Question about Garden
My pressure washer isnt getting pressure. - Garden
    New Friend:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 5 Answers
Http://mammothtruckwash.com/
Please visit this site any quesry for Pressure Wash this wite help you.
Posted on Nov 11, 2016
No water pressure when wand is squeezed
check the nozzle isnt blocked easiest way to do this is remove pipe from lance handle and see if it fires water at pressure when lance isnt attached if it does fire water at pressure then your spray nozzle is blocked or turned off at the nozzle the nozzle can sometimes spin to far round and close
Apr 21, 2015 | Garden
How do i remove gas tank cover?
Hey Chuck
Not sure of the model washer you have but most Briggs tank covers only have 2 bolts on top holding the cover to the tank. If the isnt it can you be more specific with a model number?
Feb 20, 2015 | Craftsman 2700 PSI Briggs Stratton...
I switch the pressure washer on motor starts pressure builds up motor stops. OK pull the trigger on the lance the moter starts sounds different water pressure low. Release trigger motor still runs.
It isnt very clear your explanation of the problem but what type washer do you have first? It sounds like you have a bad unloader or need a new variable nozzle tip. Can you explain in more clear detail. Thanks
Feb 16, 2015 | Garden
Where is the oil drain plug located on a Homelite 2700 psi 2.3 GPM Honda Gas Pressure Washer?
There is drain plug, surprisingly. You basically have to tip the washer over to the side opposite of the exhaust. I like to take the wheel off first. It is much easier this way. You don't want oil to get in the exhaust Or you could get something like a turkey baster and pull it out. There isnt much oil in there so it isn't that difficult.
Let me know if you need more assistance.
Travis
Jun 06, 2013 | Homelite Ut80993 Honda Gas Pressure Washer
Motor runs fine, no pressure
do you h ave water supply make sure inlet screen isnt clogged. 0utlet hose or nozzle isnt clogged ,turn up pressure control valve could be bypass valve problem or internal valves are stuck or ddestroyed also pistons did it ever freeze with water in it during cold weather?
Jul 05, 2011 | Garden
I have a honda 8.0 GX240 on a generator and when i go to start it. It acts like it isnt getting a spark the engine isnt turning over i checked the plug and fuel lines and still nothing
Is there sufficient oil in the crankcase? Most all generators have an oil level sensor that shuts down the ignition if the oil level gets low.
Jul 23, 2010 | Honda 8 HP Engine
Pressure continues to build then stalls
if te unit builds up pressure then stalls the motor, the unloader isnt working. it bay be corroded or the O ring are U/S
Jul 01, 2010 | Honda 2500 PSI Gas Pressure Washer
John deere 3800psi pressure washer will not siphon detergent. the water end does fine but cannot get any soap
The only way the washer will draw soap into the line is with either the black tip installed or with no tip in wand at all.There is a ball and spring inside of the pipe that the siphon hose hooks to so when you use the washer with alot or even a little pressure the ball is forced up and blockes off the soap inlet port.So if you use it with no tip in the inlet port is open cause the ball isnt being forced up by back pressure.I hope this makes sense.
May 18, 2010 | Dewalt 3800 PSI Pressure Washer
I have a John Deere AC2600Gh power washer and I can't get the soap to work everything else works great it just won't **** the soap up when I am pressure washing I know that it must be something simple to...
Soap will only siphon into hose if there isnt any pressure in the hose attached to the wand.Remove tip from wand and see if it draws soap into hose,back pressure in wand hose will cause the spring and ball to seat/close off the inlet line for the soap otherwise water would blow out of soap line.
May 17, 2010 | Karcher 2500 PSI Pressure Washer
Garden Logo
191 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
