Question about Motorola Mobility RAZR V3m Cellular Phone
My motorola v3m will shut down or sometimes screen will be black but keys are still lit up and I have to press on button several times to get it to fully boot up again.
    Problem Solver:
  • 12 Answers
You should try resetting the handset back to its original factory settings and see if this helps, if not maybe you need to flash your handset with the original firmware
Posted on May 11, 2009
Froze on video and now black screen
Try pressing the back and home keys a few times. Sometimes a program hangs and the input prompts android to display the force close option to end the application.
If that doesn't work, try holding in the power button for about 10 seconds and see if the power down options appear (this might cause the force close to appear too, if so go for that method, if not shut down and power back up).
If none of that helps, you may need to pull your battery and boot it back up.
Please leave feedback if you found this helpful. Thanks.
Mar 31, 2011 | Motorola Mobility MILESTONE XT720 Cell...
Motorola Razor V3m not power ON
It seems like a damaged chip possibly rusted or if you didn't take out the battery, severe damage to the whole phone. You might be able to get it repaired for less instead of replaced. I am not sure if you can buy new parts, but you can probably find a new one on ebay with a broken screen or something like that, and use parts from both to make a new phone(Did the same with 3 broken PSP consoles) I hope this helps. If you have a hard time with the second option, you can find guides for disassembly and reassembly online.
I really hope i have helped
C-m0n3y
Feb 25, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Need motherboard diagram for the test mode
It sounds like the flash did not finish or hung while trying, I would
think that you just bricked the phone. I have never heard of this
test mode of the board, you normally use the keypad on the phone
to enter it into test mode. If the phone does not post, I have never
heard of a way to get it to reflash.
Maybe someone will come along that knows a way.
Apr 04, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Won't power up
Device is bad or needs reset, remove the battery while the device is on and count to 30 then re-apply battery and power on!
Sep 14, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Master Reset
the OPCODe can master reset the phone. I screwed up my phone by trying to change the theme and evry time i pressed menu the phone restarted. However, i found a post on another site that read...
For me, Motokit, PTS, and the reset of the tools could not reset my phone. Here's how I reset my phone with just the phone keboard.
This will reset all your menus. On my Verizon Razr V3m phone, my contact and my picture gallery were not affected. (Make sure you key the command in exactly. 18*1 is Master Clear, and you don't want do to that.
From your phone, enter this sequence to go into OPCODE mode fairly quickly:
Press CLR then
048263*
This puts you in OPCODE mode, where you can enter special commands. Be CAREFUL here.
Enter a the code for a Master Reset command:
18*0
Press the middle navigation button.
Wait. The screen should show "SUCCESS" after a few seconds.
Push the LEFT soft key (back). You'll be back at the OPCODE screen.
Push the RIGHT soft key (options). Push this button again to select Cancel Entry (the only option).
This gets you out of OPCODE and back to where you started. You might have to push CLR a few times to clear the number you entered to get into OPCODE mode.
It was really helpful
Aug 16, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Backlight display not working
Hey Dannes1956,
The Motorola V3m has a light sensor, which is visible just above the right soft key -- the key above the CLR button. This light sensor turns the backlight on when you press a key in the dark and disables the keypad backlight when you are in a well-lit area.
Your phone sounds like it's operating normally. I believe they disabled the option to activate or deactivate that feature.
Hope this helps,
cHiPz.
Mar 17, 2008 | Motorola Mobility RAZR V3
Razr V3M Power-up/Black Screen
I ended up having to take my phone back to Verizon.  They replaced it with a brand new one because they were unable to find the problem.
Oct 16, 2007 | Motorola Mobility RAZR V3m Cellular Phone
TV shuts off automatically
I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board.
Aug 24, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Razr- turning on camera makes screen turn black but keypad stays lit
the easiest thing tpo do here is take it to a professional but if you want to try updating your software off the Motorola website. (this require a data cable or bluetooth in your computer) This fixes a lot of software problems with the razor. If this doesn't work then you will have to reflash your Firmware which is like the Windows Xp of the phone. This does require a professional as it can destroy the phone
Jul 05, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3m Cellular Phone Logo
156 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
