Question about Canon PowerShot SD30 Digital Camera
White screen for all outdoor pictures
When in daylight mode or taking pics outside it will take a bright white picture. Spent lots of hours playing with the settings and it just will not take pics outside.
  • Canon Master
  • 4,738 Answers
Sorry to say this sounds like a stuck open shutter mechanism. Put the camera in any mode other than auto and make certain that you turn the flash OFF (you don't want to blind yourself in the following step). Next look down the center of the lens barrel and take a picture. You should see a tiny flicker (wonder where that website got that name?) in the center of the lens as the shutter opens and closes. If no movement is seen then it's likely stuck.
Some people have had success in unsticking Canon S2 IS shutters with the following procedures. It may or may not work for you:
http://www.fixya.com/support/t295396-canon_s2_black_screen
Posted on May 10, 2009
Camera exilim ex-s600 will not take pictures outside,pictures turning out white,yet will take pictures inside ok.is this a worthwhile repair
This seems to be a software problem with your camera. Your camera should, if on AUTO mode, automatically expose your photo accurately. Try half pressing the shutter button (used to take pictures) while outside to adjust focus and exposure, then press the button fully to take picture. If your camera cannot adjust to take a properly exposed picture (not bright white), then it is possible that the shutter speed is stuck on a too high speed, outside daytime shutter speed should be fast (1/1000 sec). Or if your shutter speed adjust accurately, it could be the aperture if the aperture is not small enough for daylight shooting. This is likely a software problem. Try adjusting your settings manually and see if the picture turns out!
Sep 10, 2011 | Casio EXILIM Card EX-S770 Digital Camera
When taking pictures outside or from inside through a window, the picture comes out white with faint red outlines of some images. Inside the house and darker areas it takes pretty good pic's. What can be...
First the camera has a flash to allow for darker areas to be illuminated to capture pictures. The type of camera may bot allow to capture outdoor pictures with the camera flash on. Power off the flash when outdoors to capture daylight pictures.
Jan 30, 2011 | Canon PowerShot SD700 IS Digital ELPH /...
Pictures are over exposed when outside
You may have the settings wrong. Check in the MENU to see if you have it set to "inside" pics rather than outside.
Also the ISO has a lot to do with the exposure. If the iso is set too low outside sunlight pics will be white or overexposed. Try setting ISO on wheel for various options select program mode button and MENU select ISO 120 or 250. These are are pretty general settings. the flash will only engage inside or outside if the light is low ( like evening) I suspect your ISO setting is at a setting that is incompatible with bright sunlight
t
Also select White Balance and move it to DAYLIGHT
take a few shots inside and out to see if there is an improvement.
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Samsung Digimax L60 Digital Camera
Yashica ez digital 6032- 6 mp camera.. i got one sparingly used yashica camera... with above spec... which shows trouble when taking stil pictures outdoors... indoor pictures and video indoors n outdoors...
i am using yashica ez digital 6032 camera but while using SD card of 4GB memory, it is not working. it is asking to format. Pl. help me regarding this problem. Shall i format the camera?
Apr 27, 2010 | Cameras
Problem on outdoor daylight picture taking
hi
try the Exposure button [+/-] will generally be disabled in auto mode
try changing mode to 'P' (Program) mode and then change the exposure by pressing the +/- button and then you would generally see a scale on the LCD now press the left button to decrease the exposure
better more is to reset the camera to the default settings this would set the aperture, shutter, Exposure, LCD brightness and otehr settings to defaults and this would save from any unwanted changes than required
cheers
pls rate if it was any help
Jul 03, 2009 | Samsung Digimax L60 Digital Camera
Canon S2 IS - LCD screen is white after taking an outside picture
the image is all white or has lines through it.Definitely sounds like a repair issue, and has been a previous problem with the camera in the past. There is a defect in the sensor of the camera, and happens quite frequently in this model. I would try and contact Canon about it, and see if they'll repair it for free. If not, its probably going to cost more than the camera is worth to repair it.
Mar 24, 2009 | Canon PowerShot S2 IS Digital Camera
White screen when taking pictures in daylight
Go to the menu screen for LCD contrast and adjust, it sounds like it is to high. Kinda like a back light for a plasma screen.
Oct 23, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Outside picture very dark even with flash / inside better
hI ,
pENTAX K100D DIGITAL CAMERA , TRY TO ADJUST LIGHT EXPOSURE FROM INDOOR TO OUTDOOR.
Dec 11, 2007 | Pentax K100D Digital Camera
Canon PowerShot SD30 Digital Camera Logo
207 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
