Question about Epson Stylus CX6600 All-In-One InkJet Printer
COLOURS WILL NOT WORK ON PRINTER
BLACK INK VERY FAINT ON PRINT AND COLOUR DO NOT WORK AT ALL PUT IN CONPLEAT NEW SET OF INK CARTAGES BUT STILL THE SAME
  • Anonymous Mar 26, 2014
    Print is so light it is not readable. I put in new ink cartage. Do the ink jet printer have print heads?
  • Epson Master
  • 705 Answers
What does the nozzle check pattern show? If the check pattern is patchy or has lines missing then you need to clean the head. If you are using rubbish compatible inks instead of the genuine stuff then doing head cleans may make the situation worse.
See my previous post about under head cleaning and follow the instructions there.
If the check pattern is good you may be experiencing a common CX problem with one of the vacuum pipes. A rescue kit is available from tradebit
Posted on Nov 16, 2007
SOURCE:
I have message "Cartridge Error". I have established that the colour cartridge seems to be faulty. It is old and only replaced once because I do not actually need colour, use mainly black printing onl
Hi and welcome to fixya
You can print black pages with the color cartage. HOW ? just when you select the size of the paper A4 then ther is an option of colored printing or black if you have ink in the color cartage then it can be done that you can print black pages with that cartage
thanks hope that will be helpful
Dec 08, 2012 | HP Officejet 5610 All-In-One InkJet...
Printer only prints in black/white. have put new
It could be the print setting on your computer.
If you're using Windows, with your document open, go to File > Properties/Preferences. In the Print Setup tab, make sure to select "Print using all available ink" in the Ink Use section.
On Mac you can select Color in Print Setting in any expanded print dialog.
Sep 01, 2011 | Lexmark Interpret S405 Wireless All-in-One...
I HAVE MX 300 PRINTER IN WHICH THE COLOUR CARTRIDGE FINSHES OFF QUICKLY THOUGH I DO NOT USE COLOUR PRINTING PLEASE ADVISE
You can goto printer settings and choose black and white printing only, it will be there in one of the options of your printer.If your printer has only one cartage Color, then when you rpint in black and white you are using all 3 colors to create this black and white, nothing much you can do there. But if your printer has two cartages 1 black&white, and 1 color then tell it in settings to print only black and white, hope this helps
Nov 29, 2009 | Canon MX300 Office All-In-One Printer
My hp deskjet 1280 will not print yellow
Hello, this is Harry from www.BusinessSpread.co.uk.
We had the exact same problem when printing, we used 3 different 78 colour ink cartages and they all said 100% full but did not work. We then had a look at the dates on the box and they were all expired so when buying ink from anywhere even PC world or Curry’s always look at the expiry date.
Today I went to PC world and purchased a new 78 ink which said expires July 2011 and it works perfectly fine.
Regards,
Businessspread.co.uk
May 09, 2009 | HP DeskJet 1280 InkJet Printer
Printer is refusing to print colour, with full colour ink tank.
Have you checked the ink levels in your cartridges? Ink can dry due to usage and also due to prolonged non usage.
Apr 13, 2009 | HP LaserJet 1100 Printer
My epson stylus cx3200 is not printing in black but does print colour even though ink levels in both colour and black cartridges are fine
If you are brave I had the same problem. I removed my ink disconnected the data ribbon to the Head. Took off the nozzles. I used a child's med. syringe with the tube. Filled it will rubbing alcohol. placed the tube on the head where the ink cartage attaches and slowly put pressure on the syringe. Be care full it will flush the black ink everywhere. I kept doing this till the black was all flushed out. Put it back together. make sure you put the ribbons back in the right way. Mine works great.
Mar 04, 2009 | Epson Stylus CX3200 All-In-One InkJet...
The Printer is not sensing the Black Cartage
if their cartridge worked and yours did not. buy a new cartridge.
Jan 27, 2009 | HP Officejet Pro K5300 Laser Printer
Printing problem with Canon iP2600
Appears to be a defective color cartridge. Verify the printing is not set to fast or draft.
Dec 15, 2008 | Canon Pixma iP2600 Photo InkJet Printer
Epson Stylus CX6600 All-In-One InkJet Printer Logo
48 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
