Question about Bosch Dryers
Bosch Classixx dryer door won't close
I have just moved into a rental flat and there is a Bosch Classixx dryer. I can't figure out how to close the door. There is a picture of a hand on the door but I don't see how the mechanism makes it shut. I have searched for the user manual but sadly there is only a French, German and Italian one. Reading the German one, there is a reference to making the door go "click clack" but I can't figure out what the heck that means.
SOURCE: garage door will not open or close
I had the same problem, mine was just the white Sprocket assembly, it stands straight up, there is another one which is the Worm gear, mine was fine. I read on some other post, when you take off the panel, and if you see a lot of white dust (shredded white plastic) then its the gear. Went to Sears warehouse, had the part in stock and replaced it myself. Had to just unbolt the Sprocket assembly from inside (3 bolts), pull out from the top, a little hassel, but got it done. Follow the instructions and you will be fine. Remember after greasing up the sprocket like it says too, take the time to use some silcone spray on the springs and rollers, a lot of people forget to do this, even me...
Posted on Jan 03, 2009
  • 6 Answers
SOURCE: 1999 clk 320 driver door makes loud clicking noise
tony i'm assuming you on about the little bar/plate about an inch wide which seems to rattle about when you open the door??? This is i suppose the check strap and it is designed to hold the door open while not letting the door go too far and become hingebound, bending the hinge and possible damaging the door panel. If it is making a clicking noise it may need a bit of lubrication as it will go over some kind of ball or ridghe to slow it down. If it is completely loose it may be catching something inside the door, possibly the window frame guide or the internal skin of the door. check the mounting bolts on the door post and in the resess on the door and tighten them up and lubricate the rod. You may need to remove internal door skin, window switches etc to get to it. what ever you do do not remove it altogether, as one day the wind may catch it and take the door right around 180 degree causing serious damage, they are not designed to stop the door completely and can stretch if the wind does catch it so check it for damage to as it could effect the door hinges later on
Lee
Posted on Mar 16, 2009
shinn8
  • 85 Answers
SOURCE: kenmore 90 series dryer makes noise and does not want to turn. I can make it spin by hand holding the door switch in, grab it and spin it, and get it to spin again. It keeps doing the same thing when
Your motor is worn out. Bearings worn and not enough power to start it. Motor is not repairable it must be replaced or new dryer. Sorry
Posted on May 20, 2009
dniro592006
  • 121 Answers
SOURCE: door is closed,dryer will not start. Makes click sound and does
you may have a high limit switch out or a cutoff switch bad
Posted on Jun 18, 2009
Illeagle
  • 525 Answers
SOURCE: How to use temperature settings on Bosch Classixx fridge freezer
You can find most user manauls at, www.managemyhome.com, on the right side of the page. You will need the model number off the product information label affixed to the unit.
Posted on Jul 05, 2009
What do's f16 mean on the bosch classixx 6 1200 mean
F16 is a door fault, could be the door is not tightly closed before pressing start, the lock is faulty so the machine is not registering that it is closed or the wiring connection to the door lock is loose.
Apr 10, 2013 | Bosch Washing Machines
Bosch classixx wash and dry - washing machine works fine but dryer does not start and door light does not go out?
if the door light is not going out it is an indication that the door switch is not working. this would also cause it to not run because it thinks the door is still open.
Mar 27, 2013 | Bosch Classixx WVF 2402 Front Load...
Can I stack a Bosch WTL5400 dryer on top of a Bosch Classixx 7 washing machine?
http://www.bosch-home.co.uk/store/product/Connectionpiece/244024
Call the helpline for verification of compatibility prior to ordering.
Feb 06, 2013 | Bosch Axxis WTL 5400 Dryer
Water leak from bottom of machine
This video will show you how to change a door seal on this Bosch Classixx WVF 240S front loader washing machine
we have all bosch repairs in our channel
You can get seals on eBay
Feb 18, 2012 | Bosch Classixx WVF 240S Front Load Washer...
F-16 message showing on my bosch 1200 classixx
Usually means the door is open when the start is pressed, so either you have not closed the door before trying to start the cycle or there is a problem with the door lock
Nov 07, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx condenser dryer won't turn on
try replacing the thermistate fuse link
Dec 04, 2009 | Bosch Axxis WTA4400 Dryers
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
Washing machine malfunction
The latch might be an issue . Move the dial on pump mode . Try activate the door lock with a screw driver move it to the right and should activate the machine. If that works then the latch is the issue and can easily be repaired by removing the door.
Aug 09, 2008 | Bosch Classixx WFL 2462 Front Load Washer
My bosch classixx 1200 express
Close the door and turn the dial to drain
Jan 11, 2018 | Bosch Classixx WFC 2465 Front Load Washer
Replacement door seal/gasket
This video will show you how to replace the Bosch washing machine door seal with step by step guide on the process
Apr 08, 2007 | Bosch Classixx WVF 2402 Front Load...
Dryers Logo
66 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
