Reverse is out (major grinding, and quad doesn't
It is a pretty big job for a weekend mechanic. You will need some special tools > Impact driver, torque wrench, expanding 'C' ring pliers, case splitter and flywheel puller. The entire engine, top end and bottom end must be torn down. Don't try it without the manual. The clicking noise is probably a broken tooth on a gear. ALWAYS replace gears in sets, ALWAYS. The grinding is most likely a bad bearing.
