Question about Samsung Cell Phones
No Volume when receiving calls on my cell phone
Need to know how to open case with out braking anything else to check the speeker for placement or damage
  • 21 Answers
SOURCE: I can't hear anyone, nor can i be heard, when making or receiving calls
Sometimes there might just be lint or something in the headset port. Try taking some canned air and blow it out or take a headset and plug it in and out a few times.
Posted on Sep 24, 2008
SOURCE: lg ax355 cell phone not receiving incoming calls
Have you tried rebooting the phone as I experienced a similar issue
Posted on Jan 08, 2008
SOURCE: Emergency calls only
1.Turn off phone
2.Eat some swiss cheese (it has to be swiss)
3.Turn phone back on
This should solve the problem
Posted on Jun 08, 2008
SOURCE: blank screen on kyocera cell phone
mymomcallsme solution works, I had the problem, removed battery fer a while, viola! Screen is back. Thanks mymomcallsme
Posted on Dec 14, 2008
SOURCE: Verizon Blackberry Storm
I have the exact same problem consequently all my calls go to voice mail ... very frustrating and just started happening in the past month.
Posted on Apr 12, 2009
SOURCE: LG enV earpiece and key sound not working
go to tools and setting --> sound settings --> keypad volume...see if you see "KEYPAD VOL-EARJACK"...that means that your phone is stuck in EARJACK mode....get a wired ear piece, plug it in, make a call, and then unplug after you end the call....that should resolve your problem...
Posted on Mar 18, 2010
0 characters
1 Points
Cannot make or receive calls on nokia 6300
check your volume control first ,if you do that and you still not hear anything your phones earpiece is damaged and need to replace...
Sep 30, 2012 | Nokia 6300 Cell Phone
My iphone will not ring when called. I have checked settings and all look good. I can hear my alerts, alarms and when testing ringtones (and volume is up). However, when I receive an incoming call, i...
try checking the mute button on top of the volume buttons. if you see an orange dot or line, it is on mute so slide it to hide the orange dot or line and the phone should be fine.
May 09, 2011 | Apple iPhone Smartphone
I cannot hear anything on MY end when I make a call or receive a call and the volume is completely up. It is not on mute and the person on the other end of the call can hear
The problem with your phone is that the earpiece of your phone is faulty that is why you cannot hear anything when someone calls you or when you call someone.
All you need to do is to change the earpiece of your phone in other for people to hear you when you make calls or when you receive calls.
The earpiece of your phone is bad that is why you cannot hear anything when you make calls, change the earpiece of your phone as advice and you will see that you will hear when people call you.
Take care.
May 02, 2010 | Samsung SGH-L700 Cell Phone
One day when someone called me i couldnt hear them. And when i call my phone does not even ring. any ideas?
its may be 4 network problem / head set not fitted properly/some blue-tooth issue.if its rapind then may 4 transmitter/ringar problem,if in lowd speeker tte ok,then oter ear speeker is gone.
Mar 27, 2010 | Verizon Communications Samsung Alias Cell...
When i make a call i can not hear the caller,but the cller can hear me motorala w510
is this the first time this has happened?
have you dropped your phone?
try a reset of your phone by taking out the battery and the SIM card2_bing.gif. Wait
15 seconds and put it back together and power it on.
I have had this problem and have helped fix others phones this way.
sometimes your phone just needs a hard reset. especially if you leave your phone on all the time.
now,if you have dropped your phone a lot or it had a real bad fall you mayhave damaged something. In this case it is time for a new phone.
Hope the rest helps!
Mar 26, 2010 | Motorola Mobility W510 Mobile Phone
Volume and microphone flucuation
This is a device issue. You will need to contact your service provider for replacement options!
Mar 10, 2010 | AT&T BlackBerry Curve 8310 Cell Phone -...
I have SGH J600. Can only receive and send texts,
did you check on your volume is up to check if you can hear the other party. normally your problem happens when the volume i down. So try making a call then turn the volume up to double check
Aug 11, 2009 | Samsung J700 Cellular Phone
When i call or receive a call from someone i cant hear any thing
there is problem in ear speeker. plz change it
Jun 03, 2009 | Nokia 3220
My LG cookie's AUDIO does not work.
I had the exact same problem, i downloaded some mp3's onto my phone from my MAC using the usb cable included with the phone and when i played them they only worked on the headset but then i quickly realised it was the speeker that had gone. I checked every setting just to be sure but no luck, anyway i opened it up got to the speeker, i kept the power on and a song playing to see if i tweeked the conection from the circuit to the speeker maybe i could see if the wires were the problem and re-solder but no luck. SOLUTION i then got frustrated and played a song flicking the phone near the speeker to see if it would work, THEN i decided to try a magnet but no change so i turned it off and ten mins later i turned it back on and heard a partial sound i flicked it turned it on and off and it now works! don't know if it was the flicking or the magnet but when i opened it up and moved it around nothing happened so i say try the magnet and turn it off and on giving it a 10 min break between and hope for the best.
I realise this is probably not the answer you are looking for but worth a try it can't get worse
Apr 12, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Cannot hear anything thru the receiver,
when you are in a call , turn the volume up with the volume button
this is one solution
if that dont work then:
1.reset the phone to defualt settings
sorry thats all the solutions iv'e got lol
Dec 31, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Cell Phones Logo
52 people viewed this question
Top Samsung Cell Phones Experts
Steven Wander
Steven Wander
Fred Sops
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
