposed to? It barely plays
check your ohm load on that audiobahn sub some amps run at an bypass or ohm load and then kick off if its the sub itself is not a 2ohm stable or 4ohm stable
Mar 03, 2010 | Car Audio & Video
My car is lumina LS 2004. The problems are 1-the RPM moving up/down very little (not stable 100% )while the car in parking pos. 2-There is a light vibration in the motor which is noticed in parking...
try disconnecting the battery for 1 minute at the negative post to reset the on board computer id have to hear in further detail is it surging maby fuel filter
Aug 22, 2009 | Chevrolet Lumina Cars & Trucks
JerkyDisplay
It May also be caused if your screen is in an external magnetic field.Just try it at any other location and report it please.
Dec 05, 2007 | IBM ThinkPad T30 2366 Notebook
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
