First is the light on the nexstar coming on when you plug it in, if so what colour? If not try using both USB connectors on the PC end to plug in, it's possible you're not getting enough power if the light is not on as many 2.5" hdd enclosures require 2 USB connections one for power and data and the other for additional power.
Next, if the light is on but no drive in my computer, right-click on my computer, then left-click manage, select disk management from the MCC window that pops up. If your Nexstar HDD shows up here, identify it on the bottom part of the window and report back what is said there.
If it is not there and the light is on, try a different USB port. If the light is not on or you tried the other ports and still no luck the enclosure itself may have failed.
Try moving the HDD into a new enclosure and try again. If this works, Great, if not then the HDD may be damaged and may need a pro to get your files back. If that is the case report back here with your progress and region and I will recommend an appropriate pro.
Hope this helps FixYa,
Chris
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Vantec NST-285S2-BK NexStar SX
I am getting the following error ''Please Insert a Disk into Drive '' when I try to access my...
(More)
I am getting the following error ''Please Insert a Disk into Drive '' when I try to access my external drive in a Mad Dog enclosure. I see the drive H: but can't access it.
when using my EasyCAP and Videostudio 8, it doesn't capture by video at all. It says : No signal or...
(More)
when using my EasyCAP and Videostudio 8, it doesn't capture by video at all. It says : No signal or it is unclear? Please help
This is probably a very stupid question. However, we have just purchased a NexStar SX case for an...
(More)
This is probably a very stupid question. However, we have just purchased a NexStar SX case for an external drive for our daughter's laptop (the motherboard on the laptop is toast). How do we get the hard drive into it?
