Question about Canon PIXMA MP600 all-In-One InkJet Printer
Printer display is gobbledegook and buttons do not respond - reset, start, ok, direction, etc. Display reads: 544%$$LIV$$ C| | | | | |$LEMN
  • 1 more comment
  • GARY COGLEY May 09, 2009
    I should have said - I'm on a MAC.
    Printer display on face of printer is gobbledegook and buttons do not respond - reset, start, ok, direction, etc., even on-off.
    Printer won't print from MAC computer. Updated the printer drivers. Still won't print. When start button is pushed the alaerm light flashes as it goes through setup, then goes off and the following display is shown.
    Display reads:
    544%$$LIV$$
    C| | | | | |$LEMN (C| and | | represent boxes - some blank and some filled, like the boxes on the adjustment of density)
    Comment posted on May 09, 2009
    Again said - I'm on a MAC.
    Sorry, I have no idea what you are referring to.  Locale settings?  Regional languages?
  • 385 Answers
Check you locale settings are set correctly on the system
Check that the Regional langauges are setup correctly for your local area.
Hope this helps
Regards
Richard,
Posted on May 09, 2009
  • Richard Finney
    Richard Finney May 09, 2009
    My mistake, sorry,
    your refering to the printer's on-board display is incorrect,
    If after turning off half hour or so doesn't clear the error,
    You have a hardware problem, as the ROM inside the printer is non-updatable,
    And the buttons have lost all functionality too.
    It could be a Language problem in the settings on the printer, but if not working, this rules this option out too.
    Sorry.
    Richard.
    President:
  • 2,923 Answers
Uninstall/re-install the printer driver. If same problem exist, restart the printer spooler to avoid garbled print out. To fix this, please use the link below and click the 'Fix it' button and run the file:
http://support.microsoft.com/kb/934885
NOTE: Do not forget to uninstall/re-install the printer driver first.
Have a great day!
My brother dcp 1510 is telling an error massage "replace the toner cartige"i have changed toner ;try to reset but i cant please tell me the exact reset code and procedure .
Hi try this press menu button hit down arrow until u see info on display press OK button hit down arrow until u see reset drum on display press and hold OK button until u see reset on display press start button press-up arrow until u see the value 10 press OK button on display should read accepted press stop until the main menu appear on display.......good luck
Jun 10, 2016 | Brother Office Equipment & Supplies
Reset maintenance count
T632 reset maintenance count: Press and hold down the "select" and "return" keys while powering on the printer, hold these buttons until the display reads " 80 Scheduled Maintenance, press the "go" to continue past this message and access the configuration menu. Press the menu button until the display reads "reset Maint Cnt" on the second line of the display and press the " select" button. the top line of the display should nnow read "reset maint cnt" and the second line will read "reset" and pressthe "selcect" button. this will reset the counter to exit out of the "configuration mode" cycle the power.
Jan 16, 2014 | Lexmark T632 Laser Printer
T630 clear counter
The following will reset the maintenance count after you install the maintenance kit, you can not reset the printer total page count. Press and hold down the [Select] and [Return] keys while powering on the printer, hold these buttons until the display reads "Performing Self Test." If the display readds "80 Schedules Maintenance", press the [Go] to continue past this message and access the Configuration Menu. Press the menu button until the display reads "Reset Maint Cnt" on the second line of the display and press the [Select] button. The top line of the display should now read "Reset Maint Cnt" and the second line will read "Reset" and press the [Select] button. This will reset the counter. To exit out of the "Configuration Mode" cycle the power.
Apr 15, 2013 | Lexmark T630 Laser Printer
CM 1015mfp Colors are not aligned. when printing the characters looks like 3D.
If nothing else works, you may have to manually calibrate the dials inside the mirror box. This video link will show you how. http://youtu.be/R1DIko0a1MA
This may be necessary if the printer got bumped really hard.
Aug 17, 2011 | HP Color LaserJet CM1015 Printer
I have a Ricoh GX3050sfn, it says the collector unit is almost full. I have installed a new unit, but it is still saying that the collector unit is almost full!
O.K. I had this problem also. Here is the solution to reset the Collector Full or Collector Near Full Alarm:
1: Press the following buttons: Clear (Yellow Button) then 1, 0, 7 in that sequence then press and hold the Clear/Stop button. After a few seconds, the printers service menu will appear.
2. Scroll, using the arrow button, up til you see 'Engine Maintenance' in the lcd display. When you have that on the display press the 'Yes' button.
3. The LCD screen will read 1000. Using the arrow buttons change the first number to 5. Use the right arrow button to move the cursor to the last digit and using the up arrow button change the last digit to 3. The display should now read '5003'
4a: When you have '5003' in the display Press the 'Yes' button. The display will change to 'RST:WASTE:R'. 4b:Press the 'Yes' button. 'EXEC' will appear on the display. 4c: Press the 'Yes' button again. The display will change to 'OK?'. 4d: Press the 'Yes' button again. The lcd will read 'RUNNING'.
