Question about Dryers
Dryer does not start
Kenmore Series 80 Dryer will not start. Push Button and can here chatter from timer but drum does nothing. Door switch is good and so is belt. Model # 110.64892401 Ser MR5125164
  • campcoach Feb 19, 2010
    Found Problem:
    There are 3 overload heat sensors on this dryer. 1 had burned out. Checked continuity with Ohm Meter to find which one. replaced for less than $20. Thanks for the help anyway.
    Problem Solver:
I just fixed my 110.73932102 model dryer, and have done about a week of web research on that problem. I got a electronic control board from AppliancePartsSolutions.com for about $60 delivered-took about 4 days. Use flat screwdriver to pop off plastic ends of top console. Under plastic ends, find one screw (phillips) on each end-remove. Then, slide console forward 1/2 inch and it should open back to expose innards. Note-follow static elec. charge abatement procedures around all electronics! Part snaps out and in after disconnecting wiring. 20 minutes, tops and you're running again. Less than the service call! Good luck.
Posted on May 10, 2009
When I push the start button on my Kenmore 700 series dryer nothing happens. You can hear the timer clicking as if it is getting power, but the dryer doesn't come on. Could this be a defective timer?
Check the door saftey switch and the start button for continuety.
My bet is the door switch.
Then look at the timer if both those are good.
Mar 19, 2010 | Dryers
Heavy duty super capacity plus Kenmore 80 series Electric drier the timer is running, but when I push the start button - nothing
the drum belt may be broken. you will have to check this, it goes around the drum and the pulley on the motor. you could also have a bad motor.
Oct 16, 2009 | Kenmore 73952 Gas Dryer
CHECK DOOR SW,CHECK DRUM BELT, CHECK THERMAL STAD MIGHT BE OPEN
Aug 20, 2009 | Dryers
Kenmore 80 series electric dryer wont start
Push the button manually and see if the light goes off . If it does , then the problem is the thermal fuse (a white slim piece of plastic with 2 wires connected to it ) located on the blower housing beneath the drum .
Jul 22, 2009 | Dryers
Push the start button and nothing
Either a bad thermal fuse located on the blower box or a bad door switch .
Jul 21, 2009 | Dryers
Push the start button and nothing happens - no noise nothing.
check both thermal fueses, door switch, power relay, timer contacts if good, replace motor, do you have 220 volts at plug
Jun 26, 2009 | Kenmore 62602 Electric Dryer
Kenmore Dryer 90 Series will start but suddenly stop...
Hello , Sounds like your motor is over heating , it will run until the sensor shuts it down from getting to hot , it is most likley because the motor is covered in lint and needs cleaned. Hope that helps.
Dec 30, 2008 | Dryers
Dryer not turning on
most likely its the timer it has electrical contacts built on the timer that allow it to start its cycle if the timer has bad contacts it wont allow dryer to come on
Jan 21, 2008 | Dryers
Dryers Logo
111 people viewed this question
Top Dryers Experts
