Question about H2O Audio Case, Earphone / Headphone
Loss of sound in one ear due to an internal wire break
Loss of sound in one ear due to an internal break of the wire at the point where the L+R earphone cables come together at the rear of the headset. Is it possible to make a watertight repair?
thanks
    Problem Solver:
  • 5 Answers
No
Posted on May 10, 2009
Slapping ears?
Yes slapping someone in the ears can knock them unconscious. It can be very painful, throw off the equilibrium balance, cause nausea, cause dizziness, and in some cases lead to internal bleeding, internal swelling, loss of hearing, and vomiting.
Jan 04, 2017 | Preschool
I have fluids and paste coming out of ears seems like infection it affects my hearing and I permanently have hearing loss as side effect ?
I had the same problem. I went to the Dr. and she said it was yeast.You need a prescription.But yours sounds as if you need to see an E.N.T. specialist due to the hearing loss.I suffered for years with this and finally broke down and saw a Dr.,but I did not have any loss of hearing.
Oct 03, 2016 | Rodale Alternative Cures: The Most...
No sound from speaker but through ear piece I get sound.
Many devices will automatically switch off the large speaker when ear phones are plugged into them. Also there may be a switch or button or prompt on your radio to switch between regular speaker and ear phone jack. Look for that first.
Try connecting and disconnection ear phones while listening to a station and see if the problem is intermittent. If is works sometimes but not every time then it is most likely an internal connection.
You will have to access the inside of the radio to investigate further. Connect a working external music or sound source with speaker wire to the terminals inside the radio that connect to the radio's speaker. If the radio's speaker works with the external sound source then you know it is a bad connection inside your radio. If the radio's speaker does not work with the external sound source then it is most likely a faulty radio speaker. Look closely for a broken solder point or broken/disconnected wire.
Sep 10, 2013 | Eton E100 SW/FM/AM Radio
Boss oethe left side of my headphone is stop working
The most common cause for this, is a loose wire connection to that speaker (as opposed to the speaker being faulty).
Has anyone pulled the cord too tight or tripped on the cord? If yes, then the internal wire connecting that speaker has an internal break somewhere.
Try the following:
1) Plug headphones into music device and turn on.
2) Gently press the wire 'in' at the left earpiece (or wiggle at the earpiece end). If sound returns intermittently, then you have n internal wire break in that end of the cord.
3) Gently press the wire 'in' at the plug where it connects to your player (or wiggle the cord at the plug end). If sound returns, then there is an internal wire break at this end of the cord.
In the case of broken internal wires, it is possible to repair.
Although very fragile, it is possible to resolder these tiny wires (you'll have to burn off the enamel coating around these wires first) back onto their respective connections, or onto a new plug.
Good luck....
Jan 13, 2012 | Bose On-Ear Headphones
Hi, I have a Behringer EuroPower 2500 power amp that has done very little work, maybe 10 hours total at half capacity through 8 ohm speaker box. (It has never been pushed to anywhere near it's limit.) It...
Hello
Due to long time in storage, its internal plugin wire sockets may have rusted or loose contacted. You just open the set, and pull out the pluged in connection inside, one by one and reset it to the same slots, or pins. I think this may resolve your problem.
Nov 13, 2010 | Behringer EUROPOWER EP2500 Amplifier
One earbud stopped working
what happens is inside the cord where you have your ear phones connecting to your ipod, there is a thin wire that can easily brake. it happens if u for example, rap your ear phones around your ipod. if your rap the chords to tight, the wire can break. it can even brake when you move the cord too much. such as spinning it, shaking it and such.
the wire that breaks connects to one side or both sides of your earphones, which produces the sound. if you can hear only on one side, the cord is damaged and cant be fixed.
i would go and buy new ear phones
i perfer skullcandy in-ear earphones because the wire is secrurly wrapped, and doesnt brake easily such as other producers. the skullcandy ear phones are in my mind are much better then other earphones. you actually feel like your in the room or at a live show.
Apr 20, 2010 | Philips Ear Bud Headphones with Virtual...
Right earplug is shorted out. sound goes in and out. how do i fix it?
The right ear plug internal wire is cut off due to wear and tear. This is common problem with earplug especially if
if you pull by the wire of your earplugs. The solution is to
cut open the wirings of your right earplug and reconnect,
resolder it, and tape the bare wires, to restore the sound. However, it will be unsighty. So, the best thing
to do is to buy another.
Oct 13, 2009 | Etymotic Research Isolator ER-6i Consumer...
Losing sound in my Shure ear buds, they are one year old.
the wire breaks after a while in ear buds ,and head phones due to the constant flexing,and moving.they probably need to be remade.by cutting out the bad part of the wire(usually close to the fitting)You can usually wiggle the wire and find where the breaks are that way.it can be a real pain re soldering ear buds.also check the plug end by wiggling the wire there.
Mar 16, 2009 | Shure SCL3 Headphones
Bose in-ear headphone cord cut
most head phones there two wires. those are the two that you most likly put together. if there is any metel mesh covering the wires. that has to be connected also.
Jun 05, 2008 | Bose in-ear headphones - Black with...
H2O Audio  Case, Earphone / Headphone Logo
505 people viewed this question
Top H2O Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a H2O Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
