Question about Vacuums
The brush isn't turning. Have cleaned around ends of brush. Looks like the motor isn't turning the belt.
Brush isn't turning
  • 57 Answers
Belt could be broken or has come off. It needs to be taken apart to find out. Not a hard fix usually. Since you didn't mention that it didn't squeal, got hot and smelled of burnt rubber or the roller didn't spin this is my guess.
Posted on May 09, 2009
Brush bar won't turn
Belt is broken or over stretched and needs to be replaced. If belt is good, then clean threads that wrap around the brush at each end. Then place a couple drops of motor oil at each end of brush where a crack goes in a circle around the brush.
Oct 18, 2015 | Dyson DC25 All Floors Bagless Upright...
How do I replace the belt for this model
Make sure vacuum is not plugged in to power outlet. Lay it upside down and remove 4 screws from bottom plate covering brush roll. Remove bottom plate and pull the brush roll out. Clean hair and debris from brush roll and make sure it spins freely. Remove end caps from brush roll if possible and clean debris out. Install new belt around motor shaft then insert brush roll into belt and pull on brush roll to give you enough leverage to stretch belt far enough to put. Brush roll back into position. Reinstall bottom plate and screws. Make sure brush roll will turn before turning vacuum back on. Belt will lose elasticity and should be replaced twice a year.
Jan 17, 2015 | Hoover U5434-900 WindTunnel Plus Bagged...
The brush bar isn't going round ?
your problem seems to be the belt has snapped. Underneath the the hover there is a rubber belt that connects around the brush bar and around the motor, this belt will be broken. They can purchased from any hoover shop for a couple of pounds.
Jan 06, 2013 | Dyson DC24 Ball All-Floors Upright Vacuum...
A burning smell when in use
Martinsivyer:
Turn the machine upside-down and see if you can turn the beater/brush bar with your hand. You should see the brush turning and feel the resistance from the motor. The brush/beater bar may be binding, and what you are smelling is the motor shaft spinning against the rubber belt. You can remove the base plate and check the brush/beater bar with the belt disconnected. If the brush/beater bar is difficult to turn, you need to remove the brush/beater bar and clean the bearings at each end, Remove any threads that are wound around the beater bar ends so that the bearings roll easily and smoothly. Check to see that your machine is not set too low for the surface that you are bacuuming. While you have the belt disconnected, check thi inside surface to see if the motor shaft has been spinning against the belt, you'll see the damage to the inside circumfrence of the belt.
Oct 21, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do i replace the belt on my hover
lower handle to floor and flip entire unit over. In the bottom near the brush, there are 2 levers that hold the cover on. flip both levers and pull up on cover. It will come out of the 2 wire holders that hold down the 2 front tabs.With the cover removed you can easily access the brush. Firmly grasp 1 side of the brush and pull straight up. This may take a lot of force as the brush may have been seated for a long time. Pull both sides out and clean the area underneath the brush. Also make sure nothing is wrapped around the brush or motor.
After cleaning you're ready to install new belt. Place new belt around brush. After pushing brush through the new belt, with belt loosely around brush slide brush back into housing 1 side at a time. The brush fits in very tightly. The ends have 2 pieces of metal that act as springs, these are installed facing the top. Make sure the brush is pushed down tightly toward the bottom or the cover will not fit right. Once brush is in stretch belt around motor tip. Replace cover by placing the 2 tips into the wire clips and close. Flip the latches closed and turn machine over. Lift handle and you're good to go. You have now completed the worlds longest instructions for a vacuum belt...ever!
Jun 11, 2012 | Vacuums
Where is the belt housed on the Hoover vacum cleaner model U5461-900? The belt number is 38528-033 but I can't find where the broken belt is to replace it.
Simply lay the machine down with the brush assembly facing upwards, and remove the four screws holding the bottom plate in place, and remove it. Put the new belt around the motor shaft, then around the brush assembly and push the brush back into place. Turn the brush with your fingers before replacing the bottom plate, to be sure the belt isn't caught between the brush and housing.
Jul 27, 2011 | Vacuums
Need to replace belt and cannot figure how to take it apart to get at the belt --- Took Screws off on the bottom but could not get to the belt
You have already removed the screws so lift the brush cover off. Then grasp rotating floor brush at both ends and lift. Clean strings,hair and other debris from rotating brush, paying close attention to the brush ends. Clean the debris from motor pulley and drive belt areas.Grasp old drive belt and remove from motor pulley. Place new drive belt over motor pulley and stretch other end over rotating floor brush in the space between the bristles. Place the ends of the rotating floor brush down into slots on the sides. Turn the rotating floor brush by hand several times in the direction of motor pulley. If installed properly, drive belt will center itself on rotating brush. Reposition brush cover and screw back into place. I hope that this helps you!
May 26, 2011 | Bissell 3591 CleanView Bagless Upright...
Canister vac - the motor on the cleaning head cuts out while vacuuming. does it as you draw back the head while cleaning , goes off momentarily and ten when pushed forward engages the motor again. this...
Unplug the vacuum then pull the bottom off the head and clean the brush. Check for debris on the brush and around the ends of the brush. Insure the brush moves freely. Check the motor by turning it by hand to see if it rotates freely. Check the belt to sdee if it is tight. When belts get old the will sometimes stretch and won't work properly. Hope this helps.
Jan 03, 2011 | Vacuums
Actually have model 6594. no suction. any suggestions?
If you hear the motor running and the vacuum is not sucking up debris, I would believe you have a problem with the beater brush. Problems with this brush are usually caused by 1 or 2 if not both of these problems: 1- The drive belt for the brush is broken. 2- The brush itself is frozen due to debris. Remove brush and clean all debris off. Pay special attention to end pieces of the brush that hold it in the vacuum. The brush should rotate around these two pieces. Clean ends and spray on a little WD40 and turn to work it so that the brush turns freely. If you find the brush is frozen and needs to be cleaned, probably a good idea to put a new belt on at the same time. Be sure the belt is put on correctly so the brush turns in the proper direction. Feel free to contact me if you have questions.
Sep 17, 2010 | Bissell 6596 Bagless Upright Vacuum
Drive belt ; whirlewind litespeed.
There is nothing but the motor shaft. The belt rides on the shaft and around the brush assembly on the other end. The belts fail if the brush assembly gets jammed, for example from a rug ot debris. If this occurs you should immediately turn off the unit,unplug the power cord, and clear the jam. Also occasionally cleaning the brush and being sure the bearings on each end turn freely will help prolong belt life. The brush assemblies also look to be available. lysager@gmail.com
Jan 25, 2009 | Eureka Whirlwind 4388 Bagless Upright...
Vacuums Logo
175 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
