Question about Dryers
My maytag neptune mde4000ayw dryer just stopped drying clothes. the vent is only 3' long.
  • 146 Answers
SOURCE: change rollers on a Maytag Neptune Dryer
You have to work from the front. Pull the top then the front then you will be able to see everything. Pretty self explanatory.
Posted on Dec 22, 2007
  • 1028 Answers
SOURCE: Maytag Neptune MDG9700AWW gas dryer. Problems
be sure vent is clear all the way to outside try a load with vent disconnected ..also if gas dryer may be a problem with burner reigniting after heat up if so try replaceing both coils on burner valve
Posted on Jun 06, 2008
SOURCE: Changing the drum rollers on a Maytag MDE4000AYW Neptune Dryer..
The instructions above are perfect for most Maytag Dryers, but the Neptune MDE4000AYW is built differently from most. To open it, undo the two screws that run through the door hinges, and remove the door, then undo the two other screws that are on the opposite side of the doorway. With these four screws out, you can lift the front panel UP and out. Make sure you unplug the dryer first :-)
Posted on Nov 21, 2008
Illeagle
  • 525 Answers
SOURCE: My Maytag Neptune gas dryer gets hot for about 30 seconds.
Below is a link courtesy of www.repairclinic.com. This shows the Gas Valve Coils, which is the number 1 failing component.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG5500AW-%3d%3di3479&PartID=3479
Below is the disassembly/diagnostic procedures page that may help on teardown.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
For more information visit, http://homemanagement.services.officelive.com/FieldServiceHelp.aspx
Posted on Sep 23, 2009
heatman101
  • 43501 Answers
SOURCE: Maytag Neptune clothes dryer Model# MDE4000AYW
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
trxcvhj
Posted on Sep 29, 2010
My Maytag MDE4000AYW electric dryer is not heating and drying my clothers
Check for a blocked vent. If the vent is blocked or restricted it will cause the thermo fuse to blow. If the thermo fuse is not blown check for a broken heating element. I hope this may help.
Jan 02, 2012 | Maytag Neptune MDE4000 Electric Dryer
Mde4000ayw  It runs and hot air comes out the exhaust but clothes take for ever to dry. Help?
Sounds like you may have lint stoping up the vents it could still get some hot air out but not enough. Or maybe one side of the 220 power line has kicked the breaker or a burnt wire in the dryer.Check the outside vent it should be blowing as much air as coming out the dryer.
Jul 16, 2010 | Maytag Neptune MDE4000 Electric Dryer
Maytag Neptune clothes dryer Model# MDE4000AYW Noisey squeeking sound. However, after a few minutes when it heats up, the sound goes away.
heatman101
trxcvhj
Jul 05, 2009 | Maytag Neptune MDE6700A Electric Dryer
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer doesnt dry clothes
I suspect you have a blocked air vent. A blocked vent will definitely extend your drying time. You may even find yourself having to run a load twice to get it fully dried. One way to confirm this is to disconnect the vent hose from the back of your dryer and dry one load with the machine venting directly into your laundry room. If that load dries quickly then you know the problem is a blocked vent. Most vents get blocked by lint near their exit to the outside. There's usually a screen at this location to prevent small animals from crawling into your house. Often this screen gets clogged with lint. Most vents are designed to allow removal and cleaning of this screen from the outside.
Jun 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have a neptune drying center and it's taking 3 hours to dry
Check the exhaust duct again. There must be a blockage, a kink, or a disconnected vent pipe.
May 03, 2009 | Maytag Neptune MCE8000AY Electric Dryer
NOt drying clothes like it should
Has air flow problem, check to make sure the vent going to the outside is not blocked. If it isnt, you should be able to take off back cover of dryer. Should be a duct that air goes through, take it apart and make sure there is no lint in bottom of it. I had the same problem and that fixed it.
Apr 20, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag dryer won't dry clothes.
Pull the dryer out away from the wall. Unhook the vent from the dryercompletely. Do not put anything over the dryer exhaust on the back ofthe dryer. Do a normal load with the vent unhooked. If it dries betteror ok like this then the problem is in the dryer venting. Like ablocked vent pipe or a smashed or restricted vent hose.
If the vent doesn't make a difference,then check the blower wheel for excessive lint build up, check thatthere isn't anything stuck to the air intake baffle inside the drum,(i.e. the screen on the back wall of the dryer when looking into thedrum). Check the lint filter chute for blockage. Check that the heatingelement isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermomter can be used for this. It should cycle between 120 degrees and 160 degrees. Check that the drum seals are not worn out.
Feb 21, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Maytag Neptune sensor and time drying settings
Fixed the problem, not the machine, needed a new dryer vent. Just unhooked the vent and
the dryer worked perfectly. V
Feb 08, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
76 people viewed this question
Top Dryers Experts
