Question about SanDisk Sansa e250 MP3 Player
Edgar rosas no funciona mi sansa e250
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
SOURCE:
Quero eliminar mi cuenta porque no me funciona su progra y me están quitando mucho dinero
You'll have to contact Quero what ever that is. We can't help you.
Sep 20, 2016 | Computers & Internet
Tip
I apprepcaite your code it can create and hide folder but when you run the code...
In an earlier post I had written about how to create an invisible folder. That’s a method to create a merely invisible folder with no real protection.
Now, here we will see how to create a folder that will not just be invisible, but also require a password to reveal it and open it. The best part is that you don’t need any special software to do this. Just plain old Notepad is all that you need.
Here is the code that you need:
cls
@ECHO OFF
title Folder Personal
if EXIST “Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}” goto UNLOCK
if NOT EXIST Personal goto MDLOCKER
:CONFIRM
echo Are you sure u want to Lock the folder(Y/N)
set/p “cho=>”
if %cho%==Y goto LOCK
if %cho%==y goto LOCK
if %cho%==n goto END
if %cho%==N goto END
echo Invalid choice.
goto CONFIRM
:LOCK
ren Personal “Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}”
attrib +h +s “Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}”
echo Folder locked
goto End
:UNLOCK
echo Enter password to Unlock folder
set/p “pass=>”
if NOT %pass%==pwd123 HERE goto FAIL
attrib -h -s “Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}”
ren “Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}” Personal
echo Folder Unlocked successfully
goto End
:FAIL
echo Invalid password
goto end
:MDLOCKER
md Personal
echo Personal created successfully
goto End
:End
Now here is what you need to do:
Just copy the above code and paste it into Notepad. Save it by giving it any name you choose. Assuming, the file is called secret.txt, change the extension to ‘.bat‘ so that the new name becomes secret.bat. What you get is a batch file. You could actually save one step by saving the file in Notepad directly as secret.bat by enclosing the file name like this: “secret.bat” . This batch file is the one that you need. You can edit this batch file to change the folder name and the password. To change the name of the folder that is created, change the ‘Personal’ (in bold in the above code) to any another name you choose. Likewise change the ‘pwd123′ (in red in the code) to anything else.
Now let’s see how to use it. Place the file in the location where you would like to create your protected folder. Run the batch file by double clicking on it. This will create a folder named Personal in the same location as the batch file. You can now open this folder and place any files in it. Once you are finished, run the batch file again. You will be asked whether you want to lock the folder. Entry ‘Y’ (for Yes) and hit Enter. The folder becomes invisible. To retrieve the folder, run the batch file again. You will be prompted to enter the password. Enter the password, hit enter and voila! the folder appears.
Important: The batch file acts like a key to open the locked folder. So once you have created and locked a folder, do not keep the batch file in the same location since anybody can open the batch file and view your password. So I would suggest that you keep the batch file in a separate and safe place or better still keep it on your pen drive or flash drive. That way when you want to open the folder just copy the batch file to the location where you have your protected folder and run it.
Do remember that the above method is not intended to act as a substitute for the numerous free and commercial softwares that are specifically designed to provide security and encryption to your data.
Update: I got comments saying the code does not work. Of course I did check it before posting it here. But I have identified the problem. The problem is with the straight double quotes used in the code in this post. Once you copy the code you would also need to change each of the double quotes with your keyboard double quotes. That might seem a lot of work for some. So I thought it would be easier to give away the batch file itself. You can download the file here. (Use right-click and ‘Save Target as’ or ‘Save Link as’).
on Jul 25, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Mi lavadora crosley no funciona solo dos luces enciende
Mi lavadora prenden las 2 luces primera y ?ltima lava un minuto se para y centrifuga
Jan 24, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
La calefaccion de mi auto no funciona que debo hacer?
Mi caqrro es Nissan Murano 05 no trabaja la calefaccion que puedo hacer o que pasos seguir?
Dec 03, 2010 | 1996 Saturn SL
Help please
Try resetting everything back to factory setting or download its drivers from the official website and install them.
That should fix your problem!!!!
Thank You!!!!!!!!!!!!!!
Jul 03, 2008 | SanDisk Sansa m240 MP3 Player
Problems with mi Sansa
A Firmware upgrade may help.Connect it to the computer with usb and log onto the Sandisk website and follow the instructions,worth a try
Feb 18, 2008 | SanDisk Sansa e250 MP3 Player
Edgar
debes explicar cual es el problema.
Oct 11, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250
Switch the usb mode from what ever it is to a different one, and then it should reset it.
Mar 29, 2007 | SanDisk Sansa e250 MP3 Player
Pls help me asp
por mi sansa no funciona se en cuentra en initializing
Dec 25, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
106 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
