Question about Dual Electronics CECT P168 Cellular Phone
I cant recieve my text messages using my sciphone i68
I can send them though
  • Anonymous May 12, 2009
    The phone says text failed? This happens every time. What do I do?
  • 193 Answers
First off need to know what cellular provider you are using, 2nd all text or picture text. regualar text is classified as SMS pic text is MMS. You may have a corrupt setting, but ill take a guess and post T Mobile setup. if you use someone else dont use these settings.
SMS Messaging:
1.) From the main screen tap the SMS Text icon.
2.) Tap SMS on the Messages menu.
3.) Tap SMS settings on the SMS menu.
4.) Tap either SIM1 or SIM2 on the SMS settings menu, whichever SIM you are setting
up at this time for SMS messaging.
5.) Tap Profile settings on the SIM1(2) message settings menu.
6.) Tap on any unused profile to select it, then tap the Edit button on the bottom of the
screen.
7.) You should be on the Profile name menu with the name field already highlighted. Go
ahead and tap the Edit button at the bottom of the screen.
8.) Tap in the following text between the quotes in the Profile name editor:
“T-Mobile”
Next tap the Options button at the bottom of the screen. Next tap the Done button.
You should be back on the Profile name menu with the new name.
9.) Tap the area below the profile name. The top of the menu should change to read SC
address and the bottom of the screen should show a numeral keyboard.
Tap in the following text between the quotes in the SC address editor:
“+12063130004”
Next tap the OK button at the bottom of the screen.
10.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen.
You are done setting up SMS messaging for T-Mobile. You can continue
to tap the Back button on the bottom of the screen until you exit out of all
the menus to the main screen, or simply press the On/Off button once to
get back to the main screen. At this point you can test SMS messaging by
sending yourself a text message, or continue with other setup of the
phone.
MMS Messaging:
2.) Tap MMS on the Messages menu.
3.) Tap MMS settings on the MMS menu.
4.) Tap Server profile on the MMS settings menu.
5.) Tap either SIM1 or SIM2 on the MMS settings menu, whichever SIM you are setting up
at this time for MMS messaging.
6.) Scroll down the list until you come to Profile 8. You can use any profile if need be, but
profile 8 is usually the first not already filled.
7.) Tap on Profile 8. Tap Edit profile.
8.) Tap just below Rename profile, then tap on the Edit button at the bottom of the screen.
9.) Clear the current text, then tap in the following text between the quotes
“T-Mo MMS”
Tap the Options button at the bottom of the screen.
Tap the Done button.
10.) Tap the area below Homepage, then tap on the Edit button at the
11.) Clear the current text except for “HTTP://”, then tap in the
following text between the quotes after the HTTP://
“216.155.174.84/servlets/mms”
12.) Tap the area below Data account, then tap Select at the bottom of
the screen.
13.) Tap GPRS on the Data account menu.
14.) Scroll down the list until you come to T-Mo MMS, the data account
set up under the Data Account Services section. Tap on T-Mo MMS
to select it.
15.) Tap the area below Connection type, then tap Select at the bottom of
the screen.
16.) Tap on HTTP, then tap on OK at the bottom of the screen.
17.) Tap the area below Proxy address, use the numeric keyboard at the
bottom of the screen to tap in the following numbers,
“216155165050”. The result should look like 216.155.165.050 under
Proxy address.
18.) Tap the area below Proxy port, use the numeric
keyboard again to tap in the following numbers
“8080” to replace the current 0 value. Then tap OK.
19.) The areas under both User name & Password should
remain BLANK. If they are not blank, select each,
and Edit them by clearing all text.
20.) Next tap the Done button at the bottom of the screen.
21.) A Save? question box should pop up. Tap the Yes
22.) Tap the Activate profile button on the T-Mo MMS menu screen, and you should be
taken back to the Select profile screen where a big green check mark will be beside the
newly saved T-Mo MMS profile.
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact prestorose@aol.com Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out and returned with instructions. Guaranteed safe transaction.
Posted on May 12, 2009
  • MSDLurker Dec 16, 2010
    I have a similar phone (T3000 X-Phone, Dapeng). So far, we've been able to set everything up using directions from the Sciphone i9... at least that's what we thought. We have At
I have the sciphone i9 +++ but cant receive sms on orange(uk) a g1 symbol appears when a text is supposed to come trhough or at least thats what I think it means. please help. i like the phone but without sms to me its pretty useless!
