Question about Danby DPAC8020 Air Conditioner
What is the P1 error code on an Everstar portable A/C unit?
    Problem Solver:
  • 6 Answers
U need to empty the internal bucket, its full of water.
I have this air conditioner. What I did was get a long plastic tube from home depot and connect it to the middle back drain. I then put the plastic tube outside my window, or if u have a drain somewhere put it in there or put the end into a big bucket. Let gravity do its job. I did not connect the tube to the internal bucket b/c I would have to empty it too often. The air conditioner is on top of a table so that water will flow down the tube and out the window.
Posted on Aug 19, 2009
  • 22 Answers
The owner's manual should have a trouble shooting section and the codes should be listed there. I looked online but found nothing for support on the unit. There may also be a sticker inside one of the panels with the trouble codes listed. If you can't find anything, get back to me with everything that is written on the manufacturer's tag on the back. Ron
Posted on May 10, 2009
  • 3 Answers
On the MPK-10CR, this code shows up (for me) when either the bucket for evaporation collection isn't in the compartment, or it isn't seated properly. Try re-seating it a few times until you hear the A/C kick in.
Posted on May 23, 2009
    New Friend:
I received this AC unit second hand, so I have no manual and cannot find one online.
Where can I find this drain or internal bucket to empty? I know the back has the air filter and there's a door that leads to the plug. I had the vent tub attached and connected to my window.
I have P1 flashing and can't find this plug! I'll happily put it in my Bathtub and empty it - if only I can figure out what I pull to empty.
Thank you!
Posted on Jul 05, 2015
There is a little plastic sensor with a small thin metal piece in the middle, located just behind where the pull out bucket rest when pushed in all the way. The metal piece has to rest on the back wall for the AC to kick on. We duct taped the metal part to the back wall, the AC kicked right on.
Posted on May 27, 2018
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
P10
Posted on Jan 28, 2013
I know that this code means that you need to force-drain the water out of it using the small tube in the back. Put the tube in a empty gallon jug. Then you push two of the buttons on the top panel at the same time and hold them down. For the life of my I'm having a hard time figuring out which ones! Right now I'm stuck on P1. If you keep trying them (as I will) you'll figure it out.
Posted on Jul 17, 2012
3 Suggested Answers
SOURCE:
SOURCE: Everstar Portable air
Well, sorry the response is so late but here goes. I just went through the same problem a few days ago. Press and hold the turbo button while plugging in the unit. The AC will cycle through a few tests and mine showed that it had excess water. I have long vinyl tubing so the unit could drain outside the window but it thought whenever it would start or stop there was excess water (thus stopping the flow). I drained the excess water out of the line and voila. I hope this helped you.
Posted on Dec 31, 2007
  • 39 Answers
SOURCE: My Everstar MPK-10CR portable 10,000 BTU's is blinkink P1 all tim
Make sure the level arm is also making good contct with the water bucket when you insert it. You can awlas pull the level towards you to adjust for better contact.
Posted on Aug 21, 2010
What is P2 indication on my everstar MPK-10CR-1?
Prior FIXYA question:
http://www.fixya.com/support/t2766014-everstar_model_mpk_10cr_flashing_p2
Everstar Model MPK 10CR What does flashing P2 mean
Quoting:
Everstar Model MPK-10CR, What does flashing P2 mean?
I have a manual and it only talks about the error, P1, when the water container is for. Says nothing about P2. The unit will just completely shut off and then the red light is flashing and P2 appears in the window.
Posted by oyalajan on Aug 13, 2009
  • oyalajan Aug 13, 2009
    No, I do not add water to the unit.
zobs
P2 means the bottom pan is full, you need to drain the bottom, small valve on the back bottom in the middle Posted on Jul 21, 2010
  • jerry1029 Jun 14, 2011
    My unit runs for about 5 or 10 minutes then shuts down blinks red with the P2 error message. I read what has been said but there is no water built up in my unit. i removed the plug , nothing. it does not run long enough to fill up. any ideas?
