Question about Dryers
Squeaky Dryer, want to take front off to examine
How do I take the front off the DE04-US5
  • 31 Answers
Many dryers have two screws near the bottom front. Take out the screws and swing the front off, bottom first. The top spring clips will release when you pull out the bottom. Be careful with the wires to the door switch. They are usually long enough so you can lean the front panel against the side of the dryer, or just unplug the wires. Of course, unplug the dryer first. The squeak is probably one of the drum rollers. To put the front panel back on, line up the top with the panel at an angle, then swing in the bottom.
Posted on May 09, 2009
My Maytag Depenable Care Gas Dryer has become very squeaky when the barrell spins. i took off the front panel and sprayed WD-40 on the backsides with the Plastic wheels and it went away for about 10...
Probably best to grease the wheels (called drum support rollers) rather than use WD-40 because that strips away the lubrication. It will also pay to check the drum support glides under the front of the drum. Worst case you may have to replace the support rollers.
Jun 26, 2011 | Maytag Dependable Care LAT9706
My dryer makes a squeaky sound during adrying
the front guides around the drum or the bearing at the back may be failing partially or bearings in the motor may have started to noise,there is also the chance that the belt idle pulleys have started to wear,more than lightly it is the belt idle pulleys that have dried up or the bushings have started to wear
Jun 30, 2010 | Kenmore 94702 Front Load Stacked Washer /...
Squeaky DE dryer
there is a ball bearing in the back of tub in a plastic housing that wears out or the front glides on front of tub are wearing out,you can pop the top off and the front to check them out-mike
Jan 30, 2010 | GE Profile DPSB619ED Electric Dryer
My danby dryer DCD 5505W is making a squeaky noise.
You need to change its Drum bearing and front rollers. Also replace its Drum glider/pads.
Jan 09, 2010 | Danby DCD5505W Electric Dryer
Fisher paykel dryer DE04-US6 just get a buzz sound when i push start button.
Open up the door and push the door switch and hit the start button and try to turn the drum by the baffle in the dryer and it it starts to go then you need a new motor.
Aug 20, 2009 | Fisher and Paykel Dryers
I'M TRYING TO REPLACE A SQUEEKY PULLEY
The back does not come off.
Unplug the dryer.
Remove the top. Then the front panel. Then the front support. Then the belt. Then the drum.
Probably not a squeaky pulley.
Probably a bad drum bearing.
Mar 11, 2009 | GE DBXR453EV Dryer
Cannot tighten the drive belt on my Fisher and Paykel DE04 electric dryer.
Remove the belt from the motor and pull it out of the tensioner. Put it back through the tensiner from the other side of the bracket. (If you put it in right to left, this time, put it in left to right ). The belt will seem very tight to try to get onto the motor but, it's supposed to.
Feb 20, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Nextra7 condenser dryer making squeaky noises
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
tukuymhg
Feb 14, 2009 | Hoover Nextra 160 HNWF 3137 Front Load...
Put dryer belt on maytag dryer
generic maytag dryer belt replacement
type 1:older models by Maytag with lintscreen under door
  • unplug dryer
  • remove 2 screws from under front panel
  • tilt front panel up from the bottom and unclip top
  • remove door switch wires
  • set front panel aside
  • remove front drum retainer 2 screws each side
type 2:newer models by whirlpool lint screen in top cover
  • unplug dryer
  • remove lint screen
  • remove 2 screws under lint screen
  • with putty knife or other blunt blade
    unclip spring clips at front corners of top panel
  • remove 1 screw each side of front panel 1/2 way from top
  • remopve door switch wires
  • tilt front panel down and unclip
all
  • withdraw drum forward
  • examine drum rollers for wear
    if worn or locked replace in pairs
  • examine felts and nylon glides(if fitted) for wear
    if worn replace
  • examin case floor for tensioner
    (sometimes broken belt ends pull the tensioner out of place its easy to see the slots on the case floor for the 2 feet and spring, looks like a power socket)
  • loop new belt around drum at wear mark of old belt
  • insert drum
  • loop belt around motor pulley
  • pull tensioner to end of travel against spring
  • loop belt around tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
Oct 29, 2008 | Maytag Dryers
Dryers Logo
73 people viewed this question
Top Dryers Experts
