MUSIC MANAGEMENT SOFTWARE THAT RUNS ON VISTA
The Music Management Software that came with the pearl wont install with windows vista where can i get the software to run with vista
I would suggest using ITunes for music management software on Vista, as it is VERY sophisticated in comparison to most others in creating MP3 files from your CDs / CDs from your MP3 files. You don't need specific software to load songs onto (or sync with) your Pearl. Just Drag/Drop or copy/paste folders from outside of ITunes as though the Pearl is a simple flash drive (which it is). Yes, I am running Vista and Vista (32bit anyways) works fine with ITunes. Don't forget to set up the options in ITunes for creating the directories and naming/tagging the MP3 files - and also don't forget to stop your connection to your Pearl before yanking it out of the USB port (good way to damage things eventually). p.s. If you want to check out truly outstanding music management software, check out Amarok for the KDE Desktop (ala Kubuntu Linux)
Posted on Dec 12, 2007
SOURCE:
Pc suite download
Okay for the PC Suite, connect the device to either Windows Vista or 7, and then download and install Desktop Software 7.1 from BlackBerry.com, here is the link: http://us.blackberry.com/software/desktop/desktop-pc.html Once downloaded and installed on Desktop Software you can do backups of the device, synch music and photos over to the computer or items on your pc back to the phone such as pictures stored on computer, you can also do regular software updates from Desktop Software.
Jul 28, 2013 | RIM BlackBerry Pearl Flip 8220 Cellular...
Music manager
WELCOME TO THE MAGICALLY FUSTRATING WORLD OF VISTA ..
Well here is what you can do that may work
1.) go to the manufactures web page for your device and download the new drivers for Vista (ONLY IF YOU DONT ALREADY HAVE IT).
2.) Download the music managers software for windows vista.. eighter from the devices manufactures home page or you can try this
http://www.helium-music-manager.com/
3.) You can transfer music directly to your device by copying and pasting it.. You device will show up in Compuer as a drive..
Let me know what happens or if i misunderstood your question
Feb 22, 2008 | RCA TH1101 MP3 Player
Freezing magix music studio 12 deluxe with vista 64 bit
I think the problem is..... Magix is compatible with XP 64 bit but not with Vista or 7 64 bit, not much 3rd party software is.
Sep 12, 2009 | Magix Music Studio 2005 Deluxe for PC
Keyboard stops responding after a powersave on laptop ACER 5715Z
The issue is that several of the Acer software products don't support Vista. You need to remove these programs.
Follow the instructions in this link
http://global.acer.com/support/winvista/t-faq.htm
Due to architectural changes to Windows Vista®,some Acer applications are not supported anymore. Below is a summary ofthese applications. Uninstall these applications before the upgrade.
Acer eRecovery Management The new version of Acer eRecovery Management, which is compatible with Windows Vista®,requires repartitioning your hard disk drive, causing data loss. As aresult, the Wizard will not reinstall the new version of eRecovery onyour computer under Windows Vista®. However, you will be able to find similar features in the built-in Backup Utility of Windows Vista®, including full system volume backup to a HDD or CD/DVD. Acer eAcoustics Management Windows Vista® supports similar functions of eAcoustics so Acer will no longer provide this utility for Windows Vista®. Acer ePresentation Management You can easily manage your external monitor settings via Windows Vista® Mobility Center. As a result, we do not support an upgrade to Acer ePresentation Management. Acer ePower Management Due to architectural changes to Windows Vista®,Acer ePower Management cannot be upgraded for some models. However, youcan easily manage your power settings via Windows Vista® Mobility Center instead. Acer ePerformance Management For notebooks only. Since Windows Vista® provides similar resource management functionalities, we will no longer provide this for notebook models with Windows Vista®. Acer Arcade™ Deluxe 3.x
Acer eNet Management 1.x
Acer eDataSecurity Management 1.x Due to architectural changes to Windows Vista®, these applications cannot be upgraded.
Alternately (not recommended) you can change your settings with the following method. I would recommend removing all the Acer software though as keeping them might cause problems.
