my monitor is vibrating, like it is constantly jumping up and down, kinda like your trying to scroll up and down really really fast, and i dont know how to stop it, what do i do?
Depending on what monitor you have (most new lcd/plasma models dont have vertical hold) it may have a vertical hold adjustment knob. If you have not already tried adjusting it, turn it all the way clockwise, then all the way counter-clockwise, and then see if you can find a middle ground and slow or stop the jumping.
Another thing it could be is your video adapter, if the above step does not repair it, shut down the computer, unplug the video cable, then plug it in again and secure it tightly with the provided screws. If THAT still doesn't do it, shut down, remove the video card, then make sure the contacts are not damaged and are clean, re-insert the card and secure it properly to the chassis with its screw. Attach the video cable, and turn on the computer.
If none of the above fixes your issue, the last step I would suggest is reinstalling/updating the drivers for the video card, available at your card manufacturers website.
If that doesn't help you, the only way to continue troubleshooting would be to open the device up and service it, which I would strongly advise against if it is a CRT monitor (Glass screen, heavy) as certain components hold strong charges that can seriously harm you and possibly cause death, if you touch the wrong component.
Try changing the screen refresh rate in Desktop -> Properties -> Settings -> Advanced -> Monitor for xp or Desktop -> Personolize -> Display Settings -> Advanced Settings -> Monitor for vista
My server use Tyan S3970 motherboard and Volari Z7 display adapter. First time My server have no...
(More)
My server use Tyan S3970 motherboard and Volari Z7 display adapter. First time My server have no problem with display adapter, but suddently one day my Volari Z7 display adapter getting disable. When I change dan make it enable and restart the server, when windows logo appear my server hang. So I must run windows with safe mode and make Volari Z7 display adapter disable. Until now my server run normally with disable display adapter Volari Z7. I see event viewer looking for a problem, but I cannot found it.
I bought my graphics card a year ago and the blu-screening
problems where there but not as...
(More)
problems where there but not as annoying ..my computer blu screens when i run NFSUC and starts only 2out of 5 times but works OK with other programs.
when it asks you to select an "x" amount of recording time, it won't even let me change it...
(More)
WHEN IT ASKS YOU TO SELECT AN "X" AMOUNT OF RECORDING TIME, IT WON'T EVEN LET ME CHANGE IT FROM ZERO, THEREFORE I AM NOT ABLE TO MOVE FORWARD THROUGH THE PROGRAM.... ALSO, WOULD IT BE POSSIBLE TO HOOK SECURITY CAMERAS DIRRECTLY TO THE DAZZLE DEVICE ITSELF, SO LONG AS IT HAS RCA CONNECTIONS ATLEAST.... AND WILL IT BE ABLE TO RECORD AND MAKE A DISC, MOVIE OUT OF WHATEVER IS CAUGHT ON CAMERA ?
