Hi, the rubber roller that feeds the paper seems to have black gunk on it. I pulled some off and was able to feed the paper through it, but I'm wondering if I need a new rubber roller???? I love this calculator even though it's old. Thanks, Maura
SOURCE: Loading Paper into a Casio Calculator
This isn't too complicated. And for the lazy guy that just put a phone number for the fix, what the heck do we need FixYa for anyway? :\ For cryin' out loud! :) )
1. Slide the clear plastic cover toward the back to remove and flip of the metal spool holder up. Place the roll of paper on the holder. (Make sure the paper drops off the "back" of the spool for proper feed.)
2. Feed the paper into the bottom slot at the **** end of the calculator.
3. Feed the paper through that bottom slot along the inside case under the black guide inside. If you tilt the calculator correctly, you can look inside and see there is a way to slide the paper under the guide.
4. Making sure the paper slides as far as it can, press the FEED button until the paper starts feeding.
5. Feed enough paper to slide through the clear plastic cover and you're all set.
This isn't factory, it's just what I figured out playing with the thing. If you can think of a better way of explaining the procedure, by all means edit this and post!
God bless!!
Maridian
SOURCE: I believe the rubber roller that feeds the paper
i don't know this particular calc very well, but on most calcs, the paper feeds between the rubber one and a plastic idler roller that is on a shaft below the rubber one. if you can see the rubber roller turning, check the plastic one as it can sometimes slide to one side or the other, and bind up causing paper to not feed. you can usually get at it with a small screwdriver or something like that and center it back and that will take care of problem.
hth,
razors
I fixed. Opening the calculator the roller was melted, removed all posible residual and then cut 3 1/2” of electric tape and split about the wide of the roller and roll on the roller in the same way that it move to feed the paper.Casio NR-8TE AND IS WORKING FINE NOW.
