Question about Dryers
Where is the belt located on a whirlpool dryer?
  • Dryers Master
  • 1,070 Answers
In most cases, you have to kill power (unplug unit) and pull the top loose from the front. It should hinge or swing up and back out of your way. Your belt is wrapped around the drum, tension pulley (spring loaded accessable from the back), and the pulley on the motor.
Hope this helps and Good Luck on your project.
Posted on May 09, 2009
HOW DO I LOCATE THE HEATING ELEMENT ON THE 6TH SENSE DRYER
take the back panel off it is located in the rear.
Mar 19, 2010 | Whirlpool Dryers
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
DRUM NOT MOVING ON WHIRLPOOL ELEC DRYER
the belt is off or broken, changing the belt yourself can be tricky, you must remove the front bulkhead and door/panel assy, then you have to route the belt correctly from th motor to the belt tensioner, you may want to call a tech.
Jan 06, 2010 | Whirlpool LER5636P Electric Dryer
Whirlpool imperial series dryer heats not spinning
This problem is almost always a broken belt. Yes you can do it yourself.
Go to repairclinic. com and put in your model number for the exploded view of your dryer. Locate the belt part number and belt orientation.
Jan 03, 2010 | Whirlpool Dryers
Need model number or part number for whilpool dryer
The model number for your dryer is usually located on a plate or sticker inside the door on the body of the dryer hidden by the closed door.
The most common (but not the only) belt number for Whirlpool dryers is 341241 and the idler arm for that common dryer has tabs that fit into the floor beneath the motor drive pulley. Take a loop of the belt with ribs inside the loop and pass it through the opening below the roller and loop it around the motor pulley. If it's the most common unit the end result should look like the image below for Whirlpool:
Belt Configuration
Good Luck
Sep 07, 2009 | Whirlpool Dryers
Whirlpool dryer froze and wont tumble just makes noise where try
Hi, This dryser only has 1 belt. When you chacked the belt, was the belt located in the middle of the drum?
This model has an idler pulley that is no longer being used. They have went back to the roller style idler which is easier on the belt.
Raise the top and then remove the 2 screws holding the front to the cabinet. Remove the front cabinet and locate the idler next to the motor pulley. Look at the belt while you have the front off and see if there is any bad spots in it.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 02, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer len2000pw0, starts fine, heats up, but will not spin?
Hi, you will need to change the belt. Here is how:
Normal 0 , UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off.
There should be instructions that came with the belt. I will try and explain how this goes on. The idler pulley fits in a slot right in front of the motor. Put the belt over the drum with ribs touching drum. Now, thread the belt through the idler pulley wheel and bracket and set the belt on the motor pulley. The ribs should rest in the grooves on the motor pulley.
I hope this helps you. If I can assist you further, please let me know. Please rate me performance so that others as well as myself will know how I am doing.
Thanks
Vic
Jun 05, 2009 | Whirlpool LEN2000PW Dryer
The dryer will get hot but the drum will not go around
More than likely, the belt is broken. Otherwise, the drum motor is shot. (That's not very likely though).
Apr 22, 2009 | Whirlpool LGR5636L Gas Dryer
How to install a belt on a Whirlpool dryer model LEW0050PQ?
The tech I paid to replace the belt opened the case from the top and the back, and pulled the drum back away from the front, keeping the drum attached to the back panel. This exposed the motor and the broken belt, which had been cut by the motor drive wheel, probably because the drum was too heavy. Don't you just love renters?
Mar 26, 2009 | Whirlpool LEW0050P Electric Dryer
2003 whirlpool dryer problems
full size free standing whirlpool dryer???? part number 341241, on a scale 1-10 it might be a 3 for a first timer, the package i belive even comes with direction on installing
May 12, 2008 | Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
