Question about Whirlpool WTW5560SQ Top Load Washer
Hi. My water level knob is very hard to turn and the water level is not correct when filling the washer. Any thoughts?
Hi. I have a Whirlpool WTW5560SQ model top-loading washer. The volume level know is very hard to turn to different levels, and the water level does not seem correct to fill the tub.
  • 365 Answers
If it has been quite some time since you turned the knob it is possible that it is starting to sieze up, you may have to replace the switch behind the knob
Posted on May 10, 2009
Whirlpool Ultimate Care II LSB200KQ1 Top Load Washer - the washer filled and then stopped. No humming, no sound, no action when we turn the knob. Thoughts?
The limit switch that detects that the lid is closed is probably defective. You've already probably experienced how the agitator would stop if the lid was opened when the machine was working properly--same thing.
Jul 17, 2012 | Whirlpool Washing Machines
Whirlpool utlra care II clothes washer shuts off when filling - push knob in and pull out it starts again - once full it completes remaings cycles
Hi, the water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Nov 17, 2010 | Whirlpool Washing Machines
Washer didnt fill when turned on, but filled when holding "reset"
sounds like your water level switch is bad OR the small hose that goes from the waterlevel switch to the bottom of the tank has a hole in it.Try replacing this small hose first.you can go to an auto parts store and match it up.it's usually about 3' long and about 1/4" inside diameter and about 99cents a foot.
Aug 26, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Fills up with water and shuts off...
This information may help you to learn more about your washer.
copy n paste
http://www.partselect.com/MultiModels.aspx?ModelNum=RAS6233KQ&searchTerm=img_I3TR96FR&RefineSearch=0&imgMfg=Whirlpool
becouse it was over load it may be out of balance becouse of the
exessive weigh.
"Did it solve your problem?"
Apr 01, 2009 | Roper RAS6233KQ Top Load Washer
LTE6234 Whirlpool Twin Thin Timer Broken?
Check for voltage at the water inlet valve with the timer dial pushed in or in an off position. If no voltage replace the water valve. If you do have voltage you'll have to trace the circuits back from the water valve to the line. One point of demarcation is the water level switch. Pull the violet colored wire and see if it still fills while off. If it does it's likely the timer's bad.
Jan 31, 2008 | Whirlpool LTE6234D Top Load Stacked...
WATER WILL NOT FILL
if no voltage at water valve when unit is set to fill and timer knob is in its correct position ie pulled out then you probally have a bad water level switch or a bad timer
Oct 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer filling up improperly
Well its definately not your water level switch, so that only leaves your water fill valve at the back of the washer, the cold valve is stuck open by debris. hope this helps
May 18, 2007 | Whirlpool LSR5132PQ Top Load Washer
It will not fill with water
how do you open top on whirlpool washer?
Jan 23, 2007 | Whirlpool LSR9434PT Top Load Washer
Whirlpool WTW5560SQ Top Load Washer Logo
121 people viewed this question
Dan Webster
Dan Webster
Sal De