Check under Advanced Power Options-> Multimedia Setting -> When Sharing Media. By default onBattery and Plugged is set to "Allow the computer to enter AwayMode" Changing this setting to "Allow Computer to sleep" should solve theproblem. On Battery the Away Mode "does" allow the computer to sleepproperly.
Jan 27, 2009 | Computers & Internet
Widows vista compatable
make sure you have the latest version of the program and the latest updates for your OS (you could even try older versions of the software). Is the software compatible with vista? Try and run the program in safe mode... If it still don't work then maybe it just isn't compatible with your current system configuration (google the problem to see if others had the same issue). does it freeze other computers running vista? Ask yourself these types of questions to narrow down the possiblities and therefore finding the source of your problem. If you require additional assistance just come back and one of us will promptly answer your questions :)
Dec 28, 2008 | Microsoft Windows Vista Home Premium with...
My laptop contains windows vista and i want to install Windows XP
i am using toshiba satellite l300model laptop. My laptop also contains windows vista. i want to install Windows XP as well. Some of my music software does not support Vista. Can you
please help me on how can i install Windows XP and how can i download the
XP drivers. I... Read more
May 20, 2008 | Computers & Internet
Get pictures and video off phone to the computer
Preparation ? if an external Micro SD external memory card is to be used as the desired music/video/picture repository on the W755, install the card in the W755 behind the battery. Then go to SETTINGS & TOOLS ? MEMORY ? CARD MEMORY ? FORMAT and format the new card. Caution: reformatting the card will wipe out all contents on the SD card. Download/install free Motorolla Handset USB Driver Installer onto the PC (execute ?.msi? file). Download/install free VCast/Rhapsody software (no need to actually sign in or use the proprietary Rhapsody service). Start the VCast/Rhapsody software. Turn on cell phone (works with W755 and may work with other Verizon ?music phones? such as LG Chocolate, but the latter was not tested). Connect phone to PC ? connect USB cable to PC?s USB port first, then connect USB cable to phone . Be patient, it may take a minute to fully ?connect? in the phone?s display. Go to ?Sources? section of VCast/Rhapsody GUI screen ? the phone will register as a directory title using a name roughly like ?VCast xxx.? Windows Explorer will also show a ?VCast? drive/directory device. Files can be selected and dragged to and from source and target directories. At this point various options exist regarding music, picture, video management: 1.) The VCast/Rhapody software can be used to manage music, picture, and videos between the PC and phone. Again, no need to use the VCast service, just the software offline. 2.) Alternatively, other music management software such as Media Monkey (a personal favorite) can be used to move music, create playlists, etc. ? NOTE: Leave VCast/Rhapsody software running in the background as a means to ?connect.? It is best to start VCast, then plug in phone, then start other media management software so that the media management software will benefit from the connection (usually with a directory name using some variation of ?VCast.? Then use the alternative media management software as usual. Please note, this is a generalization based on success using basic software like Media Monkey, for example.
Apr 26, 2008 | Motorola Cell Phones
Iriver S10
If you want to copy music from cd to the S10, just use Windows Media Player to rip the cd, creating eg WMA files on your hard disc. Then copy them to the S10. Don't need any iriver software.
Mar 26, 2008 | iRiver S10 2 GB MP3 Player
Need file transfer Software!!!???
You do not need any specific software to transfer music. You can Drag and Drop files thru Windows XP or Vista, or use Windows Media Player 10 or higher, Rhapsody, or several other music management programs.
The only software on the CD was Rhapsody, or the Best Buy Digital Media Store. Both of which are on the internet.
http://www.rhapsody.com/-software
or
http://www.rhapsody.com/download.jsp?from=bbdms
Best of Luck.
Oct 13, 2007 | SanDisk Sansa e250 MP3 Player
No Software Support - Need Virgin Music Management Software
I saved the management software before I formatted the drive but I need the virgin software disc to repair the drive now. Contact me and we can make a file swap. regards Mike
Apr 23, 2007 | Virgin Electronics VM-500 MP3 Player
138 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
