Question about Brother IntelliFAX 4100 Laser Fax
Sleep Mode showing on the screen
I am not receiving any fax
    Problem Solver:
  • 7 Answers
SLEEP MODE MEANS NOTHING UNLESS YOUR USING IT WITH A PRINTER IT IS SAYING SLEEP BECUSE IT IS WAITING FOR A PRINT JOB IF YIOU ARE NOT REC. CHECK THE MODE KEY AND AMKE SURE IT IS SET TO FAX ONLY
Posted on Oct 24, 2007
  • 26 Answers
SOURCE: Sleep
You should be able to send and recieve faxs in the sleep mode. You need to reset the machine, pull out the plug, hold down the menue key while you plug the machine in. When maintanence comes up in the display enter 01 and wait. Whwn maintanence comes up again press 99. DO NOT PRESS ANY OTHER NUMBERS OR YOU WILL DAMAGE THE MACHINE BEYOND REPAIR. Your fax is now reset and completley empty, you will have to put in your name etc and sleep mode will be set to "0" minutes
Posted on May 20, 2007
boyrevel
  • 71 Answers
SOURCE: Sleep mode
Press Menu/Set, 1, 6, 2 (2. Sleep Time should be displayed) Simultaneously press Start and Options at the same time Press Menu/Set Press Stop Exit This will turn the sleep mode off. The new setting will apply after the next time the machine copies, prints or is turned off and on.
Posted on Aug 14, 2007
  • 22 Answers
SOURCE: "Receiving Sleep" on Brother Fax 4100
The sleep mode is only a power save mode. You may not have the machine in the correct fax receive mode. If the machine is on a line by itself it needs to be set to fax only, if line is shared with a telephone it needs to be in fax/telephone, if you share the machine with an answering machine it needs to be in TAD mode, and so forth. Each time you press the MODE key it will change the receive mode. Most people hit this key by mistake and change the MODE and the unit will not pick up calls. Press the MODE key until you are in the correct mode. To make sure the machine will print, press reports and then the 1, this will print a help list. If the help list prints you know that the machine works. Then check to make sure the machine is in the correct fax receive mode.
Posted on Oct 04, 2007
SOURCE: How can we exit Sleep mode?
what was the password to remove form the sleep mode
Posted on Sep 04, 2008
  • 46 Answers
SOURCE: Our Brother Fax Machine 2820 stays in sleep mode.
Machine goes into sleep mode when not being used When it recieves or you copy something it will come out of sleep mode If its not recieving then you need to check your recieving settings
Posted on Jun 11, 2009
MFC-7840w printer, how do i take it off sleep mode?
  • The control panel features a series of buttons as well as an LED "Status" screen.
  • Press the "MENU" button. Go to INITIAL SETUP, select "FAX" select "RECEIVE MODE" change to F/T
  • If you are using the Brother on a line by itself, set it to "Fax." If you are using the Brother on a line that also shares a telephone, set it to "Fax/Telephone." If you are using the Brother IntelliFax along with ananswering machine, set it to "TAD." Once you set your IntelliFax to the appropriate mode, the unit will leave "Sleep" mode and be ready for use.
  • Select "GENERAL SETUP" go to "ECOLOGY" and #2 is SLEEP TIME = adjust to 60 sec. This keeps the machine from becoming idle/sleep mode for a longer period.
    Sep 25, 2010 | Office Equipment & Supplies
    The fax continually registers as being in "sleep" mode. Says it's in "Sleep" mode all day even when it is receiving and or sending out. How do I correct that?
    Setting the Sleep Mode reduces power consumption while the machine is idle.
    You can choose how long the machine is idle (from 00 to 99 minutes) before it drops into sleep mode.
    The timer automatically resets itself after the machine
    receives a fax or PC data, or makes a copy. The default setting is 5 minutes.
    1 Press Menu, 1, 8.
    2 Use the Dial pad to enter the length of
    time the machine is idle before it drops
    into sleep mode (00 to 99 minutes), and then press Set.
    3 Press Stop/Exit.
    Jun 15, 2010 | Brother IntelliFax-4100e Fax
    Our fax is on sleep mode...how do we get it off that mode and able to recieve faxes?
    you can tun it off by using the settings setup . it should send and receive even in sleep mode
    Jan 08, 2010 | Brother IntelliFAX 5750e Laser Fax
    How to stop sleep mode?
    Sleep Mode
    You can choose how long the FAX/MFC is idle (from 00 to 99 minutes) before
    it drops into sleep mode. The timer automatically resets itself after the machine
    receives a fax or PC data or makes a copy. The default setting is 0 minutes.
    1 Press Menu/Set, 1, 7.
    time the machine is idle before it drops into sleep mode (00 to 99 minutes),
    and then press Menu/Set.
    3 Press Stop/Exit.
    Dec 01, 2009 | Brother IntelliFAX 2800 Laser Fax
    My machine is also set to sleep mode and cannot rcv. faxes!
    Sleep mode does not affect the reception of faxe check receive settings instead
    Aug 28, 2009 | Brother IntelliFAX 2800 Laser Fax
    Fax machine sleep mode
    have you tried to unplug the machine from the wall and then plug it back in this reboots the machine
    Dec 23, 2008 | Brother IntelliFAX 2800 Laser Fax
    BROTHER FAX MACHINE 2800
    Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
    1. Press MENU/SET, 1 (General Setup), 7 (Sleep Mode).
    2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
    3. Press the MENU/SET key to confirm your choice.
    4. Press the STOP/EXIT key to exit the menu.
    NOTE: If you frequently print, copy, or fax, set the idle time long
    enough to insure that you will not always have to wait for the Brother machine to warm up.
    Dec 02, 2008 | Brother IntelliFAX 2800 Laser Fax
    you might have to change the settings for the switching time into stand-by. plz have a look into the manual which describes these settings (zero seconds are possible)
    Jan 09, 2008 | Brother MFC-5840CN All-In-One InkJet...
    Intellifax 2820
    Make sure it is set to autorecieve and not manual recieve, not too sure off the top of my head where in the menus you go to switch off sleep mode but if you print out a "Menu Map" this will show you every part of the menu and which to select to change it Hope this helps Cops
    Sep 04, 2007 | Brother IntelliFax-2820 Laser Fax
    Brother IntelliFAX 4100 Laser Fax Logo
    915 people viewed this question
    James Cagle
    James Cagle
    ctnozil
    Victorman
    Victorman
