Question about Garden
Where is the unloader valve in a honda 2600psi
My Honda pressure washer wil not run when the wand trigger is released. It builds pressure and cuts off. What will cause this?
it's a faulty unloader valve have it replaced depending what type of unloader or you may have it adjusted too tight make sure the large spring has a gap between the coils for it to drop down and unload.
Aug 14, 2014 | Honda Garden
Honda XR 2600 pressure washer, cord will not pull on engine
This is typically due to the unloader bypass valve not operating properly. You can remove and clean this valve or you may want to replace the valve with a new one.
If you take the high pressure hose off of the pump and with the water turned on you can start the engine each time then you probably should replace the unloader bypass valve.
Here is a link to the pump.
http://www.allpartsinc.com/mmAllParts/Others/A14292-001.pdf
Oct 08, 2012 | Honda Maxus Pressure Washer MX5222
I have a honda power washer and it will run for about 30 minutes and then start losing pressure,gaining pressure back and losing for about a minute until dying, if i let cool off it will be good for...
Since you did not include a model number.. I have to speak in generic terms. On the output side of the pump there is a high pressure / unloader / bypass valve. There is probably corrosion on the stem of the unloader and the corrosion is causing the stem to stick in the brass stem guide. Remove the unloader valve assy from the output side of the pump. Clean off the corrosion with some scotch brite and the GREASE the stem. (Make sure the input water supply hose is connected but NOT on.) Dump about 2 oz of engine oil into the hole where you removed the unloader valve. Place a liberal amount of grease in the hole where the unloader was then install the unloader valve.
Start the unit but do NOT turn on the water for about 1 minute. Squeeze the power wand knowing full well your going to get oil and grease out of the end of the nozzle for about 45 seconds. Begin cycling the wand trigger rapidly.... multiple times. Your forcing the unloader valve to work.... Then try normal use.
I Not only work on these I have an Excell 2400 with the honda 5.5hp GX 160 engine that just this last weekend I had to do this exact procedure for the same reasons.... It is working like a champ again and it was new in 1997.
Thanks for choosing FixYa,
Kelly
Jun 03, 2011 | Garden
My pressure washer stops running when i let off the trigger
hi there sal rick85
sounds like the unloader valve is not working or stuck closed , check the setting of the unloader valve may be set too high, the unloader must open in odrder to cycle water back to inlet side of pump - if not builds up heaps of pressure , stalls the engine - service the un loader valves on the pressure head
take look and let me know - what brand your blaster unit is i know its honda but what pump
comet - axd, lw/zw, - in line or axial cam
in the mean time here is good web site on power washers
http://www.the-power-washer-advisor.com/
or go to
http://www.the-power-washer-advisor.com/pressure-washer-pump-trouble-shooting.html
cheers pauly46
May 30, 2011 | Honda Pressure Washer PSI 3000
Hard starting does this model have an unloader
There are two types of unloaders used on IR compressors. One is oil pressure controlled, and second is manually activated for starting. According to the photo and model number provided, yours is manually operated. Follow air line from compressor to tank. The pilot valve (brass valve) between airline and tank is a multi-function component. There is a flip leaver or pull ring w/ hold that unloads the compressor by venting air thru small muffler. The valve also contains the check-valve holding pressure in the tank, a means of adjusting pressure and controlls throttle for engine. For easy start, flip leaver upright and start; to run, flip leaver to right angle of stem.
Nov 19, 2010 | Ingersoll Rand 2475F13GH Ir Stationary...
I have a 4,000 psi, 4.5 gpm 45G cat pump powered by a 13 hp honda engine I can not seem to be able to adjust the unloader valve to give me pressure over 950 psi and even at lower pressures, the pump...
I would just purchase a new unloader valve, they usually aren't worth rebuilding. I would like to have a picture of the set up that you have, if you can send me a picture of the unloader region of the pump I can get you are price on a new one. email is justin@wmpcs.com
Oct 22, 2010 | Honda Pressure Washer PSI 3000
NO PRessure
Hi It sounds to me like your unloader valve is stuck, this is the thing that is meant to move up and down when pressing the trigger.Please remove the unloader valve assembly and check for damage. If no damage is found then grease and lubricate this part and replace and this should work ok again.
Jun 15, 2010 | Honda Pressure Washer PSI 3000
Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
Oct 02, 2009 | Honda Karcher G4000RH Pressure Washer
If you let the trigger on the lance go while in use the machine cuts out
hi, you are making the engine stall with having the unloader valve screwed to far down i would say, try dropping the pressure on the unloader and then try it.
the unloader valve could also be blocked.
Jun 27, 2009 | Honda Pressure Washer PSI 3000
Garden Logo
109 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
