Question about Yamaha RX-V995 Receiver
Mp3 connect yamaha rx-v995 ---> muddy sound
Connecting using any of the inputs leads to the same distorted, muddy sound, like the speakers are blown, which they are not. Player does fine with powered speakers or headphones; receiver and speakers are fine with other sources.
  • brookefox May 09, 2009
    Thanks much. I'll give that a whirl. My only doubt comes from the fat that it sounds great with powered speakers.
  • brookefox May 10, 2009
    In the MP3 player there are various preset EQ settings and custom EQ, but no settings or output controls for external devices other than those (that I can discern, anyway). The connection to the active speakers and the receiver is different, of course. I don't doubt that it is possible to achieve great improvement through tweaking of the EQ setings but I was hoping to find something easier as it looks like that would be very time consuming and error prone. Given that the situation is a very typical one, I was hoping to find a set of presets or specific recommendations.
  • 757 Answers
Try getting into the configuration menu of the MP3 player and adjust the output controls for external devices....it sounds to me like it might be too high and/or the wrong output decoding.
Posted on May 09, 2009
  • Mike LaPres
    Mike LaPres May 10, 2009
    But you also indicate that the receiver and speakers are fine with other sources.
    But here is the important question:
    Does the MP3 player connect to the active speakers and to your receiver the same way?
    If it operates how you'd like with active speakers but not the passive speakers then it is a mismatched configuration between the output gain of the MP3 player to the amplifier section of the receiver.
  • Mike LaPres
    You still may be able to connect to the receiver in the same manner as you would to your powered speakers if it is that you are using the heaphone jack from the player. There might be an adapter available to split the headphone output to L&R RCA. Is it connecting now to the receiver straight from USB as it would to your computer?
How do you connect a Nakamichi surround sound system to my Phillips tv model 42PF7220A/37
I'm confused. The message header shows a problem with a Yamaha RX-V995 receiver.
As for connecting a Nakamichi (or any surround system) to a TV - the only connection would be the Monitor output (video connection) to an appropriate video input of your TV.
If it is a Nakamichi, it is a little older and probly predates the invention of HDMI cables. My guess is you will either use the S video output or Composite video output to the TV's input with similar connections.
This allows you to route whatever video sources you have connected to the Nakamichi to the TV.
May 07, 2014 | Yamaha RX-V995 Receiver
Yamaha RX-V995: Is there anyway to only listen to
Assuming you have the same Model Variant ( I'm not sure if Yamaha varies model from Country to Country) I just switch mine to effect off ( 2 Channel) to remove the surround component so that only A or B speaker pairs work.That should fix it unless I am mistaken.
Jul 19, 2010 | Yamaha RX-V995 Receiver
Yamaha RX-V663 powers off when I hit the volume up/down button. Used to work fine, but now it doesn't after I hooked up HDMI cables in back. Tried reseating them, but no luck. What am I missing.
Not sure If I'm on the money with this one but make sure none of your speaker leads wires are touching the case or each other. This may be causing the protection circuitry to cut in. ( I did this to my Yamaha when I plugged in yet another lead into the back )
May 02, 2010 | Yamaha RX-V995 Receiver
Hi i have a yamaha rx-v995 reciver and just percase new pioneer dv-320 dvd. it's output connection is with coaxial conector.when i connect the coaxial to the coaxial onector of my yamaha reciver i dond get...
1) Check to see if the screen says "EXT DECODER". If it does, press the EXT DECODER button again and this should fix the problem
2) Press input mode button until the display reads auto or digital. It may be set to analog.
Nov 16, 2009 | Yamaha RX-V995 Receiver
RX-V995 Earthing issue
your main lead wire contains only two core, could be brown, black, anyway..open the cover of the unit, and change the cord, get three core main wire, and take the old one off, replace the other one, which should have earth, you can screw it to the transfomer base, try this
Nov 09, 2009 | Yamaha RX-V995 Receiver
HUM noise at PSW3000 if i connect the Yamaha RX-V995
the conections some where are dirty you need to unplug everything clean all connections and the hum will go away
Nov 06, 2009 | KEF Audio PSW 3000 Subwoofer
Yamaha rx-v995
I'm in the same boat w/ my v995 - it has a bad volume motor and its $150 for the part. You want to sell your v995? Adam
Mar 01, 2009 | Yamaha RX-V995 Receiver
Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Jan 02, 2009 | Yamaha RX-V995 Receiver
Yamaha RV1103 receiver
YOU SHOULD BE ABLE TO RUN SOME PHONO LEADS TO THE AMP FROM THE CONECTORS ON THE BACK OF TV THE SOUND CONNECTORS ARE USUALLY WHITE AND RED JUST CONNECT THE CORRESPONDING LEADS TO THE SAME COLOURED CONNECTORS ON THE AMP
Sep 30, 2008 | Yamaha RX-V995 Receiver
No zone 2 sound coming from yamaha amp rx-v861
Had same problem. A and B speakers are basically connected together, and there is no way to get the same volume out of each speaker. This is not a multi-source receiver like Onkyo. Zone 2 needs to go to a seperate amplifier and select teh correct source on the fornt,
Jun 29, 2008 | Yamaha RX-V995 Receiver
Yamaha RX-V995 Receiver Logo
219 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
