Question about KitchenAid Food Processors
I have a kitchen aid food processor, it is on, but motor doess no
I have a kitchen aid food processor, barely used, tried to blend some soup and the motor/blade won't start turning.
The power light is on, but pulse and on does not seem to turn the blades.
Anyone else have this problem? Any solutions?
  • Anonymous May 24, 2009
    My kitchenAid food processor is on but does not turn. The power light is on, but the motor does not work.
  • 145 Answers
This sounds like an issue relating with the assembly of the machine. The motor is definitely getting power if the indicator is lit. However, Kitchenaid food processors are designed (as a safety feature) to remain unengaged if the unit is not assembled in such a way. Here is the proper assembly:
Please disassemble the unit. This means: removing the blade, removing the work bowl, the work bowl cover, and unplugging the unit.
Starting with the work bowl: place the handle at the 9 o'clock position, which is out to the left. Rotate downward to the 6 o'clock position until it locks in, centered over the button panel.
Repeat the process with the work bowl lid.
Depending on which food processor you have, you may need the feed tube pusher depressed at least half way down the feed tube.
Plug in the unit. The blade does not have be installed for unit it to work at this point, assuming everything is assembled properly and the motor is functioning. The motor should now be working.
Posted on Jul 07, 2009
My processor is doing the same thing what I did was unlock the safety latch a wee bit and it worked.
Posted on Nov 23, 2012
The above solution was helpful. I found mine worked once I made sure it was installed correctly AND pushed the blade down, hard.
Posted on Dec 26, 2009
Lid stuck on work bowl of kitchen aid processor
This tip is used to remove a stuck bowl from the base of a Kitchen Aid tilt-head mixer. It might work for your situation. Fill the bowl with very hot water (use the food shoot as a pour spout). Now use either frozen gel packs, or a bag of ice cubes, and lay the ice on top of the lid. Wait for a few minutes. The hot water with make bowl expand, ice will make lid shrink, thus loosening the tight lid. I'm assuming that the lid edge fits inside of the bowl, like most food processors do. Try to gently move the lid, and see if it'll give.
Mar 20, 2017 | Food Processors
Looking for a base for Kitchen Aid food processor KFP 700.
Base of motor housing or whole motor unit assembly?
Oct 04, 2014 | Food Processors
How can I get kitchen aid blade out that is stuck
The blade will be stuck on the shaft and both will be damaged and require replacement. With that knowledge you now understand that drilling a hole sideways through the blade cap isn't wrecking anything you are going to use again. You can then get something into the hole for leverage. Here in NZ blades are under $20 and motor shaft sleeve is about $5. If you don't replace the parts it will happen again.
Aug 11, 2014 | KitchenAid Kitchen Aid 13-cup Food...
Need Use and Care manual for new 13 cup Kitchen Aid food Processor I bought from Chef's Catalog, but there was no manual in the package sent to me.
This is the link for Kitchen Aid 12 cup food processor.
http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/kfp750.pdf
Although this manual is not exactly designed for your model, it will have similar information.
If you want the exact manual for it, let us know the model no. of your product.
Oct 31, 2011 | Food Processors
I recently picked up a used 5 cup Kitchen aid food
may be u shoud read the menual and plz check ur wiring
Jul 22, 2009 | Food Processors
Kitchen Aid Little Ultra Power, 4 yrs old, suddenly stopped.
I HAVE A BASE UNIT WITH NO MIXING BOWL,
HARDLY USED , CAN PURCHASE CHEAP
RESPOND TO garyhp@cox.net
Jul 13, 2009 | KitchenAid KFP450 Ultra Power 7 Cups Food...
Kitchen Aid food processor, model # KFP 700 from 1970s
The closest I have seen recently - there is an auction for a complete KFP-700 with work bowl/lid intact on eBay right now:
http://cgi.ebay.com/Kitchen-Aid-12-Cup-Food-Processor-model-KFP-700_W0QQitemZ150328616612QQcmdZViewItemQQptZSmall_Kitchen_Appliances_US
-Tha Mp3 Doctor
Mar 12, 2009 | KitchenAid Food Processors
Can't get food out of white spicket in work bowl
After trying jetstreams of water, canned air, dishbrushes and soaking the bowl all didn't work, I grabbed a piece of wirea and dug it out. What a pain.
Jan 24, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Food Processors Logo
1,745 people viewed this question
Top KitchenAid Food Processors Experts
Shehu Pro
Shehu Pro
Ted Maxwell
ray gallant
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