Posted on May 02, 2010
I have fido, and the same problem hapend to me. do any of you have the profile name and sc address for fido + sciphone?
Posted on Jan 02, 2010
  • hockey_gal04 Jan 02, 2010
    whats the sc address number for fido??
Make sure your sms center is the right number or it wont send text mesages i had the same problem but i found out that you need to make sure that your sms center is the right number hope this helped you out
Posted on Oct 02, 2009
I have a Mini i68, i can receive sms mess. but can't send them. i'm with Rogers in Toronto, Canada. Help.
Posted on Jul 09, 2009
2 Suggested Answers
fathitkf
  • 1871 Answers
SOURCE: cannot send/receive texts on sciphone i68
Hello :
You need to go to [message settings] and choose the right message center ! Or better you call AT&T care center for help .
good luck .
rate if useful please !
Posted on Mar 13, 2010
Cannot send/receive texts on sciphone i68
Hi, this is simple, there is what is called a message center number on every mobile phone that allows you to send and receive text messages. Since you can not send and receive text message, then it's either the message center number is not there or that you have a network problem from your service provider. Contact the customer service section of AT&T to make a complain about it and the problem will be resolve immediately..
Take care
Mar 12, 2010 | AT&T Cell Phones
Can send texts from sciphone but people arent getting them help!
if there's over 200 messages in your inbox and you have a new message it won't show you until you've deleted your inbox.
as for the other problem i haven't had that yet sorry.
Nov 19, 2009 | Cell Phones
Sciphone i68 cant enable gprs to use internet
my phone said gprs not subscribed which was not the actual case. i had internet service but it couldnt recognize it. I called service provider( t mobile in my case) and they text me a package that i downloaded and now it works fine
Oct 06, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
I68 sciphone can't recieve or make call or txt messages
try putting a 1 then area code then number.
(13215556666) this will also help with contacts names showing up when you rcv a call or text instead of just a number.
good luck
Jul 21, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
I cant recive nor send mms messages
call your carrier and tell them you need your new phone configured. they'll send a few texts to it and it'll be done.
call from another line if you can when you do this.
good luck
Jun 12, 2009 | Dual Electronics N99i Cellular Phone
Message alert tone for cect sciphone i68
If you have version 3 software there is no way that you can use mp3 or downloaded tones as message tones, best thing you can do is upgrade your firmware to version 4. Type this on the dial screen to check your version *#8375#
Jun 03, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Sci phone i68 phone
Try to type in the following code:
*#0044#
Find here an english user manual for SciPhone i68
May 28, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
I HAVE JUST GOT AN I68 SCIPHONE BUT IT CANT RECOGNISE MY CONTACTS ON SMS AND PHONE CALLS ANY IDEAS HOW I CAN RECTIFY THIS
Make sure the numbers in your contacts list is exactly correct. ex....if you get a call from John and his number shows up as 18326048921 then make sure in your contact list his number is in there exactly the same 18326048921. That's including the 1 and the area code. Hope this helps
May 18, 2009 | Dual Electronics CECT P168 Cellular Phone
Need gprs settings for i68 sciphone
http://three.wdsglobal.com/quicklink and i selected lg ku990 veiwty set settings to my phone then install all working planet 3 a little slow but working fine
Apr 20, 2009 | Lands Phones
Trouble with internet and mms messages on sciphone i68
Centennial Wireless Internet And MMS Settings For The Iphone!!!!!!!
ALL SETTINGS WORK AND BEEN TESTED ENJOY...........
$$$$$ HACKED BY QWAZY $$$$$
INTERNET
APN = private.centennialwireless.com
USER = privuser
PASSWORD = priv
MMS
APN = mmspublicwap.centennialwireless.com
USERNAME = "LEAVE BLANK"
PASSWORD = "LEAVE BLANK"
MMSC = http://mms.myblue.com/servlets/mms
MMS PROXY = 063.099.231.135:8080
MMS MAX MESSAGE SIZE = "LEAVE BLANK"
MMS UA PROF URL = "LEAVE BLANK"
Apr 05, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Dual Electronics CECT P168 Cellular Phone Logo
2,055 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
