Question about Sony Ericsson K800i Cellular Phone
Seems to be corrupt
I unplugged my phone from my mac without putting the icon on the desktop in the bin first and waiting for it to say 'now safe to unplug your phone'. Now it doesn't work. It switches on but can't see anything on the screen apart from the word ok!
  • 425 Answers
Yup, your phones memory is corrupted. have it flashed or reprogrammed by qualified personnel...
Posted on Oct 17, 2007
SOURCE:
How do i get the weather cloud off my home page
Put your finger on the cloud icon and wait for the bin to show up then drag it to the bin and let go.
Aug 27, 2014 | Samsung Galaxy S 4G Cell Phone
How to remove icons from mac desktop
Try to restart you system and then try again .
Aug 09, 2014 | Apple 24" iMac Desktop
Unmount usb
External hard drives are portable storage devices you can use to back up files or transfer content from one computer to another quickly and safely.
While external hard drives vary in design and storage capacity, turning them off properly is ideal because it decreases the chances of damaging or corrupting files.
Whether you are using Windows or Mac OS X, you can safely eject and turn off your external hard drive in minutes.
Safely eject your external hard drive before turning it off if you have connected it to your computer.
To do so, click the "Safely remove hardware" icon on the system tray on the taskbar. T
he hardware window launches.
Click your external hard drive's icon in the hardware window and click the "Stop" button. You should see the "This device can now be safely removed from your computer" dialog message.
Press the "Power" button to turn off your external hard drive.
Some external hard drives turn off automatically when you safely eject them.
Right-click your external hard drive's icon on the desktop if you are using a Mac, and then click "Eject."
Alternatively, drag your external hard drive's icon from the desktop to the "Trash" bin.
You should no longer see your hard drive on the desktop.
Feb 05, 2014 | Transcend Computers & Internet
I need to know what the icon looks like, which is in the finder, then go to file and choose cancel to disconnect . I don't know what the icon looks like. This comes up on my screen every time I unplug my...
You should have an icon appear on your desktop when a few second after you connect your camera, the icon will appear on your desktop, if you have a clutter free desktop you should spot it easy, before you disconnect your camera next time, drag the icon to the trash, which by then will turn into an eject button. once dropped onto the eject button wait for the icon to dissapear and then safely unplug the camera.
Kev.
Feb 23, 2011 | Computers & Internet
My screen is blank with a folder in the middle
This is an icon indicating that the iBook G4 cannot locate the bootable Mac OS X volume on the hard drive.
Here is a procedure you can use in order to get back to your main desktop:
I am going to have you take your Mac into Safe Mode to see if we can't remove a possible folder(s) that may be affecting your Mac's start up function.
Try these steps:
-SAFE BOOT MODE-
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain startup items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
If this does not work, it could mean the Mac OS X directory on your iBook G4 may be damaged or corrupted. So the best step you can take to try to correct this without losing any data from your Home Folder(s) is to run an Archive and Install, with your Mac OS X installation disc.
What this process consists of (using your Mac OS X install disc),is removing the damaged or corrupted Mac OS X directory and replacing it with a brand new directory.
This procedure also allows you to save your applications, files and folders without the old directory no longer in the way of interfering with you accessing those files.
-ARCHIVE AND INSTALL-
• Start up from your Mac OS X Install Disc 1 or Install DVD. Please remember to use the install disc that matches the current operating system your system haves.
Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key.
• Hold the C key until you see a White screen, with a Gray Apple icon and eventually a Spinning gear.
• Release the C key only after you see the Spinning gear.
-Your mac will now boot from the disc and load into the Installer environment.
• Select your language. The Welcome to the Mac OS X
Installer window appears.
• Click Continue. The Important Information window appears.
• Follow the prompts until you get to the licensing agreement screen
• An agreement sheet appears. If you agree with
the license agreement, click Agree. Then Select a
Destination window appears.
• Click the volume that you wish to install to (your primary
hard drive).
• Click Options. The installation options sheet appears.
• Select Archive and Install.
• Select the volume which already has Mac OS X installed.
• You should also select Preserve Users and Network
Settings, to preserve network and Home directory
settings.
• Click OK.
• Click Continue to begin the installation.
• Once the Archive and Install is completed, when you reach your desktop be
sure to run all Software updates to bring your new
Mac OS X directory back
up to current.
Also, if you look inside your Macintosh HD icon on your Desktop, look for a folder entitled "Previous System Folder" which will have all of your previous Home folder files prior to the Archive and Install.
Here is the link (below) from Apple for more information about how to locate the Previous System Folder
How to locate Previous System Folder (after Archive and Install)
If you don't have a Mac OS X installation disc, let me know.
Regards,
-Mactechtrainer
Feb 01, 2010 | Apple iBook G4 Mac Notebook
Removing my usb stick
"removing my usb stick" - This seems like a statement, not a question.
That said, the biggest problem people have removing the USB stick from a computer is that they fail to unmount the drive before removing it. In Windows this can be done by left clicking the "Safely Remove Hardware" icon in the task bar, clicking your device, and then waiting for it to tell you that it is ready. With Mac and Linux you just right-click and unmount the drive.
Either way, not doing this can wipe your USB drive or corrupt your files.
Sep 30, 2009 | Computers & Internet
Why "print and fax" icon disappearing from my mac "system preferences" window ? Right now instead of showing "system preferences icon!"(name didn't change! only the icon). So i can't add new printer, even...
Hello, it seems like your system has a corrupted preference file, or something has been deleted. For best results, I would recommend to do an update of your system. If this doesn't work, you can try to repair the systems permissions in Applications --> utilities --> disk utility, and hit "SOS" and select your drive then click on "repair permissions". Reboot the computer.
If this doesnt help, I would recommend to reinstall the system using the Leopard DVD
May 28, 2009 | Apple Power Mac G5 Desktop
LaCie icon won't show up on my mac desktop
1. A. Yes.
2. A No.
3. A. Replace the LaCie
Apr 24, 2009 | LaCie Computers & Internet
Hard disk icon on the move
It may have done this in an update for some reason. Nothing to be alarmed about, just move it back to where it used to be.
-OR-
You have changed the name of the drive. Mac desktop works on alphabetised lists.
Jul 05, 2008 | Apple MA590LLA Mac Desktop
Play dvd movie
have you tried opening trash bin and restoring files in it?
Jul 03, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Sony Ericsson K800i Cellular Phone Logo
21 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
