I put jeep in four wheel drive & drive it. It makes a load rumbling noise while in four wheel drive. When I stop the vehical. I noticed smoke coming from underneath the vehical & smell fuild burning. Then when I take it out of four wheel drive it continues to make a grinding noise. what is this problem?
SOURCE: Grinding sound in the front end
I had this problem in my 2005 F-150 twice! The first time was covered under the warranty and the second time was out of my pocket! ( close to $500.00!) There is a solodoid u[pp on the firewall that gets water into it then it corrodes the lines and such. Ford dealership replaced 2 valve assemblies, 2 actuator assemblies, and the IWE Solonoid to fix mine. They claim the problem will not come back but that remains to be seen.
SOURCE: Jeep Wrangler 1998 Sport Four Wheel Drive stuck in high
Try putting the car in neutral first. Try going in reverse while shifting out of 4wd.
SOURCE: 1996 suburban makes grinding noise in 2 wheel drive
sounds like the clip on the rear output shaft its probably broke. do this by removing the rear driveshaft, and the tail of the transfer case, there are 4 bolts holding it in place. then grab the output shaft and see if it has any front to back movement. if so pull it all the way to the rear and you should see a groove at the front part of the shaft where the clip goes. Then you should find the pieces fo the clip in the tail housing. One person said he found the replacement clip at a local tranny shop. I am calling the dealership parts counter for a new clip for my 97 Tahoe tomorrow. Hope this helps..
SOURCE: 1999 jeep grand cherokee all time four wheel drive will not engage
Sounds like the splines on your transfer case gear are ground down
SOURCE: grinding noise in front end when coming to a stop,
could be a stone stuck in one of the calipers , sometimes driving in reverse can clear the stone.
