Question about Dryers
Dryer will not stay lit
Dryer will lite but goes out after a few seconds is it the electric eye
  • 460 Answers
I need to know the model n brand
thanks
Posted on May 09, 2009
My Maytag gas dryer is not drying my clothes Model MDG 9316 AWW. I opened and realized that the ignater works, glows and starts the flame, but only stays on for a few seconds and turns itself off, after a...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 19, 2011 | Dryers
Flame won't stay lit more than 15 seconds
heatman101
Aug 07, 2011 | Dryers
Dryer is not drying igniter coming on but wont stay lit lites once in awhile
heatman101
May 24, 2011 | Whirlpool Dryers
I light the piuolot button and when i let go of the pilot button the pilot goes out does not light burner wont stay lit
When you light the pilot lite you have to hold the button down until it gets the element hot enough to stay lit. If you hold down the button and lite the pilot and let it go right away it will go out. What to do is hold down the button and lite the pilot and continue to hold the buttn down for about 45 seconds to a minute then let it up very slowly and you will see if it is going to go out by the flame getting smaller as you let up on the button. If it does start to get smaller conitnue to hold it again for a few seconds and repeat the process of letting it up slowly. when the control element gets to the right temperature it will stay lit then turn your valve to "ON" and the fire will start up and continue to heat the water.
Mar 15, 2011 | RELIANCE ELECTRIC WATER HEATER
Maytag Model # LDG510 - Dryer burner will not stay lit. Electric igniter glows but will not lite gas. Igniter cycles on and off.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 10, 2010 | Maytag Dryers
My Maytag dryer lites then goes back out after a few seconds. It will lite again then goes out again. Model MDG7600AWW
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Aug 21, 2010 | Maytag MDG7600AW Gas Dryer
Maytag neptune dryer will not stay lit. It starts up, lights, stays lit for about 1 minute and then goes out
heatman101
Aug 09, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The heater won't stay lit
CHECK YOUR EXHAUST VENT MAKE SURE THAT IT IS NOT PLUGGED OVER HEATING THE UNIT.ALSO IF IT HAS A FLAME SENSE BAR CLEAN IT AND CLEAN ALL SENSOR OFF.AND MAKE SURE ALL WIRE CONNECTIONS ARE PLUGGED IN TIGHT.
Jan 16, 2009 | Desa International CBN20T Heater
Clock doesn't stay lit up
To turn the time of day display OFF or ON in the display press and hold for 15 seconds (the control will beep
once) and then release. This feature does not remove the set time of day from the memory of the control. When the display
is turned OFF the time of day will re-appear for a few seconds any time the pad is touched
Mar 04, 2008 | Frigidaire FEF366 Electric Kitchen Range
Dryers Logo
Top Dryers Experts