When it's done running it will revert back to the 'RST:WASTE:R' on the display.
5. At this point turn off the printer. Wait 10 seconds or so, then power the printer back on. After the printer is done starting up the error should be cleared and your free to continue on. YAY! You beat the system!
Another quick tip: If your collector is near full or even partially full, find yourself some latex gloves, a plastic knife and some paper towels. You can carefully clean the collected ink out of the tank with the knife using the paper towels to clean the blade off between scoops. If you're not careful, it can get messy,but in that way, with the reset instructions above, you can easily re-use a collector tank 3 or 4 times.
Mr. Wizard
Jan 31, 2011 | Ricoh GX3050sfn InkJet Printer
I read on the display Error:0xd05d010d Reset Power
Hello
HP suggests 3 reset levels.
Power off printer, then press and hold buttons while powering on, if it doesnn't reset, then unplug it and press and hold buttons while plugging it in,
# and 3 Partial Reset
# and 6 Semi-Full Reset
# and 9 Full Reset
A Full Reset will clear any stored information in the printer, speed dials, etc, so always start with a partial reset and work your way up.
Hope this helps
Jan 26, 2011 | HP Officejet 5610 All-In-One InkJet...
How do I reset the printer to the english language panel display
Follow these steps to change language setting on the printer display :
1.On the printer control panel, press the Left arrow twice or the Right arrow seventeen times on the Menu button until SELECT LANGUAGE? appears on the printer display screen.
NOTE: If the language is currently set to a language other than English, the Select Language? menu option will appear in that language.
2.Press the OK button.
3.Press the Left or Right arrows on the Select Photos button until your desired language appears.
NOTE: Even if the printer is currently set to another language, the name English will appear in the English language.
3.Press the OK button to select the language. A message requesting confirmation of the selection will appear appears. If the correct language is displayed, press the OK button. If the incorrect language appears, press the CANCEL button and start the selection process again.
4.When the SELECT COUNTRY/REGION? setting appears on the printer display screen press the OK button to continue.
5.Press the Left or Right arrows on the Menu button until the desired country/region appears on the printer display screen.
6.Press the OK button to select the country/region.
Nov 07, 2010 | HP PSC 1610 All-In-One InkJet Printer
Printer: HP C4599 All in One, Limited Ed Wireless Error message Printing cartridges missing or not detected. both cartridges are in the printer. This error message appeared 4 days ago, Have any idea...
I suggest you try to reset the printer. remove the cartridges before starting these steps.
1. Press the Power button and the Cancel button at the same time and release them. The display will show 'Enter Special Key Combo'.
2. Now press the Blue(Scan), Green(Color Copy) and Grey(Black Copy) buttons one after the other. The display will show 'Support
Oct 03, 2010 | HP Office Equipment & Supplies
Error : Oxc 18a0206
here.. check this out. a solution to your problem.
These are reset instructions designed to clear most of hp errors starting with 0xc...It works on different hp models.. it could work on you too.
Semi reset
1. While your printer is on.. unplug to power cable from the printer.
2. Press and hold the "OK" and "HELP" buttons while you plug the power cable at the back of the printer. Try these steps to reset your printer to default setting.
Full reset
1. Press & hold " * " key...(asterisk sign)
2. While holding the " * ", press "#" key and then release both keys..."Enter Special Key Combo" will be displayed...
3. Press "1", "2" and "3" to display Support...
4 Press ">" right arrow button and release when System Config Menu appear....then click OK
5. Press arrow key to display Hardware Failure Status...click OK....
6. When Hardware Failure Status:Clear appeared, press "OK" to clear...
7. Press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".....
8. Press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".....
9. The last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to proceed..After this try to print...
If you find the reset solutions helpful...Please rate this solution and vote YES ..thanks..
Jul 30, 2010 | HP Photosmart 3210 Printer
Scan not functioning. Provides NO ERRORS.
Unplug the power cable from the All-In-One when there is still power in the unit.
Also unplug the power cord from the wall outlet.
Leave the cable unplugged for atleast 1Min time.
And connect the cable directly to wall outlet with out any surg protector (if you have a different outlet try with that)
Then before connecting the cable to the All-In-One press and hold the # and no 9 button do not release the buttons untill it comes up with a mesage as reset (or if the screen goes blank then release the keys and turn the power on)
Then press the setup/menu button and then press the right arrow key till you see print reports> the press Ok and scroll to print test page and check if it is functioning properly.
Then try a color or Black copy and check.
Good Luck
Sep 12, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
42 people viewed this question
old marine
old marine