  • gerald young Jun 12, 2013
    my unit is flashing p1 my unit is flashing p1 what is wrong
w_benjamin
The filter that allows the water to get to the pump is clogged. Since the pump can't pump the water into the drain bucket, it fills the bottom pan up, the unit shuts down, and the P2 error code is then displayed. Posted on Jun 29, 2011
    oyalajan254 Jun 30, 2011
    Where is the filter that is full that is not allowing the water to drain into the drain bucket, and is it something that can be cleaned? w_benjamin Jun 30, 2011
    It should be near the pump that pumps the water up to the drain bucket. Each model is different, on my Everstar it was located under the housing for the drain bucket. The back and front of the unit needed to be removed, then the housing for the drain bucket needed to be removed. Not that hard, but a lot of screws. Take it out, then clean it with some dish washing detergent.
Aug 08, 2018 | Heating & Cooling
Everstar mpm 08cr bb4 manual
Try Googling (Everstar)(mpm 08cr bb4)(manual) without parens.
Oct 23, 2017 | Everstar Portable Air Conditioner Everstar
I have a polar wind portable air conditioner/dehumidifier/fan with swing louvers model # MPN4-12CRN1-BH8 I cannot get the protection code P1 to go away do you have any suggestions? When I first plug it in...
Check the back of the manual that came with it. I find two things for a P1 Error.
Midea AC "R" Series Error Display = P1
Error Code Definition = Over voltage or too under voltage protection
On a portable unit
P1 or H8 - Water reservoir is full.
Oct 22, 2017 | Heating & Cooling
Whats does P1 mean on my portable ac unit everstar model # mpn1095cr-bb6
What if you don't have the drain hose that came with it can you use any hose?
Jul 30, 2012 | Heating & Cooling
Everstar mpk 10 cr 1 manual, have an error code of P-1
It means that the little drawer for the water on the side is full of water or that it is not closed completly. In the water drawer there is a switch that makes it turn off the AC if it is running ,then it will give you a P1 code.
Make sure the water drawer is empty of water then. put the drawer back in carefully and gently, the switch that is built into the drawer will make contacts and your problem should go away. you might have to unplug the unit from the wall for it to clear the problem after doing the above steps.
Also here is a link to their site, Midea the company that makes these MPK-10CR units. For the owners manuel http://www.supportuscenter.com/documents/MPK_Manual.pdf
http://www.supportuscenter.com/pilot.asp
Sep 11, 2009 | Everstar Portable Heater/Fan
Need owners manual for Everstar Portable AC MPM1-10CR-BB6
Needed the manual to clarify a P1 error message. Figured how to fix the error P1 on my own. there are two drains on the unit, one is always open as an overflow drip, the other at bottom of unit has a plug. I opened the plug at the bottom of the unit, drained the water, and the P1 error code cleared.
Jun 25, 2009 | Danby DPAC8020 Air Conditioner
My unit has a P1 error and has stopped
Pull out the water container. Make sure the black floater switch is not stuck or impedes from working properly. If this doesn't work, need to look at replacing this
Jun 25, 2009 | Heating & Cooling
Need manual for EVERSTAR model MPM1-10CR-BB6 air conditioner
This site has the manual. It doesn't state the same model, but it's the same manual.
http://www.supportuscenter.com/product.asp?specific=90
May 17, 2009 | Heating & Cooling
Everstar portable ac unit displaying error message P1. The unit turned itself off and will not come back on. It had no symptoms of not working well before turning off.
According to my Everstar manual, P-1 is a drainage problem.
EverStar owners manual pg. 16 -
1. Release the drain hose from the ruber clip and pull out the rubber plug, let the drain hose slant down to a water container.
2. Press the TURBO button on the unit control panel for more than 3 seconds and the WATER INDICATOR light begins flashing. It indicates the forced water drainage feature is activated.
3. Waiting until the WATER INDICATOR light stops flashing and there is no water flow.
4. After the water has drained, remember to secure the drain hose and plug in the upright position and clip it to the unit.
The unit will return to normal operation.
....I had to do this and it worked - Good luck!
Mar 25, 2009 | Heating & Cooling
Everstar Air Conditioner
probably, the p1 signals that the water pan is either full or not sitting properly. There is a small lever that it pushes when the tray is pushed in. It is a switch that might have pushed out of its housing. Mine had and I had to dissasemble the unit to get the switch back in place, then it worked fine. Good luck. Dean
Aug 06, 2008 | Office Equipment & Supplies
Danby DPAC8020 Air Conditioner Logo
11,783 people viewed this question
Top Danby Heating & Cooling Experts
Dennis Boxerman
mintvl
Level 1 Expert
Bill Long
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
