Question about Braun Syncro 7526 Electric Shaver
Very Loud Since Replacing Cutter Block
I just replaced the cutter block and now the razor is very loud.  It seems to be vibrating a lot more than before as if the mechanism that comes out of the razor is no longer securely connected to the razor.  Any ideas?  Thanks.
  • 5 more comments
  • Anonymous Jan 12, 2008
    I have the same problem. I replaced cutter and foil at the same time on my Braun 7630. When reassembled it makes much more noise when operated. I reinstalled the old cutter and foil and it's still loud. I replaced foil and cutter several times in the past without this problem occuring.
  • Rapido Mar 18, 2008
    I replaced my cutter block within the last three months and the razor was operating fine until a couple of days ago. It suddenly became very loud and vibrates much stronger. Ordinarily, when cleaning the razor I lossen the cutter foil, turn on the razor and allow the loose cuttings to be vibrated out according to manufacturer directions. Now when I do this the cutter foil is popped off the razor. It apears as though the block may be pushing against the foil with more force but I don't know. Any solutions?
  • 2BorNot2B Mar 22, 2008
    My razor got very loud before I changed the cutter block and foil. I changed them and it made no difference. The razor is very loud now, but still seems to work OK.
  • maximoose Apr 11, 2008
    same as everyone else. replaced block a day ago. now it makes a very loud noise, and seems loose.
  • Anonymous May 14, 2008
    same problem here. Cutter pops right off when foil is removed and shaver is turned on.
  • Anonymous Jun 14, 2008
    I didn't update my earlier problem report. I sent the shaver to a Braun service centre and they diagnosed that the drive unit needed replacement. Cost about $Au85 in Australia.
  • BBBinIL Aug 01, 2008
    I have NOT changed the foil or cutter block, but today, while using the razor, I have the same symptoms described here by the other users. I'm wondering if it makes any sense to go buy a new blade/foil kit, as earlier users report that doesn't help. The loud rattle is present, vibrating the foil off of the head. I snap it back on, and when I turn on the razor again, it pops loose again. Took it apart, did a thorough manual cleaning, and slid the white plastic connectors back & forth a bit. It *seems* to have made it better, for now, but will monitor for the next few mornings.
    Problem Solver:
  • 5 Answers
Replace the drive unit yourself it is easy
Buy the drive unit $25:
http://shaveroutlet.com/braun-other-parts-c-4_27.html
Open the shaver:
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 scews
4) Open shaver
5) Remove circuit board with batteries
6) Remove and replace drive unit
7) Reasemble
Posted on Jan 07, 2009
Solution No.1 above was right-on. I ordered motor drive from ShaverOutlet.com and part arrived on Monday, ordered on Friday...
Repair took 5 Minutes and now shaver is like new again for another 5 Years I hope... Thanx for the Tip. Only cost 30.00 even with postage.
Posted on Mar 27, 2009
One other possibility is that you have not pushed the cutter block all the way in. I had the problem of it popping off and I just needed to push it in a little further. Watch your fingers!
Posted on Jun 30, 2008
SOURCE:
I can't figure out what is wrong. When I try to use the razor the cutter seems frozen and doesnt move side to side. When I take off the foil I see that the cutter seems to move perfectly fine. I then...
If you are having the same problem with both your old and new foils and cutters it sounds like there is a problem with the oscillator in the swivel frame. Sometimes the plastic oscillator inside will partially break and it can not vibrate under the load of the foil and cutters.
This swivel frame is part of the 'drive unit' and can be found available at shaveroutlet.com. See link below for item and scroll down the item page for installation video
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-activator-motor-drive-unit-p-36.html
Aug 16, 2011 | Braun 8585 Electric Shaver
I have had a Braun 8985 electric shaver for 4 years now. I have recently replaced the cutter block and foil but I am still having a problem with the shaver. It is not unusual for me to have to make 3 or...
The symptoms you describe indicate that the 'drive unit' is the problem. This part includes the swivel frame that the foils and cutters fit onto as well as the motor. Sometimes a piece of the plastic oscillator inside will break. The vibration causes the loud noise and it can not oscillate properly because of the break.
You will find the part needed at shaveroutlet.com. See link below for this part and scroll down the screen for helpful installation video
Jul 27, 2011 | Braun 8585 Electric Shaver
Cutter plastic drive block doesnt hold cutter pin
It sounds like the drive unit is the problem. This part can be purchased from shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-activator-motor-drive-unit-p-36.html
May 29, 2010 | Braun 360° Complete Electric Shaver
New head
Hello Brian, You can give the folks at www.electricshaver.com a try. They typically stock all the replacement and repair parts for most brands of electric shavers.
Here's a link to their site where you'll find part #5646768 for about $38 for a new set of the cutter head and foil (screen). It's always best to replace BOTH the foil and cutter block (head) at the same time, as any mircro burrs or nicks in the cutter blades will quickly ruin any new foil screen.
http://www.electricshaverstore.com/get_item_5646768_braun-foil-cutter-kit-360-complete-8000-series.htm
As you know, this is the simplest and easiest way to get an electric shaver back to a "like-new" shaving experience.
I hope you find this Very Helpful and best regards!
Nov 11, 2009 | Health & Beauty
When should you change cutters &/or head?
braun series 5 combi 51S replacement screen foil and cutter block for braun 8985 replacement parts.
Jul 19, 2009 | Braun 360° Complete 8985 Electric Shaver
The razor head comes loose from the two arms.
The one piece motor drive which also contains the shaver head in the Braun wear out. They can be replaced by yourself or a shaver tech. A good place for parts, http://shaveroutlet.com/.
To disassemble the 7000 Series Braun shaver.
Disassembly of the 7000 Braun shaver is basically the same as the 8000 series Braun shaver listed below. The 7000 is actually easier to disassemble as the plastic is much thicker and the bottom socket cover pops right off as there are less tabs and they are bigger.
To disassemble the 8000 Braun Series shaver.
Remove the plastic cover on the bottom that covers the corded socket. Be careful, there are a total of two tabs on the short sides and four very small tabs on the long sides. I usedmy fingernail to create a space big enough to insert the corner of a credit card in the center of the long side opposite the blue light indicator, then gently removed the cover. Using a screwdriver could damage the plastic.
The two sides then pop off, they only fit on their respective side when replacing. Don't lose the two small black seals on the top of each side piece.
There are a total of four screws holding the body together. Remove the screws, using the proper flat blade or torx screwdriver. The shaver will then split into. You can then remove the the Motor Drive Unit and the separate circuit board with the batteries.
This would also be a good time to clean the goo buildup from around the shaver head.
Assembly is the reverse of above. The Motor Unit will only fit in one way, there is a flat side and a angular side. Be sure the pin for the trimmer is placed in its proper hole, or it won't extend.
May 27, 2009 | Braun Syncro 7526 Electric Shaver
Loose Cutter Block
when you remove the cutter block is there a white nylon fixture atop the vibrating mechanism? this nylon piece snaps on the vibrating rod and the cutter snaps into the nylon fixture.
Sep 02, 2007 | Braun Syncro 7526 Electric Shaver
Braun Syncro 7526 Electric Shaver Logo
287 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Joseph Hoffmann
T.Johns
Level 1 Expert
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
