FixYa.com
Tags:
Ricoh Aficio 450 Copier
Ricoh aficio 450 (by 2 users)
posted by dann5 on Oct 11, 2007
whats the average life  on a drum of aficio 450? . I have a copier aficio 450 that it prints half of page very ligth even when you set it to darker , any ideas ?please help asp , need printer for a school. thanks to anyone
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by elbahy, posted on Dec 15, 2007
Show machine No. holidays 350
Best Solution
posted on Oct 12, 2007
Helpful (85)
jules_09
Rank:Wiz Wiz
Rating: 77%, 53 votes
hi im jules_09,the average copy life as we call it is 60,000 copies after that you will replace the drum,cleaning blade and the developer.see first if the copy meter is already above 60,000 copies then about the print i think it time for you to replace all that is mentioned
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Nov 17, 2007
Not Rated (0)
Gunslinger
Rank:Master Master
Rating: 87%, 12 votes
The only thing you would be able to check is the shield glass which if I remember correctly is below your toner handle. lift you toner handle an you should see a small rectangular cutout the the glass slides into. Pull this out and clean this off. If this doesn't help you will need your pcu rebuilt. If you are handy with a screwdriver I could sell you the parts to fix this yourself for much less than dealer would charge.
Solution #3
posted on Nov 02, 2007
Not Rated (0)
Kanodianitin
Rank:Apprentice Apprentice
Rating: 85%, 1 votes
Hi Dann,
Take a print out of copy count for isolating the issue with Drum unit (PCU) and optics.
1.f you get fine print on copy count optics need to be cleaned.
2. Clean shield glass of laser unit.
3. Half print or foggy image is certain issue with laser unit and needs to cleaned.
4. Drum runsmore than 60000BUT With a error on display( photoconductor unit needs to replaced) and thats not a problem.
Can you Help with these Copiers problems?
Copiers
blotches
my Xerox Workcentre M15 has... Answer This...
Copiers
PANASONIC DP-1515P DRIVER
hello: i need the panasonic... Answer This...
Copiers
canon error
canon machina ir 5055n give... Answer This...
Copiers
copystar 2014 UF error code...
I have a copystar 2014 with a... Answer This...
Copiers
smudges on printout
Goodday Jay, Thanks for the... Answer This...
Repair Service
Find Copier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
