Question about Zebra QL420 Thermal Printer
Problem in printing with QL 420 Plus USB thermal printer
I have QL 420+ thermal printer. The printer driver was installed and through the driver i could print test page and my own contents. But even by using the CPCL commands, i cannot make the printer to print through my .net application. i wrote a simple application in asp.net (with backend coding in vb) but it doesn't print.
Please provide me some help in assist me in this regard.
Thanks and Best Regards,
Saran
  • 2976 Answers
SOURCE: setup for zebra z4m plus
Make sure to select the proper printer when you send it to print. Also, make sure the printer is calibrated to the size labels you are using.
Posted on Feb 05, 2009
  • 17 Answers
SOURCE: Read and print .DAT files on labels
you must embed ZPL/CPCL or EPL command to your program.. or use Zebra Designer Pro then connect the .DAT file to it and design your sticker..
Posted on Mar 21, 2009
  • 53 Answers
SOURCE: Zebra LP2824 not printing
Sounds like you put your printer into line mode. Line mode prints code so you can see what is sent to the printer to look for possible mistakes in the code.
To switch from line mode back to page mode.
  1. Turn printer off.
  2. Press and hold the feed button down. And switch printer on.
  3. Release the feed button when the LED flashes red.
  4. When the LED flashes green, press down the feed button.
  5. When the LED flashes amber release the feed button.
  6. Try printing now that the printer is back in page mode which is used for print your labels; line mode prints the labels code.
  7. Do this fast or else it wont work if you are slow.
Posted on May 12, 2009
  • 35 Answers
SOURCE: Hi,
The TLP2844 can print from any windows application providing the application can use a windows printer driver.
The page size oof the .pdf needs to be the same size as the physical label size.
Posted on Feb 16, 2010
ozztech
  • 285 Answers
SOURCE: In Zebra 105sl Thermal Printer
try download other driver, www.seagullscientific.com, and try again.
Posted on Nov 25, 2010
Factory Reset
try driver from www.seagullscientific.cam driver, it will help to reset to factory default.
Feb 28, 2014 | Zebra QL 420 Plus Thermal Label Printer
2 partial labels being printed on 1 label
most likely to do with sensor --- label has a notch in it it in middle make sure it is clean --- do labels have a hole that align with sensor?
Look at Cleaning printer to locate sensor
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/ql-qlp-qrg-en.pdf
Mar 18, 2013 | Zebra QL420 Plus Portable Thermal Barcode...
Need to have the print darker! /Zebra QL420Plus/ How can I set the darkness?
zgorbe723: The darkness is only setup via software. Adjust it in your Windows driver or including the heat command in your format:
CONTRAST n 'in CPL comtec syntax
^MD+n 'in ZPL zebra syntax
Roberto Martinez
padrino99@prodigy.net.mx
Aug 31, 2011 | Zebra QL 420 Plus Thermal Label Printer
Resolving Print Quality Issues on Performance Line PrintersCheck this link for your model solutions:
https://km.zebra.com/kb/index?page=content&id=SO7322&actp=LIST_POPULAR
May 23, 2011 | Zebra QL 420 Plus Thermal Label Printer
Trying to configure network settings on a QL 420...will not take certain info like the gateway
Check to ensure the printer has a network card installed. if not it looks like everything is working correctly in label vista but nothing "takes"
Jun 16, 2010 | Zebra QL 420 Plus Thermal Label Printer
Zebra QL 420+ wireless printer works only without cipher/TKIP
Hi
With Label Vista
  • Go to Printer Tab
  • Define the com Port settings (use serial or usb)
  • Go to Printer settings
in network tab :
  • Put your network configuration ( IP address or DHCP,submask, gateway; ESSID, port number .....)
In 802.1X WPA
  • Select WPA WPA2
  • Authentification PSK
  • Put the username and password in EAP section
Mar 16, 2009 | Zebra QL 420 Plus Thermal Label Printer
Zebra QL420  Thermal Printer Logo
483 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
