Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Clutch drum How do I get the clutch drum loose from a husqvarna 136 chain saw? What tool do I need to get it loose. Thank you
  • 181 Answers
How do I take the clutch off a 576xp husqvarna?
Start by removing the c clip and washer securing the clutch drum, remove the drum,rim and bearing, there is now a special tool that fits into the clutch spider pt no. 502522201 it is a box spanner with three protruding legs and a bar across the top, i guess you could make something similar, the idea is to jar the clutch off against compression ( left hand thread ) useing a suitable hammer to strike the tool, i welded a 19 hex nut on top of the three legged tool so as to put an impact gun on ( some of these clutchs are murder tight ) i strongly advise you not to use a piston stop, or insert anything into the cylinder to lock the piston, this can easily end in disaster.
Good luck
Jan 12, 2011 | Husqvarna Chain Saw Models 371, 372xp
Tip
How to remove the clutch & sprocket from Husqvarna chainsaw
The clutch type on Husqvarna chainsaws fall into two types, inboard clutch, this is where the drum is on the outside of the clutch, and held on with a clip, and outboard clutch, where the clutch is on the outside of the drum and holds the drum on. There are a number of reasons as to why you may need to remove the clutch and drum, to replace a broken spring, to replace the whole clutch,to lubricate the drum bearing, or replace the sprocket. On the pro saw range it is possible with outboard clutches to grease the drum bearing through the end of the crankshaft, there is a channel to the bearing from the outside, this is not possible on hobby, and domestic saws.
All Husqvarna clutches are just spun onto the crankshaft, with a left hand thread to make them self tightening, due to this they should NEVER be run with the bar and chain removed,and the clutch in place, or there is a very good chance the clutch will spin off on the over run, and can cause serious injury. Clutches should be jarred off against the compression of the saw, many have a 19mm nut on the outside so as to fit a socket, or the combination spanner supplied with the saw, the quickest way to remove this clutch is with an air impact wrench. If there is no nut on the outside, there will very likley be two cut a ways in the clutch spider, these are designed to take a flat screw driver blade, and with a suitable hammer you can strike the screw driver and jarr the clutch off, there is also a special tool for this type of out board clutch, it fits into the sides of the clutch with a 19mm nut on the outside part no. 502541601 available from Husqvarna dealers. The hobby saws from Husqvarna are produced in America, and as such use the Poulon clutch, this clutch should never be struck with a hammer, it is made from a sintered material and will shatter, there is a special tool to remove this clutch part no. 530031112.
The inboard clutch on the 371/372/365 also has a special tool available so as to use a 19mm socket, part no. 502522201.
The tool for the 357 clutch is part no. 502522202.
As a personal thing i never use piston stops, i have seen too much damage to internal engine parts when useing these, it is far better to jar the clutch off. As a rule of thumb you should not be able to pull the clutch shoes out by hand, if you can, the spring.springs are weak and require replacement, the clutch soes are also shamffered on there edge, the bottom of which is the wear limit.
on Jul 25, 2011 | Garden
Looking for a repair manual for husqvarna 136 chainsaw
Below is the link to the Husqvarna website where you can download a repair manual for free. Click the link and just find the year of your chain saw and you are good to go!
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=136&types=O
Oct 18, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How do I tighten the chain for model 136?
A link to a 2003 Husqvarna 136 follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2003/HOUS2003_O0301010.pdf
See pages 7 and 8 for chain adjustment installation/adjustment.
All Husqvarna saws may be found here:
HusqvarnaUSA.com
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Sep 07, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How to change the chain of my 340 Husqvarna chainsaw? Is there a way to remove the "clutch" to get to the cogs?
Why post a new question instead of using the reply feature below?
Are the spurs worn? They are attached to the clutch drum.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
You can find a part number for the spur sprocket here:
HusqvarnaUSA.com
06 1500198
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 08, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How to remove a clutch drum assy.
A serial would have been helpful. She has an outboard clutch (chain between clutch drum and engine). Use this as a guide:
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources,
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
This often helpful too:
HusqvarnaUSA.com
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
Good Luck, If you need any more help you can can reply below.
Lou
Jan 18, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Hi, I took off the clutch cover for my Husqvarna 136 saw and I can't get it to go back on. Any suggestions?
you need to disangage you chain brake band as it is engaged and wont go over the the clutch hub sprocket
Aug 05, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 136 chain brake handle spring.
You can get an IPL here:
HusqvarnaUSA.com
I don't think this has the detail you need.
If it were me I'd visit my friendly neighborhood Husky chainsaw seller (not Big Box Store) and ask to look at the clutch cover with the brake installed (take a camera). I'd probably ask for a quote for their repair too. HTH
Lou
Your model is no longer sold. The seller will know what model replaced it and may be willing to explain the repair procedure for your saw you. Take the cover and loose parts with you.
Jun 27, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 137poorly works at full throttle
it seems to me the you have either a clutch problem or a spur gear problem.if it is the clutch the clutch drum will be blue.witch means you need to replace the clutch and drum.if it is a spur gear problem you need a new spur gear.to check it out,take the chain and bar off the saw.now look at where the chain rides in the gear.there should be no markings on the gear.if the spur gear has any dents on the gear then the gear is bad.if you are getting denting on the surface then you are over tighting the chain.this causes the chain drivers to ware also.most likely this is your problem.hope this helps,let me know if you have any more questions............
May 18, 2009 | Husqvarna Garden
Needle bearing maintenance
use a plastic piston stop and the proper clutch removal toop. Try Baileys on line or Madsens saw shop for the removal tool. Must order for the specific model, but they are rather cheap.
Oct 24, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
294 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
