Loose internet after 30 minutes. Power remains on machine
Internet shuts down after being on for approxamatly 30 min. Machine does not loose power
  • monte32826 May 09, 2009
    We did what you suggested. Thanks for you help
    Problem Solver:
  • 6 Answers
Hi
sounds like your network card settings allows the device to go on stand by to save power go to device manager expand network adaptors right clck and choose properties and look for a power managenment tab make sure "Allow the computer to turn this device off to save power" is unchecked
Posted on May 09, 2009
Tablet wont turn off
check your tab connector it may be damaged or out of place or loose, if loose it make contact with casing ,thinking is being used by an otg...hope this helps...then just follow trouble shhooting guides, holding down vol then power hold for at least 30 to 45 seconds then release power and then vol, wait about 2 mins before tab completly shuts down ...youll no longer hear the sound of a tab trying to keep running....times are approximate..if it doest help keep on reading ..eventually you'll find a few suggestions that may work together....
Dec 09, 2013 | Tablets & eReaders
Washer keeps shutting down after running for a few minutes
Check the program controller unit, check if there is any loose connection to the wiring to the controller, the relay or the motor and the power plug.
When the machine shuts down then check on the power to the unit , check the door switches, the sensors , in case there is a false alarm..
Jun 14, 2011 | Kenmore Elite 45986 Front Load Washer
Descaling process counts down on the displat but no solution is running through the unit and thr counter stops on 1 min remaining
This is normal behavior, your machine is fine.
For example, the machine says "5 minutes remaining" and then it goes 5:00, 4:59, 4:58....etc all the way down to 4:01.Then it changes to "4 minutes remaining". Which is 4:00, 3:59, 3:58, etc.
So at "1 minute remaining" the machine is really at 1:00, then 0:59, then 0:58 and all the way down to 0:01.So, after the "1 minute remaining" goes away, the machine is actually done cleaning itself.
May 08, 2011 | Miele CVA 4066 Stainless Steel
Scanner not ready
You have to press the "MODE" button repeatedly to get it in ready condition.
Dec 08, 2010 | Xerox 8830 Copier
Toro 6.5 hp pushmower shuts off after ~ 5 mins of
It may have a gravity float residing in the carberator which may be cracked and will show same symptoms.If not garvity float, check for loose connection, heat and vibration my cause it to die, it cools and then restarts.
Aug 02, 2009 | Garden
Audi A5 2008. Sometimes I totaly lose whole Audio
looks like a loose connection of the power to the audio system must be loose generating enough heat for the circuit breaker to shut off the electric power to these gadets/equipment getting affected in this manner. Tighten all the leads generally check the wiring to trace the place where excess heat may have hardened the insulation of nearby wires. Alternatively you may replace the input cable and connect everything afresh......sodeep
Jul 26, 2009 | Audio Technica Audio-Technica ATH-A55...
Shutting off
i have the same problem...laptop randomly shuts down, but its even done it within a minute of turning it on so i don't think its a heat issue. Sometimes it'll run for over an hour with no problem and never shut down, but other times it randomly shuts down sometimes within a minute, sometimes maybe 10 mins, sometimes 30 mins or more ...its maddening! i'd love to find a solution if anyone's found one. Thanks.
Apr 22, 2008 | HP Pavilion dv1000 Notebook
Sony TV keeps shutting down ever 5 mins
Could be loose connections on the board where the solder is expanding as it heats up causing a loose connection or something in the power supply or horizontal is over heating and your tv is going into shutdown protection . Good luck
Mar 03, 2008 | Televison & Video
Auto Power Off function?
To conserve battery power, the camera will shut down if an operation is not made within 3 minutes (default setting). The auto-power-off period can be changed in the setup mode to 1 min., 10 min. or 30 min. at user's option. When using the AC adapter, the auto-power-off period is set at 30 minutes.
Sep 19, 2005 | Konica Minolta DiMAGE E201 Digital Camera
Computers & Internet Logo
David Payne
David Payne
