Question about Whirlpool Refrigerators
I have a Whirlpool refrig Mod. ET21PKXGW01, Ser. EH5031670, Mfg. 12-98. It has two split glass shelves on the top. Today, the center screw and one other screw( only 3 total) attaching the shelves to the inside back of the unit broke off, dropping the shelves. Can we access the screws from the outside back of the unit? Is this something fixable without demanding a large number of hours of labor? I am fearing I will have to buy a new one because of this problem. One of the screws has some white stuff around the place it broke off, like it was ripped out of something.
4 Suggested Answers
  • 1073 Answers
SOURCE: water leaking from inside of refrig.I think it could be Ice maker
defrost the freezer drain tube with a hair dryer
Posted on May 09, 2008
SOURCE: The handle on the door of my bottom freezer Amana
Push the handle in and slide it to the side. It should come off and you can tighten the screws and re-attach the same way. I just about destroyed my door before i figured this out.
Posted on Aug 14, 2009
imufo2
  • 3773 Answers
SOURCE: whirlpool frig mod.no.g56shaxmq00-ser.no.sp3968169-frig stopped cooling-cleaned
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Posted on Sep 07, 2011
How to clean the streaks between the inner and outer glass on the oven door
Ugh its not fun and takes two people as you have to split the door with several screws and easy hands... take the door off... there's two tabs at the two hinges either slide them forward backwards or some are spring loaded. however get the door off and begin dis assembly preferably on soft surface. pay attention to how things go back together and begin cleaning have fun....
Sep 02, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
I want to change the light bulb in the oven,.Mod.no.ZDQ695A can you help me.
I will assume that the ZDQ695 bulb replacement procedure is the same as that for the ZDQ695A. The ZDQ695 uses a 25 W appliance light bulb (300 C). Unplug the appliance before starting. Open the oven and remove the racks for space to work. Insert a flat blade screwdriver between the side of the oven and the glass cover above the bulb. With your hand support the cover and pry it away from the wall of the oven until it releases. Push the top of the cover towards the oven wall and use your fingers to pry the bottom of the cover away from the housing. Then remove the cover. Unscrew the old bulb (counterclockwise) and then remove the bulb. Then screw in the new bulb. Replace the glass cover (position the flange so that it is pointing to the back of the oven) by pushing it into the hole to cover the bulb assembly. Replace the shelves and close the oven door before plugging the oven back in.
Zanussi manuals are available here: http://www.zanussi.co.uk/en-gb/Support/Manuals/ . Enter the model number in the search box. Alternatively, the manual for the ZDQ695 is available here: http://kitchen.manualsonline.com/manuals/mfg/zanussi/zdq_695.html . Click on the Get This Manual button.
I hope this helps.
Jul 24, 2011 | Zanussi ZDQ695 Electric Double Oven
Hello (refrigator's glass in broken) third
You can get the glass cut and put in which might work out cheaper with the same thickness than to source the same glass from the Kenmore spares outlet..
Sep 24, 2010 | Kenmore 57382 Side by Side Refrigerator
I have a flat top stove I spilt some type of liquid down between the glass of the oven door and the door it self How do I remove the glass panel
take the door off and put on table. remove screws noting were they go door should "split" apart. clean glass. put back together and use hand tool not screw driver gun
Apr 21, 2010 | Whirlpool RF378 Electric Kitchen Range
How old is my whirlpool washer mod-lsq8243hq0, ser-cj2671399
10-12 years old.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 17, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
AGITOTOR COGS ARE SHOT NEED TO PEPLACE " HOW!"
you can find avideo on you tube, search whirpool washer repair, but youll need to remove the agitaptr. 7/16 screw down the center shaft of agitator, then remove the agitator and split into 2 parts to reveal the agitaotr dogs they simoly slip back into place, part number 80040 in case you havent ordered them yet
Feb 27, 2009 | Whirlpool Washing Machines
Dripping water
YOUR DRAIN FROM FREEZER TO DRAIN PAN IS CLOGGED,LOOK INSIDE TOP BACK OF REFRIG. SHOULD BE DRAIN HOPPER,REMOVE AND CLEAR OUT DRAIN,THANKS-MIKE
May 29, 2008 | Whirlpool ET1FTKXK Top Freezer...
Refrigerators Logo
196 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
